- Thank you received: 4
Can you give me an example, how to do it?If you move very slowly so the index pulse is long enough to get sampled reliably by
the servo thread, you may be able to do this is hal
There is firmware that supports stepgen index pins
OkI don't have a ready made example, but stepgen index behaviour mimics
encoder index behaviour so has the same hal connections to the index
enable signal
Which firmware of them supports "stepgen index pinsW" and what pin to connect it on the card?There is firmware that supports stepgen index pinsW
I have only just this, 7i96s card with 7i96s_d.bin firmwareNo normal firmware supports this option.
Typically it would be used with an encoder
input card (that has a combined stepgen/encoder index pin)
What type of signal is the index from your hardware
