Planning - Bridgeport Interact 1 linuxCNC Retrofit
10 years 10 months ago #66324 by andypugh
cncnoob1979 wrote: How could I setup the development board from ICHaus?
The only information I have found so far looks to be just the ic, then I would have to build it using a bread board (or custom pcb)
No, the development board is the chip pre-mounted on a PCB, with connectors.
www.ichaus.de/upload/pdf/Mg1d_a2es.pdf
10 years 10 months ago #66326 by andypugh
cncnoob1979 wrote: It looks like I may be able to help you out with that. The machine I plan to pick up this weekend currently has *I believe* the older sinusoidal encoder to use with the Heidenhain controller.
Counting wires might help. I think that a sinusoidal encoder will have 8 wires and a resolver will have 6.
(Also, a resolver will measure as 3 isolated resistors, probably 2 the same value and one the other)
10 years 10 months ago - 10 years 10 months ago #66336 by cncnoob1979
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationAndy,
No I dont think it will be easy to replace. Im hoping it will be :) Im not sure how Im going to tackle this particular problem until I tear into it I guess.
Any suggested reading you can advise with motors similar to mine that show the "guts" so I can get an idea how the tach and encoder fit together. I would assume the encoder is in the end plate and the tach is closer to the interior to allow me room to install another encoder.??
I have attached a picture under the wiring plate. (well the guy took the pic for me:) )
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/897E7EAF-9C0D-4209-B0E6-EDF0D9FCA1E8_zpsr53gohsy.jpg
How do I go about getting my hands on this developmental board in the USA? I'm assuming I would have to contact the company directly and try to get my hand on that board? iC-MG EVAL MG1D
EDIT: after being on IRC I now belive using the IDP101 solution for converting signals will be the best solution. I need to study up on this board.
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/s-l1600_zpse1ur9xew.jpg
Also using DIN mounted 12v Relays
image missing http://i346.photobucket.com/albums/p431/swill008/2015-11/s-l1600_zpsbtrip2tr.jpg
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Last edit: 10 years 10 months ago by cncnoob1979.
10 years 10 months ago - 10 years 10 months ago #66383 by andypugh
cncnoob1979 wrote: I would assume the encoder is in the end plate and the tach is closer to the interior to allow me room to install another encoder.??
Yes, I think that the thin red and black will be the tachometer output wires.
You know there is a fair chance that the other end of that encoder cable has a plug for the EXE units?
Mechanical relays? How quaint!
Last edit: 10 years 10 months ago by andypugh.
10 years 10 months ago #66401 by cncnoob1979
I do like the idea of solid state relays. I can push up to 300ma 10+- volts to activate the relay. I wonder if the solid state relays require more than that. I'll have to look into it.
10 years 10 months ago #66404 by andypugh
cncnoob1979 wrote: I can push up to 300ma 10+- volts to activate the relay. I wonder if the solid state relays require more than that. I'll have to look into it.
No, they need much, much less. I think you can operate them with TTL voltages, in fact.
Time to create page: 1.470 seconds
