Mesa hm2/hm2_7i96s.0: error finishing read
4 years 1 month ago #252255 by JT
So in an attempt to recover from updating my Realtek drivers and losing the PCIe network card I tried to install Debian 11.4 and the screen went garbled...
Currently I'm not working on mesact until I get my dev PC back up and working so I can test configuration files on the 7i96S.
Burning Debian 11.5 to a SD card now with DD so I'll see in a while if I can install that and get back the PCIe network card.
JT
4 years 1 month ago #252403 by JT
The 5.19.0-1-rt-amd64 kernal does not fix the error finishing read issue.
JT
The following user(s) said Thank You: arvidb
4 years 1 month ago #252559 by rodw
JT
Thats kinda what PCW said. He found you need to go to the 6.0 kernel but it needs to be compiled. If you look over on kernel.org it is right on the bleeding edge (19 September). I did see it will become the 5.20 kernel somewhere but not sure about that. I'm not 100% sure how  kernel releases are managed....
mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/
4 years 1 month ago #252575 by PCW
Have you tried these (Intel only) kernel settings?
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=1 processor.max_cstate=1 idle=poll i915.enable_dc=0"
These seem to have helped on my Elite 800G1
4 years 4 weeks ago - 4 years 4 weeks ago #253298 by rodw
My test machine exhibits the latency issue on 5.18 kernels and not on 6.0 kernels
so something significant has changed (I have not tried 5.19 yet)
(plus I have tried most of the 5.x range)
Not sure if this will work but the 6.0 preempt_rt kernel is now in debian experimental. I have not tested but this but:
add the following to /etc/apt/sources.list
deb http://deb.debian.org/debian experimental main contrib non-free deb-src http://deb.debian.org/debian experimental main contrib non-free
then:
sudo apt update sudo apt install  linux-image-6.0.0-rc7-rt-amd64
reboot, hold breath and see if the network latency is resolved....
experimental only has the kernel packages in it
ref: packages.debian.org/experimental/kernel/
you might also need the linux-headers. After installing the image
sudo apt install linux-headers-$(uname -r)
Last edit: 4 years 4 weeks ago by rodw.
4 years 4 weeks ago #253299 by rodw
oops I forgot
sudo apt update
after edding sources.list
Moderators: PCW, jmelson
