Mesa hm2/hm2_7i96s.0: error finishing read
4 years 2 weeks ago - 4 years 2 weeks ago #254334 by PCW
"Error finishing read" means that too many successive timeouts have occurred
Default settings are: timeout means >80% of the servo period,
and 5 timeouts in a row result in a fatal I/O error: "error finishing read"
You can tune the controlling parameters:
hm2_7i96s.0.packet-read-timeout (default = 80%)
hm2_7i96s.0.packet-error-increment (default = 2)
hm2_7i96s.0.packet-error-decrement (default = 1)
hm2_7i96s.0.packet-error-limit (default=10)
Last edit: 4 years 2 weeks ago by PCW.
4 years 2 weeks ago #254342 by bensttech
many thanks, is the packet-error exposed to hal at all i was struggling to see it.
4 years 2 weeks ago - 4 years 2 weeks ago #254343 by PCW
Yes:
hm2_7i96s.0.packet-error-exceeded
hm2_7i96s.0.packet-error-level
Note that packet-error can be useful to prevent bogus velocity corrections
in the case of lost/dropped packets:
# position command and feedback
net emcmot.00.pos-cmd joint.0.motor-pos-cmd => pid.0.command mux2.0.in1
net stepgen0fb hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb mux2.0.in0
net motor.00.pos-fb <= mux2.0.out joint.0.motor-pos-fb pid.0.feedback
net motor.00.command pid.0.output hm2_[HOSTMOT2](BOARD).0.stepgen.00.velocity-cmd
net ioerror hm2_[HOSTMOT2](BOARD).0.packet-error mux2.0.sel
This hal section uses the packet error pin to select the commanded position
rather that the [stale] feedback position for loop feedback in the event of packet
loss
The following user(s) said Thank You: arvidb, tommylight, bensttech
4 years 2 weeks ago #254351 by bensttech
Ok so next steps? There are still to many variables to figure out if its kernel or linuxcnc its self.
Has anyone got 2.9 running a mesa Ethernet card 7i95 or 96 etc stably?
I looked at building 2.8 for deb-11 to see if its in CNC or the OS but i looks like this is not really possible.
I looked at getting the 4.19 series kernel in deb-11 and that is not easy either, would have to be a source config and build.
4 years 2 weeks ago #254355 by tommylight
The following user(s) said Thank You: arvidb, bensttech
4 years 2 weeks ago #254366 by PCW
Yes 4.19 is a better choice on most hardware but
5.10 and 6.0 work for me on my test CPU (HP Elite 800).
I dont think the LinuxCNC version is related as there have been no
significant upper level driver changes to hm2_eth for quite a while
( Though this reminds me that I should add and accumulated error count )
Moderators: PCW, jmelson
Time to create page: 0.432 seconds
