Lagunmatic 3516-SX Retrofit
8 years 2 months ago #115711 by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
So here is my attempt so far to integrate the orient code into my HAL and INI files. My config is no longer loading, so I am also including my error message and dmesg.
hal:
# Generated by PNCconf at Fri Apr 27 02:57:57 2018 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx" setp hm2_5i25.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s loadrt pid num_chan=2 addf hm2_5i25.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf pid.0.do-pid-calcs servo-thread # Velocity addf pid.1.do-pid-calcs servo-thread # Position addf hm2_5i25.0.write servo-thread loadrt orient addf orient.0 servo-thread loadrt mux2 addf mux2.0 servo-thread # chooses which pid output goes to the spindle speed control loadrt near count=1 loadrt edge addf near.0 servo-thread addf edge.0 servo-thread setp edge.0.both 0 setp edge.0.in-edge 0 setp edge.0.out-width-ns 10000000 ###################################### # external output signals ###################################### # --- MACHINE-IS-ENABLED --- net machine-is-enabled hm2_5i25.0.7i77.0.0.output-00 # --- MAGAZINE_FORWARD --- net Magazine_Forward hm2_5i25.0.7i77.0.0.output-01 # --- MAGAZINE_DOWN --- net Magazine_Down hm2_5i25.0.7i77.0.0.output-02 # --- MAGAZINE_CW --- net Magazine_CW hm2_5i25.0.7i77.0.0.output-03 # --- MAGAZINE_CCW --- net Magazine_CCW hm2_5i25.0.7i77.0.0.output-04 # --- SPINDLE_ORIENT --- net Spindle_Orient hm2_5i25.0.7i77.0.0.output-05 # --- SPINDLE-CW --- net spindle-cw hm2_5i25.0.7i77.0.0.output-06 # --- TOOL_UNCLAMP --- net Tool_Unclamp hm2_5i25.0.7i77.0.0.output-07 # --- COOLANT-MIST --- #net coolant-mist hm2_5i25.0.7i77.0.0.output-08 # --- LUBE_RELAY --- net Lube_Relay hm2_5i25.0.7i77.0.0.output-10 # --- SOFT_START_CANCEL --- net Soft_Start_Cancel hm2_5i25.0.7i77.0.0.output-11 ###################################### # external input signals ###################################### # --- WAY_LUBE_LEVEL --- net Way_Lube_Level <= hm2_5i25.0.7i77.0.0.input-00 # --- MAX-X --- net max-x <= hm2_5i25.0.7i77.0.0.input-01-not # --- MIN-X --- net min-x <= hm2_5i25.0.7i77.0.0.input-02-not # --- MAX-Y --- net max-y <= hm2_5i25.0.7i77.0.0.input-03-not # --- MIN-Y --- net min-y <= hm2_5i25.0.7i77.0.0.input-04-not # --- MAX-Z --- net max-z <= hm2_5i25.0.7i77.0.0.input-05-not # --- MIN-Z --- net min-z <= hm2_5i25.0.7i77.0.0.input-06-not # --- HOME-X --- net home-x <= hm2_5i25.0.7i77.0.0.input-07 # --- HOME-Y --- net home-y <= hm2_5i25.0.7i77.0.0.input-08 # --- HOME-Z --- net home-z <= hm2_5i25.0.7i77.0.0.input-09 # --- MAGAZINE_BACK_POSITION --- net Magazine_Back_Position <= hm2_5i25.0.7i77.0.0.input-10 # --- MAGAZINE_FORWARD_POSITION --- net Magazine_Forward_Position <= hm2_5i25.0.7i77.0.0.input-11 # --- MAGAZINE_UP_POSITION --- net Magazine_Up_Position <= hm2_5i25.0.7i77.0.0.input-12 # --- MAGAZINE_DOWN_POSITION --- net Magazine_Down_Position <= hm2_5i25.0.7i77.0.0.input-13 # --- POSITION_COUNTER --- net Position_Counter <= hm2_5i25.0.7i77.0.0.input-14 # --- MAGAZINE_HOME --- net Magazine_Home <= hm2_5i25.0.7i77.0.0.input-15 # --- TOOL_CLAMP_POSITION --- #net Tool_Clamp_Position <= hm2_5i25.0.7i77.0.0.input-16 # --- TOOL_UNCLAMP_POSITION --- #net Tool_Unclamp_Position <= hm2_5i25.0.7i77.0.0.input-17 # --- SPINDLE_UP_TO_SPEED --- net Spindle_Up_To_Speed <= hm2_5i25.0.7i77.0.0.input-18 # --- ESTOP --- net ESTOP <= hm2_5i25.0.7i77.0.0.input-19 # --- SPINDLE_ORIENT_COMPLETE --- net Spindle_Orient_Complete <= hm2_5i25.0.7i77.0.0.input-20 # --- LUBE_PRESSURE_SWITCH --- net Lube_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-21-not # --- AIR_PRESSURE_SWITCH --- net Air_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-22 # --- MACHINE_ON_CMD --- net Machine_On_CMD <= hm2_5i25.0.7i77.0.0.input-23 # --- SPINDLE_ON_CMD --- net Spindle_On_CMD <= hm2_5i25.0.7i77.0.0.input-24 # --- TOOL_UNCLAMP_CMD --- net Tool_Unclamp_CMD <= hm2_5i25.0.7i77.0.0.input-25 # --- MIST_ON_CMD --- net Mist_On_CMD <= hm2_5i25.0.7i77.0.0.input-26 # --- MAGAZINE_CW_CMD --- net Magazine_CW_CMD <= hm2_5i25.0.7i77.0.0.input-27 # --- MAGAZINE_CCW_CMD --- net Magazine_CCW_CMD <= hm2_5i25.0.7i77.0.0.input-28 #******************* # AXIS X #******************* setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd axis.0.motor-pos-cmd net x-enable axis.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => axis.0.motor-pos-fb net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts # ---setup home / limit switch signals--- net home-x => axis.0.home-sw-in net min-x => axis.0.neg-lim-sw-in net max-x => axis.0.pos-lim-sw-in #******************* # AXIS Y #******************* setp pid.y.Pgain [AXIS_1]P setp pid.y.Igain [AXIS_1]I setp pid.y.Dgain [AXIS_1]D setp pid.y.bias [AXIS_1]BIAS setp pid.y.FF0 [AXIS_1]FF0 setp pid.y.FF1 [AXIS_1]FF1 setp pid.y.FF2 [AXIS_1]FF2 setp pid.y.deadband [AXIS_1]DEADBAND setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT setp pid.y.error-previous-target true net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-vel-cmd => pid.y.command-deriv net y-pos-fb => pid.y.feedback net y-output => pid.y.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT net y-output => hm2_5i25.0.7i77.0.1.analogout1 net y-pos-cmd axis.1.motor-pos-cmd net y-enable axis.1.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.01.counter-mode 0 setp hm2_5i25.0.encoder.01.filter 1 setp hm2_5i25.0.encoder.01.index-invert 0 setp hm2_5i25.0.encoder.01.index-mask 0 setp hm2_5i25.0.encoder.01.index-mask-invert 0 setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE net y-pos-fb <= hm2_5i25.0.encoder.01.position net y-vel-fb <= hm2_5i25.0.encoder.01.velocity net y-pos-fb => axis.1.motor-pos-fb net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts # ---setup home / limit switch signals--- net home-y => axis.1.home-sw-in net min-y => axis.1.neg-lim-sw-in net max-y => axis.1.pos-lim-sw-in #******************* # AXIS Z #******************* setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT net z-output => hm2_5i25.0.7i77.0.1.analogout2 net z-pos-cmd axis.2.motor-pos-cmd net z-enable axis.2.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.02.counter-mode 0 setp hm2_5i25.0.encoder.02.filter 1 setp hm2_5i25.0.encoder.02.index-invert 0 setp hm2_5i25.0.encoder.02.index-mask 0 setp hm2_5i25.0.encoder.02.index-mask-invert 0 setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE net z-pos-fb <= hm2_5i25.0.encoder.02.position net z-vel-fb <= hm2_5i25.0.encoder.02.velocity net z-pos-fb => axis.2.motor-pos-fb net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts # ---setup home / limit switch signals--- net home-z => axis.2.home-sw-in net min-z => axis.2.neg-lim-sw-in net max-z => axis.2.pos-lim-sw-in #******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE]P setp pid.s.Igain [SPINDLE]I setp pid.s.Dgain [SPINDLE]D setp pid.s.bias [SPINDLE]BIAS setp pid.s.FF0 [SPINDLE]FF0 setp pid.s.FF1 [SPINDLE]FF1 setp pid.s.FF2 [SPINDLE]FF2 setp pid.s.deadband [SPINDLE]DEADBAND setp pid.s.maxoutput [SPINDLE]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command net spindle-vel-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE]OUTPUT_MAX_LIMIT net spindle-output => hm2_5i25.0.7i77.0.1.analogout5 net spindle-enable => hm2_5i25.0.7i77.0.1.spinena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.05.counter-mode 0 setp hm2_5i25.0.encoder.05.filter 1 setp hm2_5i25.0.encoder.05.index-invert 0 setp hm2_5i25.0.encoder.05.index-mask 0 setp hm2_5i25.0.encoder.05.index-mask-invert 0 setp hm2_5i25.0.encoder.05.scale [SPINDLE]ENCODER_SCALE net spindle-revs <= hm2_5i25.0.encoder.05.position net spindle-vel-fb-rps <= hm2_5i25.0.encoder.05.velocity net spindle-index-enable <=> hm2_5i25.0.encoder.05.index-enable ##### net spindle-pos pid.1.feedback orient.0.position net spindle-vel pid.0.feedback hm2_5i25.0.encoder.05.velocity net spindle-vel-cmd motion.spindle-speed-out pid.0.command net spindle-vel-pid pid.0.output mux2.0.in0 net spindle-pos pid.1.feedback orient.0.position near.0.in1 hm2_5i25.0.encoder.05.position net spindle-pos-cmd orient.0.command pid.1.command near.0.in2 net spindle-angle motion.spindle-orient-angle orient.0.angle net spindle-pos-pid pid.1.output mux2.0.in1 setp near.0.difference 0.0005 net spindle-in-pos-raw near.0.out edge.0.in #not needed v2.8+, use orient.0.is-oriented net spindle-in-pos edge.0.out motion.spindle-is-oriented # this switches modes net orient-mode motion.spindle-orient orient.0.enable pid.1.enable mux2.0.sel net velocity-mode motion.spindle-on pid.0.enable pwmgen.0.enable net orient-dir motion.spindle-orient-mode orient.0.mode loadrt abs addf abs.0.servo-thread net spindle-cmd mux2.0.out abs.0.in net spindle-cmd-abs abs.0.out pwmgen.0.value net spindle-pwm pwmgen.0.pwm hm2_5i25.0.7i77.0.1.analogout5 net spindle-fwd abs.0.is-positive hm2_5i25.0.7i77.0.1.analogout5 net spindle-rev abs.0.is-negative hm2_5i25.0.7i77.0.1.analogout5 # Tune the PID from the INI values setp pid.0.Pgain [SPINDLE]PGAIN_V setp pid.0.Igain [SPINDLE]IGAIN_V setp pid.0.Dgain [SPINDLE]DGAIN_V setp pid.0.FF0 [SPINDLE]FF0_V setp pid.0.FF1 [SPINDLE]FF1_V setp pid.1.Pgain [SPINDLE]PGAIN_P setp pid.1.Igain [SPINDLE]IGAIN_P setp pid.1.Dgain [SPINDLE]DGAIN_P setp pid.1.FF0 [SPINDLE]FF0_P setp pid.1.FF1 [SPINDLE]FF1_P ##### # ---setup spindle control signals--- #net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps #net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs #net spindle-vel-cmd-rpm <= motion.spindle-speed-out #net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs #net spindle-enable <= motion.spindle-on #net spindle-cw <= motion.spindle-forward #net spindle-ccw <= motion.spindle-reverse #net spindle-brake <= motion.spindle-brake #net spindle-revs => motion.spindle-revs #net spindle-at-speed => motion.spindle-at-speed #net spindle-vel-fb-rps => motion.spindle-speed-in #net spindle-index-enable <=> motion.spindle-index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-pos halui.jog.0.plus net jog-x-neg halui.jog.0.minus net jog-x-analog halui.jog.0.analog net joint-select-b halui.joint.1.select net y-is-homed halui.joint.1.is-homed net jog-y-pos halui.jog.1.plus net jog-y-neg halui.jog.1.minus net jog-y-analog halui.jog.1.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-pos halui.jog.2.plus net jog-z-neg halui.jog.2.minus net jog-z-analog halui.jog.2.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net jog-speed halui.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in
ini:
# Generated by PNCconf at Fri Apr 27 02:57:57 2018 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = Lagunmatic_3516-SX DEBUG = 0 [DISPLAY] DISPLAY = axis #DISPLAY = gmoccapy POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 2.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/treid/linuxcnc/nc_files PYVCP = pyvcp-panel.xml INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 1.000000 MAX_LINEAR_VELOCITY = 2.500000 MIN_LINEAR_VELOCITY = 0.000167 DEFAULT_ANGULAR_VELOCITY = 6.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyz [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 1000000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 [HAL] HALUI = halui HALFILE = Lagunmatic_3516-SX.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 0.20 MAX_LINEAR_VELOCITY = 2.00 NO_FORCE_HOMING = 1 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl TOOL_CHANGE_QUILL_UP = 1 #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 105.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.259 FF2 = 0.006 BIAS = 0.0 DEADBAND = 0.0001 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -0.001 MAX_LIMIT = 26.4 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 1 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 30.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 0.08 FF2 = 0.0005 BIAS = 0.0001 DEADBAND = 0.0 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -0.001 MAX_LIMIT = 16.0 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 2 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 60.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 0.91 FF2 = 0.005 BIAS = 0.0 DEADBAND = 0.0001 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -20.5 MAX_LIMIT = 0.05 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = 1.000000 HOME_LATCH_VEL = 0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 0 #******************** # Spindle #******************** [SPINDLE] P = 2.0 I = 0.0 D = 0.0 FF0 = 1.0 FF1 = 0.0 FF2 = 0.0 PGAIN_V = 0 IGAIN_V = 0.01 DGAIN_V = 0 FF0_V = 1 FF1_V = 0 PGAIN_P = 100 IGAIN_P = 1 DGAIN_P = 0 FF0_P = 0 FF1_P =1 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 10000.0 ENCODER_SCALE = -4096.0 OUTPUT_SCALE = 10000 OUTPUT_MIN_LIMIT = -10000 OUTPUT_MAX_LIMIT = 10000
Config loading error:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.12 Machine configuration directory is '/home/treid/linuxcnc/configs/Lagunmatic_3516-SX' Machine configuration file is 'Lagunmatic_3516-SX.ini' INIFILE=/home/treid/linuxcnc/configs/Lagunmatic_3516-SX/Lagunmatic_3516-SX.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./Lagunmatic_3516-SX.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=5532 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: . Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/pid.ko: File exists ./Lagunmatic_3516-SX.hal:12: exit value: 1 ./Lagunmatic_3516-SX.hal:12: insmod for pid failed, returned -1 See the output of 'dmesg' for more information. 5532 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000008d800 (usable) [ 0.000000] BIOS-e820: 000000000008d800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable) [ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved) [ 0.000000] BIOS-e820: 0000000020100000 - 000000007972b000 (usable) [ 0.000000] BIOS-e820: 000000007972b000 - 000000007975b000 (reserved) [ 0.000000] BIOS-e820: 000000007975b000 - 000000007976b000 (ACPI data) [ 0.000000] BIOS-e820: 000000007976b000 - 000000007989f000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000007989f000 - 0000000079ba0000 (reserved) [ 0.000000] BIOS-e820: 0000000079ba0000 - 0000000079ba1000 (usable) [ 0.000000] BIOS-e820: 0000000079ba1000 - 0000000079be3000 (reserved) [ 0.000000] BIOS-e820: 0000000079be3000 - 0000000079d53000 (usable) [ 0.000000] BIOS-e820: 0000000079d53000 - 0000000079ffa000 (reserved) [ 0.000000] BIOS-e820: 0000000079ffa000 - 000000007a000000 (usable) [ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved) [ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved) [ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel! [ 0.000000] SMBIOS 2.8 present. [ 0.000000] DMI: Gigabyte Technology Co., Ltd. To be filled by O.E.M./J1900N-D3V, BIOS F2 03/06/2014 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x7a000 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-E7FFF write-through [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 base 07A000000 mask FFE000000 uncachable [ 0.000000] 2 base 07C000000 mask FFC000000 uncachable [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00fd710] fd710 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c0089000] 89000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 3652c000 - 3728e000 [ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA) [ 0.000000] ACPI: XSDT 7975e078 00074 (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FACP 79769518 0010C (v05 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: DSDT 7975e180 0B392 (v02 ALASKA A M I 01072009 INTL 20120913) [ 0.000000] ACPI: FACS 7989ef80 00040 [ 0.000000] ACPI: APIC 79769628 00084 (v03 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FPDT 797696b0 00044 (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: MCFG 797696f8 0003C (v01 ALASKA A M I 01072009 MSFT 00000097) [ 0.000000] ACPI: LPIT 79769738 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D) [ 0.000000] ACPI: HPET 79769840 00038 (v01 ALASKA A M I 01072009 AMI. 00000005) [ 0.000000] ACPI: SSDT 79769878 00763 (v01 PmRef CpuPm 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT 79769fe0 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT 7976a270 0017A (v01 PmRef ApTst 00003000 INTL 20061109) [ 0.000000] ACPI: UEFI 7976a3f0 00042 (v01 ALASKA A M I 00000000 00000000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 1064MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x0007a000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000008d [ 0.000000] 0: 0x00000100 -> 0x00020000 [ 0.000000] 0: 0x00020100 -> 0x0007972b [ 0.000000] 0: 0x00079ba0 -> 0x00079ba1 [ 0.000000] 0: 0x00079be3 -> 0x00079d53 [ 0.000000] 0: 0x00079ffa -> 0x0007a000 [ 0.000000] On node 0 totalpages: 497439 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f55ec200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3933 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221230 pages, LIFO batch:31 [ 0.000000] HighMem zone: 2129 pages used for memmap [ 0.000000] HighMem zone: 268371 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x0]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x0]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x0]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] dfl dfl lint[0x0]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 103 [ 0.000000] PM: Registered nosave memory: 000000000008d000 - 000000000008e000 [ 0.000000] PM: Registered nosave memory: 000000000008e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000 [ 0.000000] Allocating PCI resources starting at 7a000000 (gap: 7a000000:660f8000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 493534 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=b51de77a-84fb-4d58-b87c-bae0ab3eabab ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 3997568 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:0007a000) [ 0.000000] Memory: 1949548k/1998848k available (3495k kernel code, 40208k reserved, 1237k data, 416k init, 1082000k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:1024 16 [ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000 [ 0.000000] Extended CMOS year: 2000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration failed [ 0.008000] TSC: PIT calibration matches HPET. 1 loops [ 0.008000] Detected 1999.990 MHz processor. [ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3999.98 BogoMIPS (lpj=7999960) [ 0.000010] pid_max: default: 32768 minimum: 301 [ 0.000091] Security Framework initialized [ 0.000098] AppArmor: AppArmor disabled by boot time parameter [ 0.000130] Mount-cache hash table entries: 512 [ 0.000421] Initializing cgroup subsys cpuacct [ 0.000426] Initializing cgroup subsys memory [ 0.000439] Initializing cgroup subsys devices [ 0.000443] Initializing cgroup subsys freezer [ 0.000447] Initializing cgroup subsys net_cls [ 0.000450] Initializing cgroup subsys blkio [ 0.000461] Initializing cgroup subsys perf_event [ 0.000501] CPU: Physical Processor ID: 0 [ 0.000505] CPU: Processor Core ID: 0 [ 0.000511] ENERGY_PERF_BIAS: Set to 'normal', was 'performance' [ 0.000512] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8) [ 0.010419] mce: CPU supports 6 MCE banks [ 0.010430] CPU0: Thermal monitoring enabled (TM1) [ 0.010521] ACPI: Core revision 20120320 [ 0.029038] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.029763] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0 [ 0.069455] CPU0: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz stepping 03 [ 0.177461] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver. [ 0.177475] ... version: 3 [ 0.177478] ... bit width: 40 [ 0.177481] ... generic registers: 2 [ 0.177485] ... value mask: 000000ffffffffff [ 0.177489] ... max period: 000000007fffffff [ 0.177492] ... fixed-purpose events: 3 [ 0.177495] ... event mask: 0000000700000003 [ 0.189559] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.201497] CPU 1 irqstacks, hard=f50f2000 soft=f50f4000 [ 0.201502] Booting Node 0, Processors #1 [ 0.211547] Initializing CPU#1 [ 0.224072] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.229504] CPU 2 irqstacks, hard=f5104000 soft=f5106000 [ 0.229509] #2 [ 0.239466] Initializing CPU#2 [ 0.252064] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.257497] CPU 3 irqstacks, hard=f5116000 soft=f5118000 [ 0.257502] #3 Ok. [ 0.267460] Initializing CPU#3 [ 0.280056] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.280116] Brought up 4 CPUs [ 0.280121] Total of 4 processors activated (15999.92 BogoMIPS). [ 0.280993] devtmpfs: initialized [ 0.281423] PM: Registering ACPI NVS region [mem 0x7976b000-0x7989efff] (1261568 bytes) [ 0.281707] dummy: [ 0.281817] NET: Registered protocol family 16 [ 0.282029] ACPI: bus type pci registered [ 0.282133] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.282140] PCI: not using MMCONFIG [ 0.282581] PCI: Using configuration type 1 for base access [ 0.283867] bio: create slab <bio-0> at 0 [ 0.284063] ACPI: Added _OSI(Module Device) [ 0.284073] ACPI: Added _OSI(Processor Device) [ 0.284078] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.284084] ACPI: Added _OSI(Processor Aggregator Device) [ 0.290076] ACPI: EC: Look up EC in DSDT [ 0.309135] ACPI: SSDT 79753c18 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109) [ 0.310659] ACPI: Dynamic OEM Table Load: [ 0.310667] ACPI: SSDT (null) 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109) [ 0.310997] ACPI: SSDT 79752918 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109) [ 0.312488] ACPI: Dynamic OEM Table Load: [ 0.312496] ACPI: SSDT (null) 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109) [ 0.313336] ACPI: SSDT 79754e18 0015F (v01 PmRef ApIst 00003000 INTL 20061109) [ 0.314924] ACPI: Dynamic OEM Table Load: [ 0.314932] ACPI: SSDT (null) 0015F (v01 PmRef ApIst 00003000 INTL 20061109) [ 0.315261] ACPI: SSDT 79755f18 0008D (v01 PmRef ApCst 00003000 INTL 20061109) [ 0.316782] ACPI: Dynamic OEM Table Load: [ 0.316790] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20061109) [ 0.319459] ACPI: Interpreter enabled [ 0.319481] ACPI: (supports S0 S3 S4 S5) [ 0.319536] ACPI: Using IOAPIC for interrupt routing [ 0.319587] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.322020] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources [ 0.322025] PCI: Using MMCONFIG for extended config space [ 0.334378] ACPI: Power Resource [USBC] (on) [ 0.336836] ACPI: Power Resource [FN00] (off) [ 0.338264] ACPI: No dock devices found. [ 0.338277] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.338830] \_SB_.PCI0:_OSC invalid UUID [ 0.338835] _OSC request data:1 8 0 [ 0.338847] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.339491] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f] [ 0.339498] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7] [ 0.339503] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.339508] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.339513] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] [ 0.339518] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff] [ 0.339524] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xd0916ffe] [ 0.339589] PCI host bridge to bus 0000:00 [ 0.339595] pci_bus 0000:00: root bus resource [io 0x0000-0x006f] [ 0.339600] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7] [ 0.339606] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.339611] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.339616] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff] [ 0.339621] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff] [ 0.339626] pci_bus 0000:00: root bus resource [mem 0x80000000-0xd0916ffe] [ 0.339641] pci 0000:00:00.0: [8086:0f00] type 00 class 0x060000 [ 0.339703] pci 0000:00:02.0: [8086:0f31] type 00 class 0x030000 [ 0.339723] pci 0000:00:02.0: reg 10: [mem 0xd0000000-0xd03fffff] [ 0.339740] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff pref] [ 0.339756] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087] [ 0.339831] pci 0000:00:13.0: [8086:0f23] type 00 class 0x010601 [ 0.339857] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077] [ 0.339870] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063] [ 0.339884] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057] [ 0.339897] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043] [ 0.339910] pci 0000:00:13.0: reg 20: [io 0xf020-0xf03f] [ 0.339924] pci 0000:00:13.0: reg 24: [mem 0xd0916000-0xd09167ff] [ 0.339967] pci 0000:00:13.0: PME# supported from D3hot [ 0.340000] pci 0000:00:14.0: [8086:0f35] type 00 class 0x0c0330 [ 0.340026] pci 0000:00:14.0: reg 10: [mem 0xd0900000-0xd090ffff 64bit] [ 0.340088] pci 0000:00:14.0: PME# supported from D3hot D3cold [ 0.340126] pci 0000:00:1a.0: [8086:0f18] type 00 class 0x108000 [ 0.340158] pci 0000:00:1a.0: reg 10: [mem 0xd0500000-0xd05fffff] [ 0.340175] pci 0000:00:1a.0: reg 14: [mem 0xd0400000-0xd04fffff] [ 0.340272] pci 0000:00:1a.0: PME# supported from D0 D3hot [ 0.340308] pci 0000:00:1b.0: [8086:0f04] type 00 class 0x040300 [ 0.340337] pci 0000:00:1b.0: reg 10: [mem 0xd0910000-0xd0913fff 64bit] [ 0.340409] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.340435] pci 0000:00:1c.0: [8086:0f48] type 01 class 0x060400 [ 0.340498] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.340530] pci 0000:00:1c.1: [8086:0f4a] type 01 class 0x060400 [ 0.340592] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.340621] pci 0000:00:1c.2: [8086:0f4c] type 01 class 0x060400 [ 0.340683] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.340714] pci 0000:00:1c.3: [8086:0f4e] type 01 class 0x060400 [ 0.340776] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 0.340819] pci 0000:00:1d.0: [8086:0f34] type 00 class 0x0c0320 [ 0.340853] pci 0000:00:1d.0: reg 10: [mem 0xd0915000-0xd09153ff] [ 0.340966] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.341001] pci 0000:00:1f.0: [8086:0f1c] type 00 class 0x060100 [ 0.341109] pci 0000:00:1f.3: [8086:0f12] type 00 class 0x0c0500 [ 0.341149] pci 0000:00:1f.3: reg 10: [mem 0xd0914000-0xd091401f] [ 0.341229] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f] [ 0.341387] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000 [ 0.341409] pci 0000:01:00.0: reg 10: [io 0xe000-0xe0ff] [ 0.341443] pci 0000:01:00.0: reg 18: [mem 0xd0804000-0xd0804fff 64bit] [ 0.341477] pci 0000:01:00.0: reg 20: [mem 0xd0800000-0xd0803fff 64bit pref] [ 0.341535] pci 0000:01:00.0: supports D1 D2 [ 0.341539] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.349475] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.349483] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.349490] pci 0000:00:1c.0: bridge window [mem 0xd0800000-0xd08fffff] [ 0.349561] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000 [ 0.349584] pci 0000:02:00.0: reg 10: [io 0xd000-0xd0ff] [ 0.349618] pci 0000:02:00.0: reg 18: [mem 0xd0704000-0xd0704fff 64bit] [ 0.349641] pci 0000:02:00.0: reg 20: [mem 0xd0700000-0xd0703fff 64bit pref] [ 0.349699] pci 0000:02:00.0: supports D1 D2 [ 0.349704] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.357473] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.357481] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.357488] pci 0000:00:1c.1: bridge window [mem 0xd0700000-0xd07fffff] [ 0.357562] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401 [ 0.357681] pci 0000:03:00.0: supports D1 D2 [ 0.357686] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.357716] pci 0000:00:1c.2: PCI bridge to [bus 03-04] [ 0.357725] pci 0000:00:1c.2: bridge window [mem 0xd0600000-0xd06fffff] [ 0.357807] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000 [ 0.357837] pci 0000:04:00.0: reg 10: [mem 0xd0600000-0xd060ffff] [ 0.358030] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode) [ 0.358048] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff] [ 0.358063] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.358068] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff] (subtractive decode) [ 0.358074] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.358079] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode) [ 0.358137] pci 0000:00:1c.3: PCI bridge to [bus 05-05] [ 0.358167] pci_bus 0000:00: on NUMA node 0 [ 0.358174] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.358683] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT] [ 0.358817] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT] [ 0.358948] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT] [ 0.359080] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT] [ 0.359371] \_SB_.PCI0:_OSC invalid UUID [ 0.359375] _OSC request data:1 f 0 [ 0.359386] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.375218] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.375370] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.375524] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.375673] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.375822] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.375971] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.376123] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.376272] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.376438] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.376456] vgaarb: loaded [ 0.376460] vgaarb: bridge control possible 0000:00:02.0 [ 0.376513] PCI: Using ACPI for IRQ routing [ 0.383054] PCI: pci_cache_line_size set to 64 bytes [ 0.383152] reserve RAM buffer: 000000000008d800 - 000000000008ffff [ 0.383157] reserve RAM buffer: 000000007972b000 - 000000007bffffff [ 0.383163] reserve RAM buffer: 0000000079ba1000 - 000000007bffffff [ 0.383168] reserve RAM buffer: 0000000079d53000 - 000000007bffffff [ 0.383172] reserve RAM buffer: 000000007a000000 - 000000007bffffff [ 0.383398] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 [ 0.383410] hpet0: 3 comparators, 64-bit 14.318180 MHz counter [ 0.385438] Switching to clocksource hpet [ 0.385570] pnp: PnP ACPI init [ 0.385591] ACPI: bus type pnp registered [ 0.385626] pnp 00:00: [io 0x0070-0x0077] [ 0.385677] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.385746] pnp 00:01: [mem 0xfed00000-0xfed003ff] [ 0.385753] pnp 00:01: IRQ 8 override to edge, high [ 0.385767] pnp 00:01: [irq 8] [ 0.385814] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.386163] pnp 00:02: [bus 00-ff] [ 0.386169] pnp 00:02: [io 0x0070-0x0077] [ 0.386174] pnp 00:02: [io 0x0cf8-0x0cff] [ 0.386179] pnp 00:02: [io 0x0000-0x006f window] [ 0.386184] pnp 00:02: [io 0x0078-0x0cf7 window] [ 0.386188] pnp 00:02: [io 0x0d00-0xffff window] [ 0.386193] pnp 00:02: [mem 0x000a0000-0x000bffff window] [ 0.386198] pnp 00:02: [mem 0x000c0000-0x000dffff window] [ 0.386203] pnp 00:02: [mem 0x000e0000-0x000fffff window] [ 0.386208] pnp 00:02: [mem 0x00000000 window] [ 0.386213] pnp 00:02: [mem 0x00000000-0xffffffff window] [ 0.386218] pnp 00:02: [mem 0x80000000-0xd0916ffe window] [ 0.386304] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.386463] pnp 00:03: [mem 0xff000000-0xffffffff] [ 0.386517] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active) [ 0.386550] pnp 00:04: [io 0x002e-0x002f] [ 0.386555] pnp 00:04: [io 0x004e-0x004f] [ 0.386560] pnp 00:04: [io 0x0061] [ 0.386564] pnp 00:04: [io 0x0063] [ 0.386568] pnp 00:04: [io 0x0065] [ 0.386572] pnp 00:04: [io 0x0067] [ 0.386576] pnp 00:04: [io 0x0070] [ 0.386581] pnp 00:04: [io 0x0080-0x008f] [ 0.386585] pnp 00:04: [io 0x0092] [ 0.386589] pnp 00:04: [io 0x00b2-0x00b3] [ 0.386594] pnp 00:04: [io 0x0680-0x069f] [ 0.386598] pnp 00:04: [io 0x0400-0x047f] [ 0.386603] pnp 00:04: [io 0x0500-0x05fe] [ 0.386607] pnp 00:04: [io 0x0600-0x061f] [ 0.386615] pnp 00:04: [io 0x164e-0x164f] [ 0.386699] system 00:04: [io 0x0680-0x069f] has been reserved [ 0.386706] system 00:04: [io 0x0400-0x047f] has been reserved [ 0.386712] system 00:04: [io 0x0500-0x05fe] has been reserved [ 0.386717] system 00:04: [io 0x0600-0x061f] has been reserved [ 0.386723] system 00:04: [io 0x164e-0x164f] has been reserved [ 0.386730] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.387069] pnp 00:05: [io 0x0000-0xffffffff disabled] [ 0.387075] pnp 00:05: [io 0x0a00-0x0a2f] [ 0.387080] pnp 00:05: [io 0x0a30-0x0a3f] [ 0.387084] pnp 00:05: [io 0x0a40-0x0a4f] [ 0.387162] system 00:05: [io 0x0a00-0x0a2f] has been reserved [ 0.387169] system 00:05: [io 0x0a30-0x0a3f] has been reserved [ 0.387175] system 00:05: [io 0x0a40-0x0a4f] has been reserved [ 0.387182] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.387958] pnp 00:06: [io 0x03f8-0x03ff] [ 0.387970] pnp 00:06: [irq 4] [ 0.387975] pnp 00:06: [dma 0 disabled] [ 0.388096] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.388862] pnp 00:07: [io 0x02f8-0x02ff] [ 0.388874] pnp 00:07: [irq 3] [ 0.388879] pnp 00:07: [dma 0 disabled] [ 0.388995] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.389036] pnp 00:08: [io 0x0060] [ 0.389041] pnp 00:08: [io 0x0064] [ 0.389051] pnp 00:08: [irq 1] [ 0.389139] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.389218] pnp 00:09: [irq 12] [ 0.389302] pnp 00:09: Plug and Play ACPI device, IDs PNP0f13 (active) [ 0.390367] pnp 00:0a: [io 0x0378-0x037f] [ 0.390379] pnp 00:0a: [irq 5] [ 0.390384] pnp 00:0a: [dma 0 disabled] [ 0.390757] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.391298] pnp 00:0b: [mem 0xe0000000-0xefffffff] [ 0.391307] pnp 00:0b: [mem 0xfed01000-0xfed01fff] [ 0.391312] pnp 00:0b: [mem 0xfed03000-0xfed03fff] [ 0.391317] pnp 00:0b: [mem 0xfed04000-0xfed04fff] [ 0.391322] pnp 00:0b: [mem 0xfed0c000-0xfed0ffff] [ 0.391327] pnp 00:0b: [mem 0xfed08000-0xfed08fff] [ 0.391331] pnp 00:0b: [mem 0xfed1c000-0xfed1cfff] [ 0.391336] pnp 00:0b: [mem 0xfee00000-0xfeefffff] [ 0.391341] pnp 00:0b: [mem 0xfef00000-0xfeffffff] [ 0.391446] system 00:0b: [mem 0xe0000000-0xefffffff] could not be reserved [ 0.391453] system 00:0b: [mem 0xfed01000-0xfed01fff] has been reserved [ 0.391459] system 00:0b: [mem 0xfed03000-0xfed03fff] has been reserved [ 0.391468] system 00:0b: [mem 0xfed04000-0xfed04fff] has been reserved [ 0.391474] system 00:0b: [mem 0xfed0c000-0xfed0ffff] has been reserved [ 0.391480] system 00:0b: [mem 0xfed08000-0xfed08fff] has been reserved [ 0.391486] system 00:0b: [mem 0xfed1c000-0xfed1cfff] has been reserved [ 0.391492] system 00:0b: [mem 0xfee00000-0xfeefffff] has been reserved [ 0.391498] system 00:0b: [mem 0xfef00000-0xfeffffff] has been reserved [ 0.391505] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.393979] pnp: PnP ACPI: found 12 devices [ 0.393984] ACPI: ACPI bus type pnp unregistered [ 0.393989] PnPBIOS: Disabled by ACPI PNP [ 0.433790] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000 [ 0.433805] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000 [ 0.433832] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 03-04] add_size 1000 [ 0.433839] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-04] add_size 200000 [ 0.433852] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000 [ 0.433858] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000 [ 0.433865] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 05-05] add_size 200000 [ 0.433879] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.433885] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.433891] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.433897] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.433903] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.433908] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.433914] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.433923] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref] [ 0.433930] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref] [ 0.433937] pci 0000:00:1c.2: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref] [ 0.433944] pci 0000:00:1c.3: BAR 14: assigned [mem 0x80600000-0x807fffff] [ 0.433950] pci 0000:00:1c.3: BAR 15: assigned [mem 0x80800000-0x809fffff 64bit pref] [ 0.433958] pci 0000:00:1c.2: BAR 13: assigned [io 0x2000-0x2fff] [ 0.433964] pci 0000:00:1c.3: BAR 13: assigned [io 0x3000-0x3fff] [ 0.433974] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.433980] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff] [ 0.433989] pci 0000:00:1c.0: bridge window [mem 0xd0800000-0xd08fffff] [ 0.433996] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref] [ 0.434005] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.434011] pci 0000:00:1c.1: bridge window [io 0xd000-0xdfff] [ 0.434019] pci 0000:00:1c.1: bridge window [mem 0xd0700000-0xd07fffff] [ 0.434026] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x803fffff 64bit pref] [ 0.434035] pci 0000:03:00.0: PCI bridge to [bus 04-04] [ 0.434046] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff] [ 0.434064] pci 0000:00:1c.2: PCI bridge to [bus 03-04] [ 0.434070] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff] [ 0.434078] pci 0000:00:1c.2: bridge window [mem 0xd0600000-0xd06fffff] [ 0.434085] pci 0000:00:1c.2: bridge window [mem 0x80400000-0x805fffff 64bit pref] [ 0.434094] pci 0000:00:1c.3: PCI bridge to [bus 05-05] [ 0.434099] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff] [ 0.434107] pci 0000:00:1c.3: bridge window [mem 0x80600000-0x807fffff] [ 0.434114] pci 0000:00:1c.3: bridge window [mem 0x80800000-0x809fffff 64bit pref] [ 0.434185] pci 0000:03:00.0: setting latency timer to 64 [ 0.434208] pci_bus 0000:00: resource 4 [io 0x0000-0x006f] [ 0.434213] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7] [ 0.434218] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff] [ 0.434223] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff] [ 0.434228] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff] [ 0.434233] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff] [ 0.434238] pci_bus 0000:00: resource 10 [mem 0x80000000-0xd0916ffe] [ 0.434243] pci_bus 0000:01: resource 0 [io 0xe000-0xefff] [ 0.434248] pci_bus 0000:01: resource 1 [mem 0xd0800000-0xd08fffff] [ 0.434253] pci_bus 0000:01: resource 2 [mem 0x80000000-0x801fffff 64bit pref] [ 0.434258] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff] [ 0.434263] pci_bus 0000:02: resource 1 [mem 0xd0700000-0xd07fffff] [ 0.434268] pci_bus 0000:02: resource 2 [mem 0x80200000-0x803fffff 64bit pref] [ 0.434273] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff] [ 0.434278] pci_bus 0000:03: resource 1 [mem 0xd0600000-0xd06fffff] [ 0.434283] pci_bus 0000:03: resource 2 [mem 0x80400000-0x805fffff 64bit pref] [ 0.434288] pci_bus 0000:04: resource 1 [mem 0xd0600000-0xd06fffff] [ 0.434293] pci_bus 0000:04: resource 4 [io 0x2000-0x2fff] [ 0.434298] pci_bus 0000:04: resource 5 [mem 0xd0600000-0xd06fffff] [ 0.434303] pci_bus 0000:04: resource 6 [mem 0x80400000-0x805fffff 64bit pref] [ 0.434309] pci_bus 0000:05: resource 0 [io 0x3000-0x3fff] [ 0.434313] pci_bus 0000:05: resource 1 [mem 0x80600000-0x807fffff] [ 0.434318] pci_bus 0000:05: resource 2 [mem 0x80800000-0x809fffff 64bit pref] [ 0.434461] NET: Registered protocol family 2 [ 0.434570] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.434865] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.435484] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.435792] TCP: Hash tables configured (established 131072 bind 65536) [ 0.435797] TCP: reno registered [ 0.435803] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.435815] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.435985] NET: Registered protocol family 1 [ 0.436013] pci 0000:00:02.0: Boot video device [ 0.441400] pci 0000:00:14.0: xHCI BIOS handoff failed (BIOS bug ?) 00010801 [ 2.041476] pci 0000:00:1d.0: EHCI: BIOS handoff failed (BIOS bug?) 01010001 [ 2.041522] PCI: CLS 64 bytes, default 64 [ 2.041610] Unpacking initramfs... [ 2.461755] Freeing initrd memory: 13704k freed [ 2.467860] audit: initializing netlink socket (disabled) [ 2.467887] type=2000 audit(1533635013.360:1): initialized [ 2.483721] highmem bounce pool size: 64 pages [ 2.483731] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 2.484110] VFS: Disk quotas dquot_6.5.2 [ 2.484157] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 2.484284] msgmni has been set to 1721 [ 2.484616] alg: No test for stdrng (krng) [ 2.484677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 2.484684] io scheduler noop registered [ 2.484688] io scheduler deadline registered [ 2.484730] io scheduler cfq registered (default) [ 2.485046] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 2.485081] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 2.485085] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 2.486258] GHES: HEST is not enabled! [ 2.486281] isapnp: Scanning for PnP cards... [ 2.841181] isapnp: No Plug & Play device found [ 2.841276] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 2.861848] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 2.882463] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 2.903466] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 2.924175] 00:07: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 2.924712] Linux agpgart interface v0.103 [ 2.925012] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 2.925522] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 2.925580] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 2.925799] mousedev: PS/2 mouse device common for all mice [ 2.925895] rtc_cmos 00:00: RTC can wake from S4 [ 2.926062] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0 [ 2.926095] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs [ 2.926315] TCP: cubic registered [ 2.926429] NET: Registered protocol family 10 [ 2.926795] Mobile IPv6 [ 2.926801] NET: Registered protocol family 17 [ 2.926810] Registering the dns_resolver key type [ 2.926888] Using IPI No-Shortcut mode [ 2.927099] PM: Hibernation image not present or could not be loaded. [ 2.927124] registered taskstats version 1 [ 2.927825] rtc_cmos 00:00: setting system clock to 2018-08-07 09:43:34 UTC (1533635014) [ 2.928067] Freeing unused kernel memory: 416k freed [ 2.928323] Write protecting the kernel text: 3496k [ 2.928384] Write protecting the kernel read-only data: 984k [ 2.947432] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0 [ 2.947961] udevd[60]: starting version 175 [ 2.980951] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 2.981357] r8169 0000:01:00.0: eth0: RTL8168evl/8111evl at 0xf8014000, 74:d4:35:e1:83:a0, XID 0c900800 IRQ 16 [ 2.981365] r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko] [ 2.982163] usbcore: registered new interface driver usbfs [ 2.982209] usbcore: registered new interface driver hub [ 2.982576] usbcore: registered new device driver usb [ 2.983239] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.983337] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 2.983346] ehci_hcd 0000:00:1d.0: EHCI Host Controller [ 2.983582] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1 [ 2.983630] ehci_hcd 0000:00:1d.0: debug port 2 [ 2.985204] SCSI subsystem initialized [ 2.988941] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported [ 2.988980] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd0915000 [ 2.991089] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 2.991523] r8169 0000:02:00.0: eth1: RTL8168evl/8111evl at 0xf8022000, 74:d4:35:e1:83:a2, XID 0c900800 IRQ 17 [ 2.991533] r8169 0000:02:00.0: eth1: jumbo features [frames: 9200 bytes, tx checksumming: ko] [ 2.993880] libata version 3.00 loaded. [ 2.997137] ACPI: Fan [FAN0] (off) [ 2.997485] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 2.997532] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.997538] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.997545] usb usb1: Product: EHCI Host Controller [ 2.997550] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 2.997556] usb usb1: SerialNumber: 0000:00:1d.0 [ 2.997779] hub 1-0:1.0: USB hub found [ 2.997791] hub 1-0:1.0: 8 ports detected [ 3.000115] ahci 0000:00:13.0: version 3.0 [ 3.013581] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x1 impl SATA mode [ 3.013594] ahci 0000:00:13.0: flags: 64bit ncq pm led clo pio slum part [ 3.013603] ahci 0000:00:13.0: setting latency timer to 64 [ 3.014122] scsi0 : ahci [ 3.014322] scsi1 : ahci [ 3.014432] ata1: SATA max UDMA/133 abar m2048@0xd0916000 port 0xd0916100 irq 19 [ 3.014437] ata2: DUMMY [ 3.014547] xhci_hcd 0000:00:14.0: setting latency timer to 64 [ 3.014555] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 3.014577] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2 [ 3.014979] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported [ 3.015055] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.015063] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.015069] usb usb2: Product: xHCI Host Controller [ 3.015075] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd [ 3.015081] usb usb2: SerialNumber: 0000:00:14.0 [ 3.015245] xHCI xhci_add_endpoint called for root hub [ 3.015251] xHCI xhci_check_bandwidth called for root hub [ 3.015315] hub 2-0:1.0: USB hub found [ 3.015330] hub 2-0:1.0: 6 ports detected [ 3.015463] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 3.015477] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3 [ 3.015521] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003 [ 3.015528] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.015534] usb usb3: Product: xHCI Host Controller [ 3.015539] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd [ 3.015545] usb usb3: SerialNumber: 0000:00:14.0 [ 3.015690] xHCI xhci_add_endpoint called for root hub [ 3.015696] xHCI xhci_check_bandwidth called for root hub [ 3.015759] hub 3-0:1.0: USB hub found [ 3.015770] hub 3-0:1.0: 1 port detected [ 3.017327] microcode: CPU0 sig=0x30673, pf=0x4, revision=0x31e [ 3.039810] microcode: CPU1 sig=0x30673, pf=0x4, revision=0x31e [ 3.043238] microcode: CPU2 sig=0x30673, pf=0x4, revision=0x31e [ 3.046844] microcode: CPU3 sig=0x30673, pf=0x4, revision=0x31e [ 3.050554] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 3.309485] usb 1-1: new high-speed USB device number 2 using ehci_hcd [ 3.341485] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.341736] ata1.00: ATA-8: OCZ-VERTEX, 1.5, max UDMA/133 [ 3.341744] ata1.00: 62533296 sectors, multi 1: LBA48 NCQ (depth 31/32), AA [ 3.343396] ata1.00: configured for UDMA/133 [ 3.343611] scsi 0:0:0:0: Direct-Access ATA OCZ-VERTEX 1.5 PQ: 0 ANSI: 5 [ 3.349743] sd 0:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB) [ 3.349952] sd 0:0:0:0: [sda] Write Protect is off [ 3.349959] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 3.350021] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 3.351037] sda: sda1 sda2 < sda5 > [ 3.351750] sd 0:0:0:0: [sda] Attached SCSI disk [ 3.354659] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 3.441926] usb 1-1: New USB device found, idVendor=8087, idProduct=07e6 [ 3.441933] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.442226] hub 1-1:1.0: USB hub found [ 3.442291] hub 1-1:1.0: 4 ports detected [ 3.465479] Refined TSC clocksource calibration: 2000.000 MHz. [ 3.465488] Switching to clocksource tsc [ 3.713550] usb 1-1.1: new high-speed USB device number 3 using ehci_hcd [ 3.805795] usb 1-1.1: New USB device found, idVendor=045b, idProduct=0209 [ 3.805801] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.806110] hub 1-1.1:1.0: USB hub found [ 3.806166] hub 1-1.1:1.0: 4 ports detected [ 4.093550] usb 1-1.1.4: new high-speed USB device number 4 using ehci_hcd [ 4.219045] usb 1-1.1.4: New USB device found, idVendor=050d, idProduct=825b [ 4.219052] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4.219057] usb 1-1.1.4: Product: 802.11 n WLAN [ 4.219061] usb 1-1.1.4: Manufacturer: Ralink [ 4.219065] usb 1-1.1.4: SerialNumber: 1.0 [ 8.459599] PM: Starting manual resume from disk [ 8.459606] PM: Hibernation image partition 8:5 present [ 8.459610] PM: Looking for hibernation image. [ 8.459883] PM: Image not found (code -22) [ 8.459888] PM: Hibernation image not present or could not be loaded. [ 8.468128] EXT4-fs (sda1): INFO: recovery required on readonly filesystem [ 8.468135] EXT4-fs (sda1): write access will be enabled during recovery [ 9.302042] EXT4-fs (sda1): orphan cleanup on readonly fs [ 9.302058] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 794957 [ 9.302241] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 1439785 [ 9.302300] EXT4-fs (sda1): 2 orphan inodes deleted [ 9.302305] EXT4-fs (sda1): recovery complete [ 9.321146] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 9.618003] udevd[378]: starting version 175 [ 9.732413] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 [ 9.732429] ACPI: Power Button [PWRB] [ 9.732535] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2 [ 9.732545] ACPI: Sleep Button [SLPB] [ 9.732639] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 [ 9.732648] ACPI: Power Button [PWRF] [ 9.779548] parport_pc 00:0a: reported by Plug and Play ACPI [ 9.779613] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE] [ 9.797797] snd_hda_intel 0000:00:1b.0: setting latency timer to 64 [ 9.849410] cfg80211: Calling CRDA to update world regulatory domain [ 9.876795] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4 [ 9.905544] cfg80211: World regulatory domain updated: [ 9.905560] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 9.905577] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm) [ 9.905590] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 9.905606] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm) [ 9.905621] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 9.905635] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 9.905651] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm) [ 9.905666] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm) [ 9.905683] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm) [ 9.912561] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5 [ 9.912738] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6 [ 9.912864] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7 [ 9.912989] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8 [ 9.913114] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9 [ 9.949677] usb 1-1.1.4: reset high-speed USB device number 4 using ehci_hcd [ 10.109379] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 10.109786] Registered led device: rt2800usb-phy0::radio [ 10.109825] Registered led device: rt2800usb-phy0::assoc [ 10.109869] Registered led device: rt2800usb-phy0::quality [ 10.109907] usbcore: registered new interface driver rt2800usb [ 10.521282] Adding 1316860k swap on /dev/sda5. Priority:-1 extents:1 across:1316860k SS [ 10.544203] EXT4-fs (sda1): re-mounted. Opts: (null) [ 10.576371] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input10 [ 10.607707] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 10.637072] loop: module loaded [ 11.667856] RPC: Registered named UNIX socket transport module. [ 11.667864] RPC: Registered udp transport module. [ 11.667868] RPC: Registered tcp transport module. [ 11.667872] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 11.674791] FS-Cache: Loaded [ 11.684024] NFS: Registering the id_resolver key type [ 11.684061] FS-Cache: Netfs 'nfs' registered for caching [ 11.691325] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 12.560983] Bluetooth: Core ver 2.16 [ 12.561020] NET: Registered protocol family 31 [ 12.561025] Bluetooth: HCI device and connection manager initialized [ 12.561030] Bluetooth: HCI socket layer initialized [ 12.561034] Bluetooth: L2CAP socket layer initialized [ 12.561045] Bluetooth: SCO socket layer initialized [ 12.568149] Bluetooth: RFCOMM TTY layer initialized [ 12.568159] Bluetooth: RFCOMM socket layer initialized [ 12.568163] Bluetooth: RFCOMM ver 1.11 [ 12.578944] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 12.578950] Bluetooth: BNEP filters: protocol multicast [ 12.660368] lp0: using parport0 (interrupt-driven). [ 12.666692] ppdev: user-space parallel port driver [ 12.842827] r8169 0000:01:00.0: eth0: link down [ 12.843072] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 12.986778] r8169 0000:02:00.0: eth1: link down [ 12.987022] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 13.269391] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 13.283181] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11 [ 16.227008] wlan0: authenticate with 00:25:9c:c1:0e:b5 [ 16.290926] wlan0: send auth to 00:25:9c:c1:0e:b5 (try 1/3) [ 16.292440] wlan0: authenticated [ 16.325478] wlan0: associate with 00:25:9c:c1:0e:b5 (try 1/3) [ 16.329064] wlan0: RX AssocResp from 00:25:9c:c1:0e:b5 (capab=0x411 status=0 aid=7) [ 16.368361] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 16.368487] wlan0: associated [ 343.660159] I-pipe: head domain RTAI registered. [ 343.660169] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 343.660257] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 343.660264] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 343.660270] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 343.660277] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 3776500 [ 343.684026] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 343.684077] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 343.684086] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 343.684092] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 343.684096] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 343.701494] RTAI[math]: loaded. [ 343.802272] hm2: loading Mesa HostMot2 driver version 0.15 [ 343.807128] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 343.807178] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 343.808958] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 343.866175] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 343.869231] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 343.871763] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 343.876239] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 343.881890] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 343.982646] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 343.985296] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 344.087472] hm2/hm2_5i25.0: 34 I/O Pins used: [ 344.087478] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 344.087483] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 344.087488] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 344.087494] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 344.087500] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 344.087505] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 344.087511] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 344.087517] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 344.087522] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 344.087528] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 344.087533] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 344.087539] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 344.087544] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 344.087550] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 344.087555] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 344.087561] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 344.087566] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 344.087571] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 344.087575] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 344.087580] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 344.087584] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 344.087589] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 344.087593] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 344.087597] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 344.087602] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 344.087606] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 344.087611] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 344.087615] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 344.087620] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 344.087624] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 344.087628] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 344.087633] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 344.087637] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 344.087642] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 344.087862] hm2/hm2_5i25.0: registered [ 344.087867] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 344.502519] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 344.502529] hm2/hm2_5i25.0: unregistered [ 344.502617] hm2_pci: driver unloaded [ 344.505450] hm2: unloading [ 346.681340] RTAI[math]: unloaded. [ 346.684381] SCHED releases registered named ALIEN PEDV$D [ 346.691597] RTAI[malloc]: unloaded. [ 346.789472] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 346.792466] I-pipe: head domain RTAI unregistered. [ 346.792565] RTAI[hal]: unmounted. [ 434.161369] I-pipe: head domain RTAI registered. [ 434.161379] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 434.161515] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 434.161522] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 434.161528] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 434.161539] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5182500 [ 434.172226] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 434.172288] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 434.172297] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 434.172305] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 434.172309] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 434.185301] RTAI[math]: loaded. [ 434.256373] hm2: loading Mesa HostMot2 driver version 0.15 [ 434.259722] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 434.259774] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 434.261292] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 434.318459] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 434.321517] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 434.324100] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 434.328640] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 434.334431] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 434.434977] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 434.437627] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 434.539794] hm2/hm2_5i25.0: 34 I/O Pins used: [ 434.539800] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 434.539805] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 434.539810] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 434.539816] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 434.539822] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 434.539828] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 434.539833] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 434.539839] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 434.539845] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 434.539850] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 434.539856] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 434.539861] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 434.539867] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 434.539872] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 434.539878] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 434.539883] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 434.539889] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 434.539894] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 434.539898] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 434.539902] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 434.539907] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 434.539911] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 434.539916] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 434.539920] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 434.539925] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 434.539929] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 434.539933] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 434.539938] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 434.539942] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 434.539947] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 434.539951] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 434.539955] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 434.539960] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 434.539964] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 434.540183] hm2/hm2_5i25.0: registered [ 434.540188] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 434.936970] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 434.936980] hm2/hm2_5i25.0: unregistered [ 434.937069] hm2_pci: driver unloaded [ 434.939845] hm2: unloading [ 437.110934] RTAI[math]: unloaded. [ 437.113963] SCHED releases registered named ALIEN PEDV$D [ 437.117892] RTAI[malloc]: unloaded. [ 437.217476] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 437.220417] I-pipe: head domain RTAI unregistered. [ 437.220517] RTAI[hal]: unmounted. [ 466.977336] I-pipe: head domain RTAI registered. [ 466.977347] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 466.977435] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 466.977442] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 466.977447] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 466.977478] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5185750 [ 466.988276] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 466.988328] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 466.988337] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 466.988343] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 466.988347] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 467.001491] RTAI[math]: loaded. [ 467.072193] hm2: loading Mesa HostMot2 driver version 0.15 [ 467.075470] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 467.075520] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 467.077293] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 467.134464] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 467.137468] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 467.139998] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 467.144423] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 467.150122] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 467.251530] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 467.254181] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 467.358614] hm2/hm2_5i25.0: 34 I/O Pins used: [ 467.358623] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 467.358628] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 467.358633] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 467.358639] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 467.358645] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 467.358651] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 467.358656] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 467.358662] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 467.358668] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 467.358673] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 467.358679] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 467.358684] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 467.358690] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 467.358695] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 467.358700] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 467.358706] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 467.358711] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 467.358716] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 467.358721] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 467.358725] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 467.358730] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 467.358734] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 467.358738] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 467.358743] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 467.358747] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 467.358752] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 467.358756] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 467.358760] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 467.358765] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 467.358769] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 467.358774] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 467.358778] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 467.358783] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 467.358787] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 467.359005] hm2/hm2_5i25.0: registered [ 467.359010] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 467.748846] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 467.748856] hm2/hm2_5i25.0: unregistered [ 467.748940] hm2_pci: driver unloaded [ 467.751702] hm2: unloading [ 469.921896] RTAI[math]: unloaded. [ 469.924800] SCHED releases registered named ALIEN PEDV$D [ 469.934262] RTAI[malloc]: unloaded. [ 470.033481] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 470.036509] I-pipe: head domain RTAI unregistered. [ 470.036616] RTAI[hal]: unmounted. [ 546.245320] I-pipe: head domain RTAI registered. [ 546.245330] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 546.245450] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 546.245608] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 546.245614] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 546.245620] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5177750 [ 546.256576] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 546.256634] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 546.256643] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 546.256649] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 546.256653] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 546.267494] RTAI[math]: loaded. [ 546.441299] hm2: loading Mesa HostMot2 driver version 0.15 [ 546.444868] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 546.444918] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 546.446714] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 546.503873] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 546.506878] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 546.509460] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 546.513832] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 546.519365] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 546.620211] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 546.622876] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 546.725016] hm2/hm2_5i25.0: 34 I/O Pins used: [ 546.725024] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 546.725029] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 546.725033] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 546.725039] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 546.725045] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 546.725051] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 546.725057] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 546.725063] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 546.725068] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 546.725074] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 546.725079] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 546.725085] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 546.725090] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 546.725096] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 546.725101] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 546.725106] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 546.725112] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 546.725117] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 546.725121] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 546.725126] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 546.725130] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 546.725134] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 546.725139] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 546.725143] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 546.725148] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 546.725152] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 546.725157] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 546.725161] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 546.725165] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 546.725170] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 546.725174] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 546.725179] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 546.725183] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 546.725187] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 546.725407] hm2/hm2_5i25.0: registered [ 546.725412] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 547.111778] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 547.111789] hm2/hm2_5i25.0: unregistered [ 547.111877] hm2_pci: driver unloaded [ 547.114819] hm2: unloading [ 549.289231] RTAI[math]: unloaded. [ 549.292655] SCHED releases registered named ALIEN PEDV$D [ 549.296961] RTAI[malloc]: unloaded. [ 549.393489] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 549.396368] I-pipe: head domain RTAI unregistered. [ 549.396466] RTAI[hal]: unmounted. [ 763.256649] I-pipe: head domain RTAI registered. [ 763.256659] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 763.256749] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 763.256755] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 763.256761] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 763.256767] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 4834250 [ 763.270527] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 763.270583] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 763.270592] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 763.270598] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 763.270603] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 763.280930] RTAI[math]: loaded. [ 763.453612] hm2: loading Mesa HostMot2 driver version 0.15 [ 763.456629] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 763.456679] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 763.458267] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 763.515576] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 763.518581] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 763.521112] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 763.525588] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 763.531378] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 763.631987] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 763.634640] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 763.736770] hm2/hm2_5i25.0: 34 I/O Pins used: [ 763.736778] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 763.736783] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 763.736787] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 763.736793] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 763.736799] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 763.736805] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 763.736810] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 763.736816] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 763.736822] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 763.736827] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 763.736833] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 763.736839] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 763.736844] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 763.736849] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 763.736855] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 763.736860] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 763.736866] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 763.736871] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 763.736875] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 763.736880] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 763.736884] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 763.736888] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 763.736893] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 763.736897] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 763.736902] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 763.736906] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 763.736911] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 763.736915] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 763.736919] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 763.736924] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 763.736928] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 763.736933] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 763.736937] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 763.736942] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 763.737159] hm2/hm2_5i25.0: registered [ 763.737164] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 764.156357] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 764.156366] hm2/hm2_5i25.0: unregistered [ 764.156450] hm2_pci: driver unloaded [ 764.159123] hm2: unloading [ 766.327660] RTAI[math]: unloaded. [ 766.330551] SCHED releases registered named ALIEN PEDV$D [ 766.337518] RTAI[malloc]: unloaded. [ 766.437470] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 766.440441] I-pipe: head domain RTAI unregistered. [ 766.440539] RTAI[hal]: unmounted. [ 888.711499] I-pipe: head domain RTAI registered. [ 888.711510] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 888.711599] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 888.711606] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 888.711613] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 888.711619] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5190750 [ 888.722357] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 888.722409] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 888.722417] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 888.722423] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 888.722427] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 888.730748] RTAI[math]: loaded. [ 888.906784] hm2: loading Mesa HostMot2 driver version 0.15 [ 888.910071] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 888.910123] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 888.911713] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 888.968920] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 888.971719] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 888.974250] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 888.978729] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 888.984365] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 889.084849] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 889.087514] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 889.189641] hm2/hm2_5i25.0: 34 I/O Pins used: [ 889.189649] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 889.189654] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 889.189659] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 889.189665] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 889.189671] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 889.189676] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 889.189682] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 889.189688] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 889.189694] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 889.189699] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 889.189705] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 889.189710] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 889.189716] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 889.189721] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 889.189727] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 889.189732] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 889.189737] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 889.189742] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 889.189747] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 889.189751] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 889.189756] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 889.189760] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 889.189764] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 889.189769] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 889.189773] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 889.189778] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 889.189782] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 889.189787] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 889.189791] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 889.189796] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 889.189800] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 889.189804] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 889.189809] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 889.189813] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 889.190031] hm2/hm2_5i25.0: registered [ 889.190036] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 889.615303] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 889.615313] hm2/hm2_5i25.0: unregistered [ 889.615401] hm2_pci: driver unloaded [ 889.618440] hm2: unloading [ 891.788759] RTAI[math]: unloaded. [ 891.791660] SCHED releases registered named ALIEN PEDV$D [ 891.800054] RTAI[malloc]: unloaded. [ 891.897475] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 891.900572] I-pipe: head domain RTAI unregistered. [ 891.900669] RTAI[hal]: unmounted. [ 940.669682] I-pipe: head domain RTAI registered. [ 940.669693] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 940.669779] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 940.669788] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 940.669793] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 940.669799] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5183250 [ 940.680625] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 940.680686] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 940.680694] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 940.680701] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 940.680705] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 940.689400] RTAI[math]: loaded. [ 940.863431] hm2: loading Mesa HostMot2 driver version 0.15 [ 940.866541] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 940.866592] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 940.868121] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 940.925378] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 940.928199] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 940.930733] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 940.935055] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 940.940657] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 941.041075] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 941.043728] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 941.145825] hm2/hm2_5i25.0: 34 I/O Pins used: [ 941.145834] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 941.145838] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 941.145843] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 941.145849] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 941.145855] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 941.145861] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 941.145867] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 941.145873] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 941.145878] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 941.145884] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 941.145889] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 941.145895] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 941.145900] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 941.145906] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 941.145911] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 941.145917] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 941.145922] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 941.145927] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 941.145931] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 941.145936] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 941.145940] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 941.145945] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 941.145949] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 941.145954] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 941.145958] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 941.145963] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 941.145967] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 941.145972] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 941.145976] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 941.145980] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 941.145985] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 941.145989] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 941.145994] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 941.145998] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 941.146219] hm2/hm2_5i25.0: registered [ 941.146224] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 941.540031] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 941.540040] hm2/hm2_5i25.0: unregistered [ 941.540124] hm2_pci: driver unloaded [ 941.543040] hm2: unloading [ 943.711520] RTAI[math]: unloaded. [ 943.714582] SCHED releases registered named ALIEN PEDV$D [ 943.720861] RTAI[malloc]: unloaded. [ 943.817480] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 943.820426] I-pipe: head domain RTAI unregistered. [ 943.820527] RTAI[hal]: unmounted. [ 1227.908263] I-pipe: head domain RTAI registered. [ 1227.908274] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1227.908385] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1227.908393] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 1227.908398] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1227.908404] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5193500 [ 1227.922650] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1227.922707] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1227.922718] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 1227.922725] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 1227.922731] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1227.932685] RTAI[math]: loaded. [ 1228.114323] hm2: loading Mesa HostMot2 driver version 0.15 [ 1228.117445] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 1228.117496] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 1228.119298] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 1228.176396] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 1228.179354] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 1228.181729] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 1228.185893] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 1228.191579] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 1228.292496] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 1228.295149] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 1228.397226] hm2/hm2_5i25.0: 34 I/O Pins used: [ 1228.397234] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 1228.397238] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 1228.397243] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 1228.397249] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 1228.397255] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 1228.397261] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 1228.397266] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 1228.397272] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 1228.397278] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 1228.397283] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 1228.397289] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 1228.397294] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 1228.397300] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 1228.397305] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 1228.397311] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 1228.397316] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 1228.397322] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 1228.397327] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 1228.397331] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 1228.397336] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 1228.397340] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 1228.397344] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 1228.397349] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 1228.397353] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 1228.397358] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 1228.397362] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 1228.397366] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 1228.397371] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 1228.397375] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 1228.397380] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 1228.397384] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 1228.397389] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 1228.397393] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 1228.397397] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 1228.397615] hm2/hm2_5i25.0: registered [ 1228.397620] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 1228.779291] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 1228.779301] hm2/hm2_5i25.0: unregistered [ 1228.779386] hm2_pci: driver unloaded [ 1228.782326] hm2: unloading [ 1230.953030] RTAI[math]: unloaded. [ 1230.956010] SCHED releases registered named ALIEN PEDV$D [ 1230.964269] RTAI[malloc]: unloaded. [ 1231.061486] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1231.064463] I-pipe: head domain RTAI unregistered. [ 1231.064564] RTAI[hal]: unmounted. [ 1404.127501] I-pipe: head domain RTAI registered. [ 1404.127511] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1404.127600] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1404.127606] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 1404.127611] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1404.127617] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5190750 [ 1404.139095] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1404.139148] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1404.139157] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 1404.139163] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 1404.139167] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1404.148315] RTAI[math]: loaded. [ 1404.321724] hm2: loading Mesa HostMot2 driver version 0.15 [ 1404.324796] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 1404.324846] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 1404.326406] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 1404.383644] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 1404.386651] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 1404.389181] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 1404.393657] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 1404.399084] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 1404.500137] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 1404.502790] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 1404.604895] hm2/hm2_5i25.0: 34 I/O Pins used: [ 1404.604903] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 1404.604908] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 1404.604912] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 1404.604918] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 1404.604924] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 1404.604930] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 1404.604936] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 1404.604942] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 1404.604947] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 1404.604953] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 1404.604958] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 1404.604964] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 1404.604969] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 1404.604975] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 1404.604980] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 1404.604986] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 1404.604991] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 1404.604996] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 1404.605001] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 1404.605005] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 1404.605009] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 1404.605014] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 1404.605018] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 1404.605023] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 1404.605027] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 1404.605032] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 1404.605036] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 1404.605041] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 1404.605045] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 1404.605049] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 1404.605054] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 1404.605058] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 1404.605063] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 1404.605067] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 1404.605285] hm2/hm2_5i25.0: registered [ 1404.605290] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 1405.005255] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 1405.005265] hm2/hm2_5i25.0: unregistered [ 1405.005355] hm2_pci: driver unloaded [ 1405.008365] hm2: unloading [ 1407.180570] RTAI[math]: unloaded. [ 1407.183470] SCHED releases registered named ALIEN PEDV$D [ 1407.192858] RTAI[malloc]: unloaded. [ 1407.289480] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1407.292421] I-pipe: head domain RTAI unregistered. [ 1407.292516] RTAI[hal]: unmounted. [ 1637.880838] I-pipe: head domain RTAI registered. [ 1637.880849] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 1637.880937] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 1637.880943] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 1999990000, CPU_FREQ 1999990000 [ 1637.880948] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 1637.880953] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 4810500 [ 1637.892175] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 1637.892235] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 1637.892244] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 1637.892250] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1999990000 hz. [ 1637.892254] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns. [ 1637.901281] RTAI[math]: loaded. [ 1638.076708] hm2: loading Mesa HostMot2 driver version 0.15 [ 1638.079808] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 1638.079858] hm2_pci: discovered 5i25 at 0000:04:00.0 [ 1638.081389] hm2/hm2_5i25.0: Smart Serial Firmware Version 43 [ 1638.138668] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard [ 1638.141672] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output [ 1638.144255] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog [ 1638.148576] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage [ 1638.154314] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage [ 1638.255583] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard [ 1638.258235] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables [ 1638.360292] hm2/hm2_5i25.0: 34 I/O Pins used: [ 1638.360298] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 1638.360303] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort [ 1638.360307] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort [ 1638.360313] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output) [ 1638.360319] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input) [ 1638.360325] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output) [ 1638.360331] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input) [ 1638.360337] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output) [ 1638.360345] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input) [ 1638.360352] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input) [ 1638.360357] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input) [ 1638.360363] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input) [ 1638.360368] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input) [ 1638.360374] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input) [ 1638.360379] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input) [ 1638.360384] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input) [ 1638.360390] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input) [ 1638.360395] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 1638.360399] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort [ 1638.360404] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort [ 1638.360408] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 1638.360413] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort [ 1638.360417] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort [ 1638.360421] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort [ 1638.360426] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 1638.360430] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort [ 1638.360435] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort [ 1638.360439] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort [ 1638.360444] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort [ 1638.360448] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort [ 1638.360452] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort [ 1638.360457] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort [ 1638.360461] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort [ 1638.360466] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 1638.360684] hm2/hm2_5i25.0: registered [ 1638.360688] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0 [ 1638.761250] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0 [ 1638.761259] hm2/hm2_5i25.0: unregistered [ 1638.761344] hm2_pci: driver unloaded [ 1638.764276] hm2: unloading [ 1640.939263] RTAI[math]: unloaded. [ 1640.942077] SCHED releases registered named ALIEN PEDV$D [ 1640.946335] RTAI[malloc]: unloaded. [ 1641.045492] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [ 1641.048557] I-pipe: head domain RTAI unregistered. [ 1641.048657] RTAI[hal]: unmounted.
dmesg:
8 years 2 months ago #115726 by tommylight
Replied by tommylight on topic Lagunmatic 3516-SX Retrofit
You have twice loadrt pid, you can have them all in a single line and it will not complain.
The following user(s) said Thank You: giz
8 years 2 months ago #115747 by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
tommylight wrote: You have twice loadrt pid, you can have them all in a single line and it will not complain.
Awesome - thanks! I'll try that tonight, something like:
loadrt pid names=pid.x,pid.y,pid.z,pid.s,pid.0,pid.1
If that is the only issue I will be astounded :laugh:
8 years 2 months ago #115748 by andypugh
Replied by andypugh on topic Lagunmatic 3516-SX Retrofit
You already have pid.s, so probably only need to add pid.o (pr pid.p or whatever makes sense to you)
8 years 2 months ago #115749 by giz
andypugh wrote: You already have pid.s, so probably only need to add pid.o (pr pid.p or whatever makes sense to you)
I figured a third pid was extraneous, but wasn't certain! Do you mind taking a quick glance at the spindle section of my hal to see if anything jumps out at you?
There were a couple things I was unsure about... spindle.hal refrenced parport.0.pin-NN-out and I changed that to hm2_5i25.0.7i77.0.1.analogout5. Also I changed encoder.3.position to hm2_5i25.0.encoder.05.position
As always, appreciate your input!!
8 years 2 months ago #115750 by andypugh
Is your spindle set up for + / - 10V or for 0-10V + direction?
Time to create page: 2.609 seconds
