If only 7i77d was available in Europe , I'll try to modify the relay board today. If not will go with adding the transistors to translate. Thanks
To add, I am amazed at the wiring masterpiece inside this Japan made machine, you literally can't move any wire. Wires are all wrapped, joined and cut to exact length. Finding which wire leads where is not possible with push pull method .
