If the pins are correct (3. 5. 13.), there are no movement on the not working channels.Here is the encoder input circuit, you can check if the 26LS32 is faulty by seeing of the
outputs follow the input state. (the outputs are inverted from the TTL input levels)
OK. I won't risk.You could, but you risk more damage if you accidentally connect the 5V to a 3.3V signal.
Most likely the inputs of the 26LS32 has been damaged so the chip needs to be replaced.
This takes care and protection of the nearby plastic connectors with some kind of
insulation from the hot air gun heat (I typically use some paper sticky labels on
the green connectors)
