7i96S card arrived what setup is recomended
4 years 2 months ago #250066 by xenon-alien
7i96s with stepgen indexes 0..4 on P1 HDR pins 1,2,3,4,5
(DB25 pins 1,14,2,15,3)
File Name: 7i96ssdid.zip
File Size:253.42 KB
Finally assembled the electric box and updated the fw.
Now I see the added stepgen index.
Can you write a simple example how to connect the *.hal file signals?
Or just enough to write
net index-x   =>  hm2_7i96s.0.stepgen.00.index-enable   => joint.0.index-enable
Can be the resistor 100 Om to protect the input? I have no 46 Om (or I can connect then in parallel and will got 50 Om)
Any news about
Can you do that for the 7i96 (pwm on 4th stepgen) too? (at home i have this card)
4 years 2 months ago - 4 years 2 months ago #250069 by xenon-alien
The index (hm2_7i96s.0.stepgen.00.index-enable) not blinks when i touch the GND, or the 5v on the 1 pin
Or will it active only when will run the homing procedure?
Tried the
sets index-enable-x 1
It's lights ON, after I touching the GND it's OFF.
Is it OK?
Last edit: 4 years 2 months ago by xenon-alien.
4 years 2 months ago #250073 by PCW
That's correct, if you set stepgen-index-enable, an index occurrence
will clear it (and clear the stepgen position)
100 Ohms is fine
The following user(s) said Thank You: xenon-alien
4 years 2 months ago #250693 by xenon-alien
I can do this here but in a day or so
Hello.
When will you have time to help me out with the bit file for 7i96 (pwm on 4 stepgen) + index for homing
4 years 2 months ago #250723 by PCW
File Name: 7i96_dstie1p.zip
File Size:112.93 KB
7I96 firmware with 1 PWM replacing stepgen4
and 4 stepgen index pins on the expansion port
4 years 1 month ago #251170 by xenon-alien
That's correct, if you set stepgen-index-enable, an index occurrencewill clear it (and clear the stepgen position)
100 Ohms is fine
It seems it's working. (loud sound)
Can you help me out with the turret feedback and spindle close-loop?
1) The turret drives a 3 ph 200W AC motor with 2 contactors (CW/CCW with classic-ladder, the algorithm is working).
When the contactor turns ON/OFF, the motor sends some "noise" to the 7i96s inputs (turning on by hands the contactor).
The 7i96s COM is the 24v Power Supply GND and the +24v goes to the Turret common, then they come back to the inputs from reed switch and a "turret closed" switch.
It looks like they needs to add for each input a pull-down resistor. (or may be something else...)
The cables comes out from the turret without any shielding. (24v signals and 3 ph AC 380v comes out parallel...)
(loud sound)
2) The Spindle Close-Loop
There is a simple 3 ph AC motor and inverter. They are connected and turning the Spindle CW/CCW.
The Lathe has 3 speeds. On the first speed when I command to turn 200 rpm (almost 1:1 ratio), it's turning with 275  ±2rpm.
The scaling not correct yet. I will do it soon.
Is it possible to use the Close-Loop to use all speeds automatically, without using any other hal component.
(the lathe config will upload on monday.)
Moderators: PCW, jmelson
Time to create page: 0.482 seconds
