Brother TC-211
9 years 6 days ago #100842 by jmelson
Replied by jmelson on topic Brother TC-211
Are the servo motors already mounted on the machine? Replacing them with steppers + stepper drives will cost more than a couple hundred $. A 3-axis PWM system from Pico Systems, with brushless motor servo amps and the resolver converters will cost $1150. That will be all you need to get the 3 axes running. Not sure what you have for a spindle motor, but you may need some kind of VFD to run that.
Ah, with our PWM system, you will have a DRO function automatically. Just hit E-stop, and you can crank the motors and use the screen readout as a DRO.
Having designed several servo amplifiers, I can't recommend it unless you are a real electronics guru, there are many pitfalls, and you will end up popping a lot of power transistors and gate driver chips.
Jon
The following user(s) said Thank You: JohnW
9 years 5 days ago #100868 by JohnW
Replied by JohnW on topic Brother TC-211
Some really useful options there andypugh and jmelson thanks. All the motors came with the TC-211 but for some reason had been removed, the same for the spindle motor, and tool changer motor. Some good options there to mull over, thanks.
9 years 5 days ago #100882 by andypugh
Replied by andypugh on topic Brother TC-211
The original motors will have been carefully chosen through a time consuming engineering process by someone who knew exactly what they were doing.
I think it makes sense to keep them.
9 years 5 days ago #100886 by jmelson
JohnW wrote: Some really useful options there andypugh and jmelson thanks. All the motors came with the TC-211 but for some reason had been removed, the same for the spindle motor, and tool changer motor. Some good options there to mull over, thanks.
Removed, but you still have them, or removed and you DO NOT have them? makes a big difference!
Jon
9 years 5 days ago #100887 by jmelson
JohnW wrote: I bought one of these TC211's with the good intention of building a servo motor resolver interface. However, my partner wants to buy a crappy desk top CNC as I have taken so long now. I am thinking there are some NEMA 34, 3 axis stepper motor kits on ebay with parallel port control.
OK, I looked up some pictures of the TC211, and you are totally NUTS! That machine is WAY too big for steppers!
The X and Y might just handle it, but the entire Z axis is on vertical ways.. I don't know what it weighs, but it has to be a LOT!
You need a SERIOUS servo motor on that axis, at least.
Also note the TC211 is a TAPPING center, not a milling machine. So, the spindle is not up to the kind of side loads that are seen in heavier milling operations.
Jon
9 years 4 days ago #100957 by JohnW
I still have the motors. They need a good clean but turn smoothly (ie bearings are OK at least). X and Y are 100w 3.25kg/cm servo motors, Z is 200w 6.5kg/cm according to the original sales brochures for the machine. One thing I have noticed is that the ball spindle pitch on the machine seems more coarse that I would have expected. It all looks standard, and I wondered how they manage to meet the original precision spec of 0.01mm. What sort of angular positioning accuracy are the original (Toshiba?) resolvers likely to achieve? Yes, the Z axis is quite heavy! It has the original a 1.5KW servo spindle motor on it. I was thinking of a counter weight if I converted the machine to manual only.
With regard to side loads, I was more concerned with the actual vertical ways not being rigid enough for milling, or getting damaged from side loads. From pictures on the web the spindle tube appears about 6 or 7 inches long, with 4 ball bearing races, two at each end... The spec says the spindle motor is a 1.5KW Servo motor. Is it a servo because for the tapping operations, you need to synchronise the exact number of rotations with plunge depth for thread cutting?
Time to create page: 0.127 seconds
