Probe Interface Board Design (resistance switching)
2 years 9 months ago #291441 by fletch
No, I have a Blum TC50 probe.  It uses IR to communicate, runs off a 9V battery, and takes fast pulses of IR to turn on/off, and then the probe output is very similar to what you describe.  But, it uses a short cone segment attached to the probe fitting, and that is pressed down on another code segment for centering.  Any deflection of the probe lifts the cone, and a rod breaks a laser beam.
This scheme removes the3-lobed pattern of sensitivity with the Renishaw balls and bars design.  Not that that pattern is anything I'd ever be aware of on my machine!
Jon
Ah, something like this? With the bar (or something poking out the top) to break the laser beam.
Makes a whole lot of sense if you can keep out anything that might set it askew. I don't think my machine would notice the pattern either!
2 years 9 months ago #291473 by jmelson
Jon
Yes, that is the concept.
Jon
2 years 9 months ago #292106 by fletch
The Mostly Printed Probe is now officially a side project...
2 years 8 months ago - 2 years 8 months ago #292255 by fletch
All the stl files are now on github: github.com/Stutchbury/MostlyPrintedProbe (there is a mag-safe version in the works).
I will write a print/build guide soon, but enough distraction for now, back to the interface board!
Last edit: 2 years 8 months ago by fletch. Reason: typo... grrr.
2 years 8 months ago #292413 by fletch
Well, someone had to try it out on a real CNC... Up until now I've been using a bench fixture & wedge to control the contacts & opening speed for the probe interface board.
www.youtube.com/shorts/06nPOA94Pbk
I am pleasantly surprised by its competence - I repeated the probe 4 time and was within 0.002mm each time. Yes, that's way beyond the limitations of my machine and yes, the plastic will likely move with temperature and humidity changes but hey, it's a Mostly 3D Printed Probe!
2 years 8 months ago #292429 by tommylight
That is impressive, for sure.
I have to remind myself to build one ... or 12 ! :)
Right after i finish my mill ... started gathering parts several years back...
The following user(s) said Thank You: fletch
Moderators: PCW, jmelson
Time to create page: 0.069 seconds
