need help! mesa 7i95 connection problem
- Thank you received: 5330
08 Sep 2025 20:01 #334650
Replied by PCW on topic need help! mesa 7i95 connection problem
Sounds like you have a 5V power issue
Either to low a power rating or too long or too thin
5V power wires.
The blinking LEDs indicate that the 7I95T is resetting
This indicates marginal 5V power. Note that the 7I95T draws
significantly more power than a 7I96S.
5V power wires.
- Nicotron
09 Sep 2025 19:13 #334727
by Nicotron
Replied by Nicotron on topic need help! mesa 7i95 connection problem
I use a bad power supply. I tested it with a laboratory power supply and it works fine with 5V now.
