- Thank you received: 4
It's alive!!!!That is all
With normal PWM 0=0% duty cycle and FS=100% duty cycle
With offset mode PWM 0=50% duty cycle, FS=100% duty cycle and -FS = 0% duty cycle
FS (Full Scale) being the PWM scale value
I did pncconf and found the serial part of the setup (never used it before)7i84 is a Smart Serial card, so no firmware required for it, it just works.
I have seen here the 7i96S + 7i85S firmware, probably is included in the downloads from www.mesanet.com , di you check?
Do a readhmid first, might be already on the 7i96S.
