Mesa hm2/hm2_7i96s.0: error finishing read
1 year 8 months ago - 1 year 8 months ago #322677 by vre
Mine mesa ethernet card has interrupts on cpu0 how can move it to cpu3 isolated for linuxcnc ?
Last edit: 1 year 8 months ago by vre.
1 year 8 months ago #322688 by rodw
THere is a topic on the forum that explains but I am not logged in to link you to it. Its probably in this thread anyway.
1 year 8 months ago - 1 year 8 months ago #322703 by JT
Almost 3 years later and I still have hm2/hm2_7i96s.0:error finishing read!
Grub quiet isolcpus=11 idle=poll r8168.EEE=0 pcie_aspm=off
john@cave:~$ sudo ethtool -i enp6s0
[sudo] password for john:
driver: r8169
version: 6.1.0-29-rt-amd64
firmware-version: rtl8168e-3_0.0.4 03/27/12
expansion-rom-version:
bus-info: 0000:06:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
john@cave:~$ uname -a
Linux cave 6.1.0-29-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.123-1 (2025-01-02) x86_64 GNU/Linux
The r8168-dkms network driver is installed but ethtool reports the driver as r8169
This package provides the dkms source code for the r8168 kernel modules.
Kernel source or headers are required to compile these modules.
Is the above line from apt my clue?
JT
Last edit: 1 year 8 months ago by JT.
1 year 8 months ago #322707 by PCW
You can temporarily check if this helps:
File Name: pinirq_2025-02-26.txt
File Size:668 B
first
chmod +x pinirq.txt
then
sudo ./pinirq.txt [ethernet_device_name_]
Where [ethernet_device_name] is the name of the Ethernet device connected to the 7I96S
(probably eth0, eno1 enp0s25 or similar)
1 year 8 months ago - 1 year 8 months ago #322710 by PCW
The problem that is fixed by the DKMS driver has fairly specific symptoms.
can you run:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
 (will run for ~ 1 minute)
and post the stats here
(assuming 10.10.10.10 card address)
Last edit: 1 year 8 months ago by PCW.
1 year 8 months ago - 1 year 8 months ago #322755 by rodw
dkms builds the drivers from source so you need linux-headers installed for the kernel version you are using. but first you need to
sudo apt purge r8168-dkms
then reboot, then
sudo apt install linux-headers-$(uname -r)
sudo apt install r8168-dkms
Last edit: 1 year 8 months ago by rodw.
The following user(s) said Thank You: tivoi
Moderators: PCW, jmelson
Time to create page: 0.274 seconds
