6I25 --recover
19 Jun 2021 22:24 #212445 by RayJr
Replied by RayJr on topic 6I25 --recover
Well that brings up some strangeness of this install
It doesn't have lspci.
a search in Synaptic package manager shows no results for it.
Do you know what library it might be hiding in?
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
19 Jun 2021 22:32 #212446 by tommylight
Replied by tommylight on topic 6I25 --recover
sudo apt-get install pciutils
19 Jun 2021 23:05 - 19 Jun 2021 23:08 #212447 by RayJr
Thank you for that Tommy!
Here are the results:
Without the 6i25 card installed:
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 08)
00:02.0 VGA compatible controller: Intel Corporation 8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port (rev f0)
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port (rev f0)
00:1d.3 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a2ca
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
With the 6i25 installed:
00:01.0 PCI bridge: Intel Corporation Skylake PCIe Controller (x16) (rev 08)
01:00.0 PCI bridge: Texas Instruments XIO2001 PCI Express-to-PCI Bridge
02:00.0 DPIO module: Device 2718:5125 (rev 01)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
I still am not understanding why the ethernet controller stops working with the card installed.
Albert Einstein
Last edit: 19 Jun 2021 23:08 by RayJr.
20 Jun 2021 00:24 #212451 by tommylight
The only reason for ethernet to stop working when inserting any add on card is if the assigned IRQ is the same and one of the devices does not play nice.
Solutions:
-Insert the add on card into another slot, if possible
-In BIOS disable automatic assignment of IRQ, then try changing the IRQ for the add on card, boot and check if ethernet is working, if not choose a different IRQ. Not much choice there, but do avoid 13, it is used for some stuff that will halt the system when the flag is set.
20 Jun 2021 00:25 #212452 by RayJr
I downloaded the mesaflash from GitHub & compiled.
It behaves very much better! It now shows me there is firmware on the card & I verified it to the .bit file I have, and it matches!
Still having issues with the ethernet port with the 6i25 installed.
Digging some more.
Albert Einstein
20 Jun 2021 00:27 #212453 by PCW
Replied by PCW on topic 6I25 --recover
Can you try:
lspci -vv
It look to me like the BIOs has messed up the Ethernet slot information
somehow thinking that its behind the 6I25s bridge
20 Jun 2021 01:18 #212456 by RayJr
I seem to have gotten the ethernet port to work with the 6i25 card installed.
While the card was out, I forced NetworkManager to write out the ethernet scripts.
Put the card back in the machine, and now works. Not the first time NetworkManager has burned me.
Attached are the lspci dumps
Albert Einstein
20 Jun 2021 15:56 #212494 by RayJr
With PCIE motherboards, control over IRQs is pretty much gone, since it is no longer hardware bound, and virtualized in the chipset.
Please correct me if that is wrong, with some examples.
Albert Einstein
20 Jun 2021 16:52 #212499 by tommylight
They are still used, but not sure how since i have not been professionally working in that industry for over 12 years.
cnc@NVME1TB:~$ lspci -v | grep IRQ
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Flags: bus master, fast devsel, latency 0, IRQ 26
	Flags: bus master, fast devsel, latency 0, IRQ 27
	Flags: bus master, fast devsel, latency 0, IRQ 28
	Flags: bus master, fast devsel, latency 0, IRQ 30
	Flags: bus master, fast devsel, latency 0, IRQ 31
	Flags: bus master, fast devsel, latency 0, IRQ 40, NUMA node 0
	Flags: bus master, fast devsel, latency 0, IRQ 55
	Flags: bus master, fast devsel, latency 0, IRQ 39
	Flags: bus master, fast devsel, latency 0, IRQ 33
	Flags: bus master, fast devsel, latency 0, IRQ 35
	Flags: bus master, fast devsel, latency 0, IRQ 36
	Flags: bus master, fast devsel, latency 0, IRQ 38
	Flags: bus master, fast devsel, latency 0, IRQ 34
	Flags: bus master, fast devsel, latency 0, IRQ 37
	Flags: bus master, fast devsel, latency 0, IRQ 66
	Flags: bus master, fast devsel, latency 0, IRQ 85
	Flags: bus master, fast devsel, latency 0, IRQ 67
	Flags: bus master, fast devsel, latency 0, IRQ 56
	Flags: bus master, fast devsel, latency 0, IRQ 87
cnc@NVME1TB:~$
But we are over 16 for sure, that was the main limit.
20 Jun 2021 17:47 #212504 by RayJr
That was the beauty of the PCI & PCIE busses. We got away form hardware interrupts! The Bus Mastering system eliminated all that grief.
The motherboard I am working with is a mini ITX, with an Intel i3 processor with internal GPU, one PCIE-16 slot. The board has an M2 socket that can work in a SATA mode for an SSD, or PCIE mode for another expansion card. A second M2 socket is set up for a WI-FI/Bluetooth card.
The only BIOS configurable IRQ is for the RS-232 port, which is a legacy interface.
The systems I care for @ work are high end workstations, with a PCIE expansion box that adds 8 more 16 lane PCIE slots, that are stuffed with high end nVidia GPUs. They all pick up IRQs from the bus mastering system, and pretty much never have a conflict.
Albert Einstein
Moderators: PCW, jmelson
Time to create page: 0.093 seconds
