need help! mesa 7i95 connection problem
- Thank you received: 5330
23 Jun 2023 15:18 #274152
Replied by PCW on topic need help! mesa 7i95 connection problem
Bit difficult with a multimeter but if you email the card serial number
to Mesa they can send a replacement card.
- madjonr
23 Jun 2023 15:22 #274153
by madjonr
Ok! thank you very much!
You are a good man!
Replied by madjonr on topic need help! mesa 7i95 connection problem
You are a good man!
- timo
- Thank you received: 61
09 Feb 2025 15:46 - 09 Feb 2025 15:51 #321067
by timo
Replied by timo on topic need help! mesa 7i95 connection problem
I am facing a very similar situation. (almost identical to the above descriptions)
I had some issue with the Linux installation to do apt-get, so today I tried to install the latest ISO image new.
Then the Mesa card was not giving any response at all.
I tried lots of different things. Now in my desperation I tried to ping the card from a windows computer and the 4 green LEDs on the 7i95 start with some life signs) aa ping. 192.168.1.121 gives me responses.
Verdict: Probably some mishap with the networkadapter on the NUC PC.
Any advise how to narrow down the Ethernet problem on the Linux installation?
I can also change the card to 10.10.10.10 and ping it from the Windows machine.
My assumptions
My assumptions
- 7i95 card seems not to be damaged
- 5 V power seems O.K.
- the patch cable is not causing the issue
Last edit: 09 Feb 2025 15:51 by timo.
09 Feb 2025 17:52 #321073
First thing I would do is setup the LinuxCNC host computer with a static IP address of say 10.10.10.100
This is most reliably done by editing the interfaces file as described in the hm2_eth man page:
man hm2_eth
Then after rebooting (or setting the interface down and then up) verify that the host Ethernet device
is set to the 10.10.10.100 static IP address with:
ip a
Then set the FPGA card to a 10.10.10.10 IP address and cycle its power.
finally check that you can ping the card:
ping 10.10.10.10
man hm2_eth
ip a
ping 10.10.10.10
The following user(s) said Thank You: timo
- timo
09 Feb 2025 18:11 #321081
by timo
This is mysterious. After I had success with the windows PC I tried another harddrive with a Windows in the linux computer. I could ping the card from windows.
So the Ethernet adapter seemed to work.
Now I re-installed the Linux hard drive and suddenly it worked again. I did the static IP address 10.10.10.1 and set the jumpers down/up.
Only idea I have now that the network adapter was in some weird state and that it was re-set after disconnecting the power and re-booting.
ping times are about 0.5 ms
09 Feb 2025 18:22 #321084
Ping times of 0.5 ms are close to unusable
Do you have
hardware-irq-coalesce-rx-usecs 0
in the interfaces file?
This is needed if you have a Intel Ethernet interface chip
Do you have
- timo
10 Feb 2025 10:53 - 10 Feb 2025 10:56 #321152
by timo
i typed in "sudo apt-get install ethtool" in order to follow some things mentioned here
forum.linuxcnc.org/27-driver-boards/3868...rking-issues?start=0
Now if I type "sudo ethtool -c enp86s0"
I get a bunch of messages.
most items are marked n/a
rx-usecs: 0
tx-usecs: 0
I assume I switched off what you suggested.
The ping times went down from approx. 0.5 ms to 0.5 ms
"63 packets transmitted, 63 received, 0% packet loss, time 63476 ms
rtt min/avg/max/mdev = 0.185/0.455/0.577/0.05 ms"
I am not sure what the conclusion is.
p.s. that I get anything at all is a plus. From all packets lost to 0% is progress.
rx-usecs: 0
tx-usecs: 0
Last edit: 10 Feb 2025 10:56 by timo.
10 Feb 2025 15:18 #321163
Maybe you don't have a Intel MAC
lspci -nn | grep -i ethernet
Should list what you have.
Have you run a normal latency test?
- timo
10 Feb 2025 17:50 #321176
by timo
Hello,
sudo lspci -nn|grep -i ethernet delivers:
"Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V [8086:15f3] {rev 03}"
further trials did not result in much other than: again 1:45 am
I tried another mini PC that I bought really cheap. Some difficulties to install from USB stick. I am not sure why it refused to install "uefi files" at first. (yet again I "fixed it" by random clicks on different options). The Ethernet adapter on this cheap Mini (it worked yesterday with the now deleted Windows 11) is a Motorcomm YT6801. This Ethernet adapter was not detected during installation. I tried to get it running using this instruction.
github.com/dante1613/Motorcomm-YT6801/bl...20-%20instruction.md
I have the feeling, that I messed the installation up quite a bit, not knowing what I am doing...
The Motorcomm adaper showed (initial value for rx-usecs: 200), smallest value I could set with the ethtool (trying), was rx-usecs:3. The ping times seem to be influenced by that and went down from approx. below 0.5 ms to below 0.2 ms
Latency test in general I did not do these days.
Thank you for helping, so I am relieved that the 7i95 is still working.
- Nicotron
08 Sep 2025 19:54 #334649
by Nicotron
Replied by Nicotron on topic need help! mesa 7i95 connection problem
I have the same problem with Raspberry 5 and 7i95T everything works fine when i use 7i96S but when I connect the 7i95T no light in ETH connector the CR15 and CR16 flash. When I turn 5V up to 5.3V then the 7i95T work
Time to create page: 0.296 seconds
