7i96S card arrived what setup is recomended
- behai
- Thank you received: 17
27 Jan 2025 12:31 - 27 Jan 2025 14:37 #319947
by behai
Replied by behai on topic 7i96S card arrived what setup is recomended
Please help me with the wiring of a single CL57T-V4.1 closed loop driver to Mesa 7i96S
( I am able to get PnCconf to see the Mesa 7i96S board. )
This is the manual of the CL57T driver: www.omc-stepperonline.com/download/CL57T_V4.0.pdf
The printed manual comes with the driver is version CL57T-V4.1, but I can't see any difference.
Based on the manuals for the driver and 7i96S, I understand that:
● Mesa 7i96S STEP pin is the Driver PUL pin. E.g., for a 1.8° step motor, 200 PULSES is a full STEP.
● Mesa 7i96S DIR pin is the Driver DIR pin. I.e., Clockwise or Counter Clockwise.
● The CL57T_V4.x driver requires input voltage 18-50VDC (recommended 24-48VDC). Peak Current: Minimum 2.4 (RMS 2A), typical 5.6 (RMS 4A), max 7.0 (RMS 5A). So it is not a "higher than normal input current requirements" as per Mesa 7i96S manual page 12.
● The CL57T_V4.x driver supports both differential inputs and single-ended inputs. ( I'll wire it to use differential inputs, since it offers better performance. )
And so I am going to attempt this:
1. Is the wiring correct please?
2. The driver manual, page 7, states:
The 1-bit selector is located on the top (S3 in figure 2), used to configure the voltage of control signals. For the safety of optically coupled, the factory setting is 24V, which no need to connect 2K resistors, making it easier to use. When the voltage of the control signal is 5V, the S3 must be set to 5V, otherwise, the motor won't work.
To use the driver using Rasberry Pi 4 as a controller, I have to set the driver S3 to 5V ( I have documented in this video: )
Using it with 7i96S, should I set it to 5V or 24V, please?
3. Do we just leave the driver ENA, ALM and BRK un-used, please?
Thank you.
Thank you.
Last edit: 27 Jan 2025 14:37 by behai.
- Thank you received: 5325
27 Jan 2025 14:58 #319953
Replied by PCW on topic 7i96S card arrived what setup is recomended
7I96S CL57
+5V PUL+
STEP- PUL-
+5V DIR+
DIR- DIR-
SW3 Set for 5V mode
The ENA, ALM and BRK can be left unconnected
+5V PUL+
STEP- PUL-
+5V DIR+
DIR- DIR-
SW3 Set for 5V mode
The following user(s) said Thank You: behai
- behai
28 Jan 2025 01:48 #319969
by behai
I have read page 12 of the 7I96S manual several times, but I don't think I fully understand it ( this is all new for me ):
Some drives with higher than normal input current requirements benefit from single ended wiring as this cuts the output resistance of the 7I96S drivers in half. In this case, suggested wiring is PUL+, DIR+ to 5VP then PUL- to STEP- and DIR- to DIR-
The wiring you have corrected matches the above manual instructions. Might I have the following questions, please:
1. This CL57T drive has "higher than normal input current requirements"?
2. This is a single ended wiring?
3. To connect CL57T's PUL+ and DIR+ to 7I96S' +5V, can I join the two wires from PUL+ and DIR+ and screw the single end to 7I96S' +5V?
Thank you.
Thank you PWC for your helps. I appreciate it.7I96S CL57
+5V PUL+
STEP- PUL-
+5V DIR+
DIR- DIR-
SW3 Set for 5V mode
Thank you.
28 Jan 2025 02:48 #319973
1.
Yes (this appllies to most step motor drives with opto-coupler inputs)
2.
Yes.
3.
Yes, you can make a little loop at the drive.
(if you are good with a wire-stripper you can do this with a single piece of wire)
2.
Yes.
3.
- behai
29 Jan 2025 02:03 #320034
by behai
Thank you for your times and your kindness PCW. Best regards.1.
2.
Yes.
3.
- kello711
19 Dec 2025 03:28 #340297
by kello711
Replied by kello711 on topic 7i96S card arrived what setup is recomended
I have a similar setup I'm building. If I wanted to use the ENA and ALM as well as STEP/DIR, which position should the S3 switch be in 5V or 24V? I know the 7i96S provides 5V power for STEP/DIR but my field power is 24V. Can I do this or would I need to provide a separate 5V power source for my ENA/ALM signals?7I96S CL57
+5V PUL+
STEP- PUL-
+5V DIR+
DIR- DIR-
SW3 Set for 5V mode
19 Dec 2025 18:06 #340308
I would use all 5V signals for the step motor drive interface
and possibly 24V for limit switches .
The following user(s) said Thank You: kello711
- kello711
19 Dec 2025 19:53 #340315
by kello711
How does one go about mixing 24v limit switch inputs with the 5v ENA/ALM inputs?I would use all 5V signals for the step motor drive interface
19 Dec 2025 20:27 - 19 Dec 2025 20:29 #340316
You can mix 7I96/7I96S input voltages if the inputs are wired in sinking mode,
that is if the input common (TB3 pin 12) is wired to ground and the sources
(switches, alarm signals etc) supply a positive voltage relative to this ground,
in this case, the input will respond to positive voltages between 5V and 36V
so
Home/limit switch:
+24V --> SWITCH COM --> SWITCH NC --> 7I96S isolated input
5V alarm signal:
+5V alarm signal --> 7I96S isolated input
7I96/7i96S input common --> 24V GND and 5V GND
Note the the enable signal is a 7I96S output so can either be driven from a free step/dir output
or an isolated output
so
Home/limit switch:
5V alarm signal:
Last edit: 19 Dec 2025 20:29 by PCW.
- kello711
19 Dec 2025 20:42 #340317
by kello711
Yeah I realized what I said about ENA after I posted. Thanks for the clarification. So, should my prox sensors be NPN or PNP in this case? Crossing fingers for NPN.You can mix 7I96/7I96S input voltages if the inputs are wired in sinking mode,
so
Home/limit switch:
5V alarm signal:
Time to create page: 0.127 seconds
