- Thank you received: 338
PCW wrote: An interesting question is whether the 5 ms delay is present in position mode as well.
Connecting the encoders could answer this. This delay might cause issues with spindle
synced motion like rigid tapping.
This brings up a general observation, your errors are not huge, in fact you may have
never noticed them when machining and similar errors may also exist in step/dir
position mode.
A similar situation happens when people add linear encoders and discover all
the backlash and stick-slip errors that they had never noticed before.
Does the overcurrent alarm go away if you reduce the acceleration?
(200 IPS/S is likely beyond what the motors can do with a high inertial load)
