ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- deroj
- Thank you received: 21
full_name [Peter van Tol]: peter
email [This email address is being protected from spambots. You need JavaScript enabled to view it.]: This email address is being protected from spambots. You need JavaScript enabled to view it.
module_name [Litex-CNC module]: test_module
module_slug [test_module]: test_module_slug
version [0.1.0]: 0.1.1
module_short_description [Module Boilerplate contains all the boilerplate you need to create a Litex-CNC module.]: description
fingerprint [0x923e1bd0]: 0x923e1bd0
File "/home/oj/.local/bin/cookiecutter", line 10, in <module>
sys.exit(main())
File "/home/oj/.local/lib/python3.7/site-packages/click/core.py", line 1130, in __call__
return self.main(*args, **kwargs)
File "/home/oj/.local/lib/python3.7/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/oj/.local/lib/python3.7/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/oj/.local/lib/python3.7/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/oj/.local/lib/python3.7/site-packages/cookiecutter/cli.py", line 207, in main
accept_hooks=_accept_hooks,
File "/home/oj/.local/lib/python3.7/site-packages/cookiecutter/main.py", line 120, in cookiecutter
accept_hooks=accept_hooks,
File "/home/oj/.local/lib/python3.7/site-packages/cookiecutter/generate.py", line 351, in generate_files
unrendered_dir, context, output_dir, env, overwrite_if_exists
File "/home/oj/.local/lib/python3.7/site-packages/cookiecutter/generate.py", line 205, in render_and_create_dir
name_tmpl = environment.from_string(dirname)
File "/home/oj/.local/lib/python3.7/site-packages/jinja2/environment.py", line 1105, in from_string
return cls.from_code(self, self.compile(source), gs, None)
File "/home/oj/.local/lib/python3.7/site-packages/jinja2/environment.py", line 768, in compile
self.handle_exception(source=source_hint)
File "/home/oj/.local/lib/python3.7/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<unknown>", line 1, in template
jinja2.exceptions.TemplateSyntaxError: unexpected '}'
- TOLP2
- Thank you received: 178
The goal of this template is to make extra modules easier. The two projects I have now in mind:
- toolerator. Basically a port of an old project for my Emco 5 turret. The caroussel component still requires some work to get it working, so I decided I want to send a tool number to the FPGA and it selects the correct tool.
- hy_vfd: A little more far fetched, as my current mill does work well, but I just want to have less cables.This module should offer the same functionality as the component with the same name: sending commands to a HuangYang VFD.
- deroj
I also would like to have a serial port on the board. With a rs232 to rs485 converter I send commands to my VFD.
Wrote a hal component for my Mesa 5i25 and it works good.
On my 7i96 I get warnings, because the hostmot serial driver seems to have some problem over ethernet....
- TOLP2
Thanks to the power of Python (or OOP in general), I was able to re-use large parts of the stepgen module for the toolerator. I have added a position mode to the stepgen. In this mode the stepgen will move to the commanded position while adhering speed and acceleration limits. In this mode it is not required to (ab)use the motion planner of LinuxCNC. The accuracy of the position mode is depending on the acceleration of the stepper motor. The motion is stopped whenever the error is smaller then 5 times the acceleration per clock cycle. When using an acceleration of 200,000 steps/s² and a FPGA clock speed of 40 MHz, the accuracy is within 10E-7 steps!
A caveat is that changing from velocity to position change (if required) can only be done at stand-still, or otherwise the movement might overshoot a little (10E-4 steps) the first time the stepper comes to a standstill. This overshoot might trigger an extra step.
When a tool change is requested, the toolerator:
- translates the tool-number to a position in the turret, this position is send to the FPGA;
- based on the current position of the turret, the turret will move forward to the new position plus some amount of overtravel;
- to lock the tool in place (it is a ratchet type), the tool changer is moved backwards;
- when the turret has stopped moving, the tool change is reported to be ready.
I believe that this module gives some possibilities to create programs with the FPGA, not necessarily tied to LinuxCNC
- deroj
Is there a How To?
Is it Python? All I see is in C...
EDIT: Sorry...I found the folder with the Python Code example
- deroj
There is already an UART core in LiteX.
Can you use it out of the box?
My big quastion is, how is the assignment to a pin done?
- romanetz
- Thank you received: 35
UART communication needs FIFOs and a kind of flow-control in driver and in firmware. In order to make Modbus communication possible (remember allowed delays and turnaround time)
- TOLP2
One challenge though would be the timings and speed. If anything like USB is used to create a serial port, this solution will not work in real-time. That's because of the nature of USB, any re-indexing or interrupt will cause a unacceptable delay on the port. However, it might be interesting for the UART on a RPI4, because you would be directly using the GPIO.
A bummer would be the speed of the UART. Let's assume a cycle period of 1 ms, or 1,000 updates per second. Every update consists of read (which starts with a write of the addresses to be read) and write. On average the read and write are something like 30 bytes; which means every cycle we have to transfer 100 bytes. This means the data-transfer required is 100 kb per second. The speed of UART is 115,200 baud tops, so in the best case scenario we can transmit is 14k4 bytes.
With the speed of UART it will be very difficult to send the required data to the FPGA. It might hamper the amount of functions / modules you want to have (128 GPIO only asks for four bytes and will most likely work) or the update speed / cycle period.
But I like the idea! Would love to have / write a driver for this.
- romanetz
- deroj
But all I would use the UART for is to send bytes to a RS232 / RS485 converter and read bytes back from it. These data should be transfered together with the other data from / to LinuxCNC.
I do not want to control stepeers, encoders, etc over UART.
So maybe, the part from lines 54 to 150 looks like it takes the data byte and shift it right out to a fpga pin. And the "rx"pin into a data-byte.
EDIT:
I attached my component for the Mesa card, so maybe you know what I want.
It maybe not the perfect C programming, but it works
I changed the Bit-file, so the Mesa card has an UART and then I used the "mesa_uart.comp" to send and receive the bytes I need.
