Running servos in position mode instead of analog
5 years 7 months ago #202315 by Michael
I tried auto tune. Didn't change.
Tried high gains, low gains and everything in-between. Spent weeks on these things. No change.
Tried analog signals and step signals to tye drives. No change.
The velocity command and analog output are dead on the with each other.
Not sure how we would adjust for the delay in the control. That defeats the purpose of synced motion and honestly not what I payed DMM for.
I have a heidenhain encoder I am going to mount directly to the motor shaft to hopefully show the DMM technician that the issue is with their product and get my money back. Just have not gotten around to it.
5 years 7 months ago - 5 years 7 months ago #202441 by silden
Please mount the encoder to the shaft. This will show if the delay is encoder output or the processing time from control input to execution.
Modern drives have a delay from control input to execute the command. I didn’t expect 5ms. but most non CNC applications that is more than acceptable. This doesn’t mean we should happy with it.
Centroid is compensating the delay from command sent to execution. This delay will always be the same. And the whole timeline will be delayed. PID control is possible after the first delay is absorbed and the control output is synced. The delay is measured during setup process and stored.
I don’t know how it is applied to the PID loop or the motion controller.
Last edit: 5 years 7 months ago by silden.
5 years 7 months ago #202478 by bevins
I am using these on a plasma and not connecting back to linuxcnc the encoders so I probably would not see the error and delays.
Good to note not to use DMM in the future but they are half the price of Yaskawa's, so if you don't need to close loop at linuxcnc I guess they would work.
The following user(s) said Thank You: silden
5 years 5 months ago #208389 by bevins
Michael wrote:
Bevin's, did you close the position loop back to Linux? If so care to share any info or hal files?
No I didnt use it. There was a wicked delay I couldnt get rid of. I am not bringing the encoder back to linuxcnc. Plasma machine and it iws working fine.
The following user(s) said Thank You: Michael
5 years 5 months ago #208515 by OT-CNC
Post here what you find out after mounting the encoder please.
I have an older gen of DMM servos on a lathe that have been working very reliably in step/dir mode. I also was not able to tune them in velocity mode most likely due to the delay and user errors (I was new to linuxcnc on that build). I was considering the DNY4s for a future build. I'm curious to see if a linear encoder or standard rotary encoder mounted to a ballscrew could be a workaround for velocity mode with Linuxcnc.
5 years 5 months ago #208516 by Michael
My schedule got a bit busy lately but I plan to be back on this project next week. I will let you know what I find out.
Moderators: PCW, jmelson
Time to create page: 0.497 seconds
