- Thank you received: 167
You have to ask yourself "why is no one else having the same issue running Linuxcnc and servos in closed loop". Maybe the issue is with DMM servos not being well built.
Actually, it's not uncommon to have delay issues when using drive generated feedback.
I had the same issue using Mitsubishi MELSERVO J4 drives with step/dir.
There is a whole thread about that here:
forum.linuxcnc.org/10-advanced-configura...pain?start=30#193073
Isn't dm17ry the guy who makes LinuxCNC controller cards for Yaskawa/Mitsubishi servos? He's also the guy with the infamous pick and place machine right? These guys are talking 5-10ms delay on the encoder outputs on much more expensive Mitsubishi servos so maybe we should lower our expectations a bit for DMMsi've been playing with several generations of mitsubishi/yaskawa position controlled servos. not actually a pulse train though, but sscnet/mechatrolink - but that shouldn't matter.
so, they all exhibit similar behavior. there's no way to eliminate this time lag completely with tuning without introducing serious overshoots. but to counteract it, those protocols have a provision to latch the motor encoder counter at encoder z-index or some external signal wired directly to the drive. when that happens the drive raises a flag and controller can read back the latched position. kinda like linuxcnc's index-request...
Jumping the gun a bit Blazini, he explicitly mentions "not the pulse train ones":OK, so you're refuting what dm17ry said? Like I wouldn't do that, not with Yaskawas or Mitsus
Apparently it does matter, but that would require much more testing and with a pool of devices.i've been playing with several generations of mitsubishi/yaskawa position controlled servos. not actually a pulse train though, but sscnet/mechatrolink - but that shouldn't matter.
I'm not familiar with Mitsubishi drives, I've dealt with Yaskawa black box servopaks and Sigma V's but that was OEM/industrial use over serial because of their indexer. Do you have or can you get a measurement of the "lag" of the encoder output of whatever you have laying around?the delay i was talking about is present in mitsubishi drives in position control mode. when i tested a MR-J3-A drive in speed control mode with my own YAO2 +-10V analog out and ABZ feedback - i had absolutely no problem using linuxcnc's PID. despite serial communication to YAO2, then SPI DAC on it, and then again ABZ encoder position transmitted back to linuxcnc via a serial link...
