Planning - Bridgeport Interact 1 linuxCNC Retrofit
10 years 10 months ago #66312 by andypugh
cncnoob1979 wrote: Maybe this will help someone else in the future. The issue I have is that I didn't think about the cables for this unit. So I asked if they came with the cables and have yet to receive a response. If the answer is no I will cancel the buy from ebay and purchase just 3 units for the same price but With cables.
www2.mouser.com/ProductDetail/Amphenol-S...2bLIux6K0kiVsIMCg%3d
But be aware that the cable back-shells and terminal pins are separate parts.
10 years 10 months ago #66317 by cncnoob1979
Well I canceled the order. No power cables or interface cables. By the time I bought and built all the cables I could have simply replaced the sinusoidal encoder with something more up-to-date. Such as the E5 Encoder from usdigital that passes quadrature TTL signals.
10 years 10 months ago #66320 by cncnoob1979
No eBay APP ID and/or Cert ID defined in Kunena configuration
The two main options for sinusoidal encoders are Heidenhain EXE boxes:
Or the development board from ICHaus.
www.ichaus.de/product/iC-MG
Andy,
How could I setup the development board from ICHaus?
The only information I have found so far looks to be just the ic, then I would have to build it using a bread board (or custom pcb) and socket from my limited understanding so far. I assume a solution has not already been built using this ic for my purpose?
What am I missing? - And if there is information available for this build, can you point me in the right area?
10 years 10 months ago #66321 by cncbasher
just for info , i'm currently designing a board specifc for these and linuxcnc for a client , although any machine will be able to use them , if you need anything , in fact iam hunting for a resolver for testing , at the moment .
10 years 10 months ago #66322 by cncnoob1979
cncbasher,
It looks like I may be able to help you out with that. The machine I plan to pick up this weekend currently has *I believe* the older sinusoidal encoder to use with the Heidenhain controller.
I could be your beta tester, or could possibly ship you my encoder for testing purposes.
Here is a picture of one servo that was rebuilt.
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/607F7B6C-704A-4532-AC50-D0831056EBDE_zpso80kuc4n.jpg
10 years 10 months ago #66323 by andypugh
cncnoob1979 wrote: By the time I bought and built all the cables I could have simply replaced the sinusoidal encoder with something more up-to-date.
The sinusoidal encoders, with the interpolation, can be very good.
Are you sure that it will be as easy as you think to swap the encoders, keeping in mind that you probably want to keep the tachometers?
Time to create page: 0.719 seconds
