Koike Aronson Plasma Conversion - sanity check on Mesa board selection?
28 Apr 2023 18:57 #270123 by brian_cant_code
I think my understanding of the encoder mapping was incorrect. I had it connected to the encoder plug on the 7i96s and couldn't get any readings off of it (I used a bench supply to simulate arc voltage). I switched it to the 7i77 encoder 2 and it works perfectly from there. Thanks for the assist!
  • Moderator
  • Moderator
28 Apr 2023 19:03 #270125 by tommylight
That can be changed in hal to any of the encoders.
28 Apr 2023 19:21 #270127 by PCW
Yes, to read the THCAD you need to:
1. Select the correct encoder
2. counter-mode for that encoder must be set to 1
For the rest to work the velocity pin of the selected encoder must be
connected to the appropriate qtplamac signal
  • Moderator
  • Moderator
28 Apr 2023 21:57 - 28 Apr 2023 21:59 #270138 by tommylight
Counter mode is set by PlasmaC/QtPlasmaC, so the only change required should be changing the encoder number.
And wiring ... :)
Edit,
To quick, encoder number must be changed also in the custom.hal file, i think that is where the encoder mode and some other stuff are.
Last edit: 28 Apr 2023 21:59 by tommylight. Reason: more info
28 Apr 2023 23:42 - 28 Apr 2023 23:44 #270146 by brian_cant_code
I tried encoder 6 and 7 via hal configuration (thinking that this would map to the encoder port on the 7i96s) and they showed -22 for the voltage. However, when I changed the hal mapping (and moved the plug) over to 7i77 encoder 2 everything worked appropriately. What I'm not sure about is if the encoder port on the 7i96s is active at all in the 7i96s+7i77 configuration.
edit: @tommylight: That's interesting, I don't have this setup in my custom.hal at all, just in my normal one
Last edit: 28 Apr 2023 23:44 by brian_cant_code.
29 Apr 2023 00:24 - 29 Apr 2023 00:27 #270153 by PCW
It looks like there was an error in the firmware, sorry...
( A typo in the pinout file gave the 7I96S encoder (6)
2 A inputs instead of A and B )
Here is fixed firmware:
File Name: 7i96s_7i77d.zip
File Size:301 KB
Last edit: 29 Apr 2023 00:27 by PCW. Reason: clarify
The following user(s) said Thank You: brian_cant_code
29 Apr 2023 00:38 #270154 by phillc54
And wiring ... :)
Edit,
Configs made with PNCconf  typically only have the debounce delays in custom.hal, almost everything else is in <machine_name>.hal
30 Apr 2023 02:46 #270280 by phillc54
Using PlasmaC or QtAxis PlasmaC or QtPlasmaC?
There is no QtAxis PlasmaC that I am aware of.
  • Moderator
  • Moderator
30 Apr 2023 10:04 - 29 Jan 2025 04:10 #270301 by tommylight
Ooopps...
Could not recal what the name was, still can't. :(
Last edit: 29 Jan 2025 04:10 by tommylight. Reason: formating
01 May 2023 01:25 #270363 by phillc54
If you are meaning this one , it is based on AXIS like the old PlasmaC, it is not a Qt GUI.
Moderators: PCW, jmelson
Time to create page: 0.121 seconds
