6I25 --recover
- Thank you received: 5335
20 Mar 2021 20:24 #203032
Replied by PCW on topic 6I25 --recover
It may need JTAG to recover
(not sure if mesaflash knows how to re-write the boot
sector in --recover mode)
- silden
- Thank you received: 3
20 Mar 2021 20:28 #203034
by silden
Replied by silden on topic 6I25 --recover
We have an ATmel ICE and flyswatter2 JTAG.
will this work and what would be the process?
- RayJr
- Thank you received: 4
19 Jun 2021 03:43 #212380
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic 6I25 --recover
Did this issue ever get resolved?
I am having the same issue with a 6i25 card purchased back in October.
I am also seeing the ethernet port disable when the card is installed.
Albert Einstein
19 Jun 2021 03:48 #212382
What issue do you have?
- RayJr
19 Jun 2021 04:17 #212384
by RayJr
Albert Einstein
When I ordered the card I specified the 5i25_7i85s_pmdx132.bit to be loaded.
I installed it in a temporary system and ran:
mesa flash --device 5i25 --readhmid
and the reply was:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
Number of IO Ports: 0
Width of one I/O port: 0
Clock Low frequency: 0.0000 MHz
Clock High frequency: 0.0000 MHz
IDROM Type: 0
Instance Stride 0: 0
Instance Stride 1: 0
Register Stride 0: 0
Register Stride 1: 0
Modules in configuration:
Configuration pin-out:
I try to write the bit file to the board with:
mesa flash --device 5i25 --write 5i25/configs/hostmot2/5i25_7i85s_pmdx132.bit
And I get back:
Checking file... OK
File type: BIT file
Error: Bootsector is invalid
I try
mesa flash --device 5i25 --write --recover 5i25/configs/hostmot2/5i25_7i85s_pmdx132.bit
and I get:
No 5i25 board found
IF I try:
mesa flash --device 6i25 --recover --write 5i25/configs/hostmot2/5i25_7i85s_pmdx132.bit
it goes through the motions of erasing, writing, and verifying, successfully. I then shut the system down, & restart.
then run the --readhmid, with the previous result.
The board seems to be having an identity crisis!
The ethernet port on the motherboard seems to not work with the board installed. Could there be a conflict?
Ray
and the reply was:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
IDROM Type: 0
And I get back:
Checking file... OK
File type: BIT file
I try
and I get:
No 5i25 board found
IF I try:
Ray
Albert Einstein
- RayJr
19 Jun 2021 04:18 #212385
by RayJr
Albert Einstein
The board is a 6i25, with all of the jumpers in the default (factory) positions. No daughter boards connected.
Albert Einstein
19 Jun 2021 15:36 #212414
Are you using the latest mesaflash version?
- RayJr
19 Jun 2021 17:37 #212429
by RayJr
Albert Einstein
I am using the version that was installed with the latest LinuxCNC buster ISO.
How do I find what version that is?
Ray
Ray
Albert Einstein
- RayJr
19 Jun 2021 18:33 - 19 Jun 2021 18:42 #212433
by RayJr
Albert Einstein
There doesn't seem to be a linux version of mesa flash in the 5i25 firmware archive from the mesanet 6i25 page.
Albert Einstein
Last edit: 19 Jun 2021 18:42 by RayJr.
19 Jun 2021 19:51 - 19 Jun 2021 19:53 #212436
github.com/LinuxCNC/mesaflash
Is the latest but the one from the ISO should be OK
It could possibly be failed hardware of BIOS related
What does
lspci -v
show?
What does
lspci -v
show?
Last edit: 19 Jun 2021 19:53 by PCW.
Time to create page: 0.173 seconds
