Koike Aronson Plasma Conversion - sanity check on Mesa board selection?
01 May 2023 07:48 #270389 by tommylight
Yes, that is it.
Thank you.
29 Jan 2025 03:29 #320039 by gwond
Hi all,
Looking to help a friend do the same thing as this thread, but with a 7i97T for the servos and a 7i78 card for the stepper for Z and THCAD2 for Arc Voltage.
I could use some help reviewing the hal and ini files to see if I'm on the right track.  I built a stepper machine before with a 7i96s and THCAD2, so have some experience with the setup using PNCCONF.  This is my first attempt at editing the ini and hal files directly.  I combined the basic 7i97 file, with the JT's configurator tool, and the plasma specific info from my 7i96s config.    My main question is how to correctly identify the board names in the files.  In the ini file it shows 7i97T as the board and 7i78 as the card, but I don't see how the 7i78 board gets translated to the hal file?  Ignore the scales, drive values, and pin assignments for most of the signals for now.
Also, the servos are Cleveland Motion Controls p/n MTE3528-508BG, does anyone know how to determine the encoder scale on these?  May just have to measure it once the system is configured.
29 Jan 2025 04:09 #320040 by tommylight
DRIVE = TB6600
The above should not be in the ini file, or it must be omitted by putting # in front of it.
We need more info on the drives/motors and general description of the machine.
Another thing wrong with the ini file is the PID values are all 1, they should all be 0 except P (start with 10 to 50) and FF1 (start with 1 and lower it as needed when tuning the drives).
You should really read this first and make sure the stuff checks OK before powering the machine as it might run the motors at full tilt if something in wiring or config is not OK
The following user(s) said Thank You: gwond
29 Jan 2025 12:48 #320079 by gwond
Thanks for the reply, I'll make those changes.  Most of the values are just placeholders for now, trying to get the overall structure of the files right and then will populate the specific values.   The machine is the same one as in this post, it has a servos on X and Y and a smart stepper motor from Animatics on the Z, which we may replace with a simple stepper driven by a TB6600 stepper motor driver.  The servo drives are from Advanced Motion Controls (BE15A8) www.a-m-c.com/product/be15a8/ and the drives are from Cleveland Motion Control MTE3528-508BG.   Also, thanks for posting the servo tuning link. I read through it a few times already and will definitely follow that when we get to that point.   In the files, how can I confirm that the stepper driver is getting assigned to the 7i78 vs the 7i97T?
29 Jan 2025 13:30 #320084 by RDA
If the DC motor still has the original encoder, then its 5V differential with 500ppr.
31 Jan 2025 13:34 #320227 by gwond
How does scale come into play for velocity mode servos?  I see multiple different Scale callouts between the .ini and the Hal files.
From JT's configurator tool, in the .ini there are these values which I currently have defined as:
Scale for drives = 10
Analog Scale Max = 10
Analog Min Limit = -10
Analog Max Limit = 10
Encoder Scale = -634.92 (this one I understand, although might need a double check on the value. Calculated based on 500 ppr with .7875" in per rev of servo)
In the main.hal file, I only see this line referencing SCALE, which I assume to be the scale for drives listed above.
setp hm2_7i97T.0.pwmgen.00.scale [JOINT_0] SCALE
I also have seen Output Scale referenced in other posts, is this the same as Analog Scale Max?
I set the PWM frequency to 75000 and enabled dither.
Thanks for the help
31 Jan 2025 15:28 #320235 by PCW
For analog velocity mode servos you can leave the scale at the default value/range (+-10V)
or you can set it so that the PID settings are all in engineering units. To do this, you set
the scale/range to the velocity in machine units per second your axis move at 10V.
This means that  now the PID output is scaled directly in velocity. This also means the FF1
value is known (1.00)
31 Jan 2025 17:55 #320245 by gwond
Thanks, that makes sense to me.  I think for now it makes sense to keep the PID values in voltage.  However, I'm still confused on the difference between Scale and Analog Scale Max.  Should the number be 10 for both if the PID is in voltage rather than velocity.
31 Jan 2025 17:59 - 31 Jan 2025 18:00 #320247 by PCW
You would need to look at the hal and ini files to see how those constants are used
(some may not even be used, as there's normally a lot of "boilerplate" in hal/ini files)
Last edit: 31 Jan 2025 18:00 by PCW.
18 Mar 2025 23:16 #324239 by gwond
Looking for some guidance on best practice for Servo Enable for the 12A8 servo drives.  The original control has an AC transformer that sends 50V AC to a PCB that contains a rectifier bridge for DC voltage, has the connectors for the motors and tach signals, an interface for the -10/+10V control signals, as well as 3 relays.  One relay for the inhibit circuit for each drive and one to connect the DC drive voltage to the servo drives.  However, all three relays are driven by one 12V control signal.  I was hoping to reuse the existing power supply and pcb and plan to interface with it via the Mesa 7i97T.    From what I've read though, you cannot have two output signals connected to one physical pin, for example X Servo and Y Servo enable both driven by X servo enable circuit.
Here are the options I'm considering:
1. Wire both enables from X and Y to the 12V relay, not sure if this would cause issues on the Mesa board if for some reason one servo was enabled and the other was not. Although, from reading the 7i97T manual, it seems like the enables are all switched in common?
2. Bypass the circuit board for enables and go straight to the drives with the enable circuit  (However, I would still need to enable the relay to connect drive power, so not sure which signal I could use for this.)  Perhaps I could make a new signal that would send 12V from the Mesa board if either of the X or Y drive enable commands are enabled, or route this to the estop switch and control it outside of the 7i97T.
3.  Any better ideas?
Moderators: PCW, jmelson
Time to create page: 0.630 seconds
