- Thank you received: 17
i played with a few renishaw probes a while back - namely TP6, TP1s. yes, the resistance can be quite high and variable. but PI4 and MI8 interface units i had could reliably detected it. AFAIR, they supply 10 VDC at 0.5 mA to the probe. resistance less than about 3 kOhm considered as a seated probe.Up until it broke, the contact resistance was a bit variable (probably because of the lack of spring tension) but operated fine at 5v with the 'check if still open loop' able to detect closed at 0.5v. Now I've removed the chrome, my '3D printed special' shows similar characteristics.
That is a very nice probe. There's a lot of information on the Renishaw site here but predicatably no information at all the protocol. Reading the IR outputs from the probe would be fairly(!) trivial with an IR reader/oscilloscope/Arduino but without the OMM receiver, the IR inputs to the probe would be challenging to say the least.I have a renishaw omp60 but i don't have the wireless ir-receiver so it is useless.
Knows soneone the comunication ptotocol to impement a receiver or
if it is posible mod it and use it with wired connection?
