7i96S card arrived what setup is recomended
- Samuelx
- Thank you received: 4
14 Jul 2022 18:07 #247309
by Samuelx
7i96S card arrived what setup is recomended was created by Samuelx
I have been 3 years away and try to start cnc hobby again.
Here is what I am planing to use
the machine I am retrofit is lathe Emco pc 50 turn
I have Dell optiflex 755 core2duo computer
I ordered some closed loop steppermotors to it.
Card is 7i96S
What version of linux to install?
What version of linuxcnc to install?
What els do I need to install:
Mesaflash ?
hostmot2?
And any links for good installation guides to those programs for newbie?
Card is 7i96S
Mesaflash ?
hostmot2?
The following user(s) said Thank You: behai
- Thank you received: 5334
14 Jul 2022 19:17 - 14 Jul 2022 19:18 #247313
Replied by PCW on topic 7i96S card arrived what setup is recomended
You need LinuxCNC 2.9 for full support of the 7I96S.
You do not need mesaflash unless you plan to use
a parallel expansion card which requires specific firmware.
For configuration utilities you can use pncconf and select 7I96
and the edit the created ini file to change the card name.
(from 7i96 to 7i96s)
(you need to select the ini card name substitution option).
Alternatively, you can use JT's mesact configuration tool.
Last edit: 14 Jul 2022 19:18 by PCW. Reason: sp
- Samuelx
14 Jul 2022 19:37 #247315
by Samuelx
Replied by Samuelx on topic 7i96S card arrived what setup is recomended
What is a good choice for linux.
ubuntu, mint, debian....
- JT
- Thank you received: 593
14 Jul 2022 21:26 #247323
by JT
Replied by JT on topic 7i96S card arrived what setup is recomended
I'd use www.linuxcnc.org/iso/linuxcnc-2.8.2-buster.iso
My Mesa Configuration tool.
gnipsel.com/mesa/mesact/index.html
No editing of the configuration files and you can open up the ini file after making changes to values and they are not lost.
JT
JT
The following user(s) said Thank You: Doug @ Design8Studio.com, behai
- Samuelx
18 Jul 2022 15:32 - 18 Jul 2022 20:10 #247698
by Samuelx
could not install mesact.
I installed mint 21 beta and linuxcnc 2.9. (forum.linuxcnc.org/9-installing-linuxcnc...n-linux-mint-21-beta)
Card is up and running
Is it possible to use Gmoccapy with mint 21 and linuxcnc 2.9 ?
Last edit: 18 Jul 2022 20:10 by Samuelx.
21 Jul 2022 18:05 #247973
Replied by andypugh on topic 7i96S card arrived what setup is recomended
It should be possible, though there might be complications with Python versions.Is it possible to use Gmoccapy with mint 21 and linuxcnc 2.9 ?
- JT
21 Jul 2022 20:39 #247989
by JT
- my1987toyota
- Thank you received: 448
22 Jul 2022 14:13 #248032
by my1987toyota
Replied by my1987toyota on topic 7i96S card arrived what setup is recomended
Correct me if I'm wrong but I thought anything Mint 20 forward was problematic at best. Hence the advice to stay with Debian O.S.'s
- JT
22 Jul 2022 14:32 #248037
by JT
I have LinuxMint 21 on this PC for the moment and the only issues I have so far is the menu is screwed up and you can't remove the generic kernel... enough reason for me to try Debian 11.4 and possibly change to unstable.
JT
JT
The following user(s) said Thank You: my1987toyota
- Samuelx
29 Jul 2022 16:59 - 29 Jul 2022 17:06 #248625
by Samuelx
If I want to connect my closed loop setepper motor encoders to linuxcnc, what kind on mesacard is good match with 7196s
Is this good option store.mesanet.com/index.php?route=produc...69_71&product_id=125
Last edit: 29 Jul 2022 17:06 by Samuelx.
Time to create page: 0.336 seconds
