7i96S card arrived what setup is recomended
- Thank you received: 5321
26 Dec 2022 16:14 #260331
Replied by PCW on topic 7i96S card arrived what setup is recomended
7I96S spindle output is 18V max so if you wanted a
bipolar output you would be limited to a18V supply and +-9V
output range
output range
- xenon-alien
- Thank you received: 4
26 Dec 2022 20:59 #260344
by xenon-alien
18v max means not
Sp- = -18v
Sp+ = +18v
I have -15v and +15v, all together 30v out, or ±15v. It wont damage the analog output?
Sp- = -15v
Sp+ = +15v
SpOut = ±9?
Replied by xenon-alien on topic 7i96S card arrived what setup is recomended
Not really understand.7I96S spindle output is 18V max so if you wanted a
output range
18v max means not
Sp- = -18v
Sp+ = +18v
Sp- = -15v
Sp+ = +15v
SpOut = ±9?
26 Dec 2022 22:02 #260351
18V is the maximum voltage between SP- and SP+
so +- 9V is the maximum bipolar voltage that can be applied
+18 on SP+ and -18 0n SP- is 36 V total which will damage the
analog output
analog output
The following user(s) said Thank You: xenon-alien
- xenon-alien
26 Dec 2022 22:09 #260353
by xenon-alien
So there is no chance to use it with ±10v
And we must make from ±15v ±9v. Or even will be best ±8v to be 100% sure.
But there is no possible way to change the driver settings for lower driving voltage...
Now I see...18V is the maximum voltage between SP- and SP+
analog output
26 Dec 2022 22:26 #260354
Well you _might_ get way with +-10V but thats close to the edge...
The spindle circuit is protected with a 18V nominal TVS diode
which will typically start conducting at about 20.5V
- xenon-alien
27 Dec 2022 07:21 #260378
by xenon-alien
Ok.
We will try to come up with something.
It's a little bit strange solution have only 18v max between Sp- Sp+.
With a standard inverter it's not a problem (0-10v, or 0-5v), but most old servo drives has ±10v driving voltage (as some inverters and in my case).
The 7i76e also has only 15v max between Sp- Sp+?
Why did you choose a this kind of solution, without any voltage margin for driving analog input by ±10v? (max voltage range 30v between Sp- Sp+)
27 Dec 2022 15:32 #260399
The 7I76E and 7I96S spindle outputs are intended for standard VFDs that have
0 to 10V or 0 to 5V inputs. In this case 15V or 18V leave plenty of margin.
Bipolar (+-10) spindle controls are much less common and require more (and more expensive) circuitry to handle properly.
- xenon-alien
28 Dec 2022 10:26 #260459
by xenon-alien
I have asked the electrician. It will be fine for our purpose.
Thank you!18V is the maximum voltage between SP- and SP+
- xenon-alien
12 May 2023 08:36 #271212
by xenon-alien
Finally I returned to this Lathe.
But not really understand, how to configure the spindle section...
I have run a PNCConf (in LCNC 2.9~1-54....) and check the box with ± spindle direction.
When the spindle at 1 rpm I see on the SP output -8.78V (nearly the -SP voltage), but it should be ~0.1v. When the spindle i Off I see on the SP output the -SP voltage.
I have -SP -8.8v and +SP +8.9v.
How to make it work properly? Sp Off = SpOut - 0v
Hello!18V is the maximum voltage between SP- and SP+
12 May 2023 13:54 - 12 May 2023 13:54 #271226
With bipolar supplies if you want 0 output, the PWM must be 50% of full scale.
This is done by setting the PWM offset mode true:
set hm2_7i96s.0.pwmgen.00.offset-mode true
Note that you must use an additional output to control spindle enable
because the analog out will start up at full negative speed when linuxCNC
is not running
is not running
Last edit: 12 May 2023 13:54 by PCW.
The following user(s) said Thank You: joekline9, xenon-alien
Time to create page: 0.212 seconds
