cncnoob1979 wrote: The encoders will plug directly into the exe boxes but I'll have to get the output 12 pin male cannon plugs and pins.
cncnoob1979 wrote: Are these male contacts or are these female contacts? (PINS?) Or do I need to order the pins separately? I'm a bit confused by all the options.
cncnoob1979 wrote: I applied 24v to CR13 for the y axis (#85) enable and manually actuated CF5 to apply power to my Amps, then I used an AA battery for the command voltage (#45/#46) and it WORKS! :woohoo:
I'm still trying to figure out if I have a 24v power source going to the original control.
