Light Machine Corp. Benchman XTr (retrofit)
10 years 11 months ago #64846 by andypugh
steve_a wrote: Still, if the motors are rated for 24V, the 28.75V seems a reasonable number. The motor data sheet has two specs; the Rated Terminal Voltage 12-60V and the Terminal Voltage 24V.
It isn't at all unusual to run motors at a lot more than their DC voltage through a current-limiting drive.
This is especially true for steppers which have a typical DC voltage rating of <5 V but often run at 50V or more.
The voltage rating is the DC voltage that will drive the rated current, but if you limit the current then you can maintain that current (and torque) to much higher motor speeds with higher voltage.
10 years 11 months ago #64946 by steve_a
Did a quick test today on the servo power circuit. I didn't have what I needed to run 230VAC to the toroid so I settled for 120VAC from the wall since I had a cord handy. I got a strange jumping reading of 72-75V on the DC output from the toroid transformer and choke circuit, but that was unloaded so I decided to take a chance and plug it in to the main board and see if the controllers made a difference. Yep. Andypugh, looks like you were right. The wire in the toroid might just be a different gauge. I got a nice steady 32.8VDC. Assuming the 230 is roughly twice the voltage as the 120, that means I will probably get something in the range of 65.6VDC... essentially 60V. Which IS the upper limit of my Servo motors. SO having already been totally wrong once I think I will find a cord for 230VAC and verify the actual output of the circuit. Distribution to the controllers happens on the main PCB and I did not have time to do yet another isolation and verify that there is no further regulation happening there, so I will add that to the list of things to try.
10 years 11 months ago #65426 by wrightsh
I'm also working on a ProLight 5000 (non Benchman) and if you trace out the circuit on the board that the servo amps & power supply connect to there's two large caps and a power resistor in parallel going from the output of the choke to ground.
10 years 11 months ago #65434 by LearningLinuxCNC
Those are smoothing capacitors to take the ripple out of the rectified DC waveform. The resistor is a bleed resistor to slowly discharge the capacitors once the system is powered down, as they are storing a lot of energy. If they were to remain charged it could possibly hurt someone working on the dc power system.
10 years 11 months ago #65477 by steve_a
I've been busy with other projects but getting very antsy about this one. I looked at the controller boards today and saw a couple of good sized capacitors. There are two 3300uf and a couple of 4700uf. I'm going to assume that some of those are smoother caps for the servo motor drive and there was mention of bleeder resistors. They seem a little smallish but maybe, with a choke that size, that's all it needs. I suppose that makes sense.
Out of caution, I have not removed anything or disconnected the controller board that is underneath the board that looks like an interface for the encoders, air, etc. I was waiting until I received the replacement controller boards from Mesa. I must not have understood their availability or processes. I ordered the boards on October 21st so I'm still waiting 3 days shy of a month.
I've found a replacement controller board on line and bit the bullet. I know I will receive that on Monday so I can test my educated guess that the machine will come back to life using the old software and system. I still plan to do the upgrade but I need to try to have this thing up by January so I've kind of got my back to the wall. I am itching to get to this thing moving but without the new Mesa cards I'm stuck. On the plus side, if I CAN get it running I can test it and see what it SHOULD look like with the upgrade installed. I think I'll probably have to come up with some kind of PCB for things like the above mentioned caps and just interface in general.
The saga continues.
10 years 10 months ago - 10 years 10 months ago #66663 by steve_a
Well this is unfortunate... I have been waiting for the Mesa Cards for 6 weeks and while I accept the circumstances I don't have the time to waste if I just can't get the boards. Couple with that the possibility of a board crashing at some future date and a replacement taking another 6 weeks... I can't afford that. SO, unfortunately, I have canceled the order and decided to go to my fall back plan and use the Kflop and Kanalog boards. Yes I know that means an open loop system, but an open loop that works is better than a potential closed loop system that is dead in the water while I am waiting for a board.
I will chime in on the modifications since those will still be relevant to the Mesa/Linux systems. Truth be told, there is little difference in the two when it comes to the rewiring and if at some future date Mesa becomes more readily available it would just be a matter of swapping cards and I can have a closed loop system. I just have to set up the Linux CNC and I already have a computer loaded and ready to go. I had set it up in anticipation of the Mesa cards.
Anyway, I have some pretty good ideas for the rewire and I will share those as long as they are possibly relevant to the Linux system.
Last edit: 10 years 10 months ago by steve_a. Reason: misspelling
Time to create page: 0.278 seconds
