Lagunmatic 3516-SX Retrofit
8 years 2 months ago #115631 by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
Spent most of the day refreshing myself on what is going on and making incremental progress.
I was able to get the spindle encoder hooked up and I can read signal. The encoder does not have a badge, so counts/rev is unknown. I read that when turning by hand, 1 revolution should equal 1 rev count in Hal Meter so through testing I came up with 4096.
When I command an RPM in the MDI it's not accurate at all so I still have to determine where that disconnect is. For example, M3 S100 gives me an RPM of about 570 (tested with a cheap digital tachometer).
Next progressive step was to test all the pneumatic functions for the tool changer. I finally learned about halcmd and sets and I was able to run through a full tool change "manually" by progressing through the signal calls. HOWEVER - I took the dogs off the spindle nose because at this point I did not know how to handle the spindle orient. I ran through this with and without a tool and everything functioned well.
So that brings me to now. I'm really lost on how to implement the tool change "correctly" - it seems like everybody does it different. Some remap M6, some use M19, some don't. The Triac Toolchanger that has been posted does it one way, the VMC sim does it another... it's all very confusing.
Lunada was gracious enough to send me his his classicladder script and I took the time to port it over to my HAL and INI files. I found the Ladder Editor and I can see when I call M6 T01 the editor starts progressing through the logic until it gets to Orient. Orient is set to true waiting for a Orient Complete signal which never comes because the spindle does not move.
This is where I am stuck! I'm very lost when it comes to the orient "command", homing the spindle, setting the correct index position, etc. I'm trying to piece this all together the best I can but I could definitely use some hand-holding if anybody can spare the time!
Thanks all. File code below and full config in the attachment if interested
Lagunmatic_3516-SX.HAL:
# Generated by PNCconf at Fri Apr 27 02:57:57 2018 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx" setp hm2_5i25.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s ##Lunada Ladder## loadrt threads name1=classicladder-thread period1=2000000 loadrt classicladder_rt numS32in=3 numS32out=8 numRungs=60 numBits=90 numWords=55 numTimers=27 numCounters=15 numPhysInputs=50 numPhysOutputs=50 numArithmExpr=25 numSections=6 numSymbols=220 numS32in=3 numS32out=9 loadusr -w classicladder --nogui shizuoka.clp loadrt modmath mod_dir=1 loadrt carousel pockets=18 encoding=index num_sense=1 dir=2 addf carousel.0 servo-thread addf classicladder.0.refresh classicladder-thread ##End Lunada Ladder## addf hm2_5i25.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_5i25.0.write servo-thread ###################################### # external output signals ###################################### # --- MACHINE-IS-ENABLED --- net machine-is-enabled hm2_5i25.0.7i77.0.0.output-00 # --- MAGAZINE_FORWARD --- #net Magazine_Forward hm2_5i25.0.7i77.0.0.output-01 # --- MAGAZINE_DOWN --- #net Magazine_Down hm2_5i25.0.7i77.0.0.output-02 # --- MAGAZINE_CW --- #net Magazine_CW hm2_5i25.0.7i77.0.0.output-03 # --- MAGAZINE_CCW --- #net Magazine_CCW hm2_5i25.0.7i77.0.0.output-04 # --- SPINDLE_ORIENT --- #net Spindle_Orient hm2_5i25.0.7i77.0.0.output-05 # --- SPINDLE-CW --- net spindle-cw hm2_5i25.0.7i77.0.0.output-06 # --- TOOL_UNCLAMP --- #net Tool_Unclamp hm2_5i25.0.7i77.0.0.output-07 # --- COOLANT-MIST --- #net coolant-mist hm2_5i25.0.7i77.0.0.output-08 # --- LUBE_RELAY --- net Lube_Relay hm2_5i25.0.7i77.0.0.output-10 # --- SOFT_START_CANCEL --- #net Soft_Start_Cancel hm2_5i25.0.7i77.0.0.output-11 ###################################### # external input signals ###################################### # --- WAY_LUBE_LEVEL --- net Way_Lube_Level <= hm2_5i25.0.7i77.0.0.input-00 # --- MAX-X --- net max-x <= hm2_5i25.0.7i77.0.0.input-01-not # --- MIN-X --- net min-x <= hm2_5i25.0.7i77.0.0.input-02-not # --- MAX-Y --- net max-y <= hm2_5i25.0.7i77.0.0.input-03-not # --- MIN-Y --- net min-y <= hm2_5i25.0.7i77.0.0.input-04-not # --- MAX-Z --- net max-z <= hm2_5i25.0.7i77.0.0.input-05-not # --- MIN-Z --- net min-z <= hm2_5i25.0.7i77.0.0.input-06-not # --- HOME-X --- net home-x <= hm2_5i25.0.7i77.0.0.input-07 # --- HOME-Y --- net home-y <= hm2_5i25.0.7i77.0.0.input-08 # --- HOME-Z --- net home-z <= hm2_5i25.0.7i77.0.0.input-09 # --- MAGAZINE_BACK_POSITION --- #net Magazine_Back_Position <= hm2_5i25.0.7i77.0.0.input-10 # --- MAGAZINE_FORWARD_POSITION --- #net Magazine_Forward_Position <= hm2_5i25.0.7i77.0.0.input-11 # --- MAGAZINE_UP_POSITION --- #net Magazine_Up_Position <= hm2_5i25.0.7i77.0.0.input-12 # --- MAGAZINE_DOWN_POSITION --- #net Magazine_Down_Position <= hm2_5i25.0.7i77.0.0.input-13 # --- POSITION_COUNTER --- #net Position_Counter <= hm2_5i25.0.7i77.0.0.input-14 # --- MAGAZINE_HOME --- #net Magazine_Home <= hm2_5i25.0.7i77.0.0.input-15 # --- TOOL_CLAMP_POSITION --- #net Tool_Clamp_Position <= hm2_5i25.0.7i77.0.0.input-16 # --- TOOL_UNCLAMP_POSITION --- #net Tool_Unclamp_Position <= hm2_5i25.0.7i77.0.0.input-17 # --- SPINDLE_UP_TO_SPEED --- net Spindle_Up_To_Speed <= hm2_5i25.0.7i77.0.0.input-18 # --- ESTOP --- net ESTOP <= hm2_5i25.0.7i77.0.0.input-19 # --- SPINDLE_ORIENT_COMPLETE --- #net Spindle_Orient_Complete <= hm2_5i25.0.7i77.0.0.input-20 # --- LUBE_PRESSURE_SWITCH --- net Lube_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-21-not # --- AIR_PRESSURE_SWITCH --- net Air_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-22 # --- MACHINE_ON_CMD --- net Machine_On_CMD <= hm2_5i25.0.7i77.0.0.input-23 # --- SPINDLE_ON_CMD --- net Spindle_On_CMD <= hm2_5i25.0.7i77.0.0.input-24 # --- TOOL_UNCLAMP_CMD --- net Tool_Unclamp_CMD <= hm2_5i25.0.7i77.0.0.input-25 # --- MIST_ON_CMD --- net Mist_On_CMD <= hm2_5i25.0.7i77.0.0.input-26 # --- MAGAZINE_CW_CMD --- net Magazine_CW_CMD <= hm2_5i25.0.7i77.0.0.input-27 # --- MAGAZINE_CCW_CMD --- net Magazine_CCW_CMD <= hm2_5i25.0.7i77.0.0.input-28 #******************* # AXIS X #******************* setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd axis.0.motor-pos-cmd net x-enable axis.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => axis.0.motor-pos-fb net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts # ---setup home / limit switch signals--- net home-x => axis.0.home-sw-in net min-x => axis.0.neg-lim-sw-in net max-x => axis.0.pos-lim-sw-in #******************* # AXIS Y #******************* setp pid.y.Pgain [AXIS_1]P setp pid.y.Igain [AXIS_1]I setp pid.y.Dgain [AXIS_1]D setp pid.y.bias [AXIS_1]BIAS setp pid.y.FF0 [AXIS_1]FF0 setp pid.y.FF1 [AXIS_1]FF1 setp pid.y.FF2 [AXIS_1]FF2 setp pid.y.deadband [AXIS_1]DEADBAND setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT setp pid.y.error-previous-target true net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-vel-cmd => pid.y.command-deriv net y-pos-fb => pid.y.feedback net y-output => pid.y.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT net y-output => hm2_5i25.0.7i77.0.1.analogout1 net y-pos-cmd axis.1.motor-pos-cmd net y-enable axis.1.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.01.counter-mode 0 setp hm2_5i25.0.encoder.01.filter 1 setp hm2_5i25.0.encoder.01.index-invert 0 setp hm2_5i25.0.encoder.01.index-mask 0 setp hm2_5i25.0.encoder.01.index-mask-invert 0 setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE net y-pos-fb <= hm2_5i25.0.encoder.01.position net y-vel-fb <= hm2_5i25.0.encoder.01.velocity net y-pos-fb => axis.1.motor-pos-fb net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts # ---setup home / limit switch signals--- net home-y => axis.1.home-sw-in net min-y => axis.1.neg-lim-sw-in net max-y => axis.1.pos-lim-sw-in #******************* # AXIS Z #******************* setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT net z-output => hm2_5i25.0.7i77.0.1.analogout2 net z-pos-cmd axis.2.motor-pos-cmd net z-enable axis.2.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.02.counter-mode 0 setp hm2_5i25.0.encoder.02.filter 1 setp hm2_5i25.0.encoder.02.index-invert 0 setp hm2_5i25.0.encoder.02.index-mask 0 setp hm2_5i25.0.encoder.02.index-mask-invert 0 setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE net z-pos-fb <= hm2_5i25.0.encoder.02.position net z-vel-fb <= hm2_5i25.0.encoder.02.velocity net z-pos-fb => axis.2.motor-pos-fb net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts # ---setup home / limit switch signals--- net home-z => axis.2.home-sw-in net min-z => axis.2.neg-lim-sw-in net max-z => axis.2.pos-lim-sw-in #******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command net spindle-vel-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE_9]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT net spindle-output => hm2_5i25.0.7i77.0.1.analogout5 net spindle-enable => hm2_5i25.0.7i77.0.1.spinena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.05.counter-mode 0 setp hm2_5i25.0.encoder.05.filter 1 setp hm2_5i25.0.encoder.05.index-invert 0 setp hm2_5i25.0.encoder.05.index-mask 0 setp hm2_5i25.0.encoder.05.index-mask-invert 0 setp hm2_5i25.0.encoder.05.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_5i25.0.encoder.05.position net spindle-vel-fb-rps <= hm2_5i25.0.encoder.05.velocity net spindle-index-enable <=> hm2_5i25.0.encoder.05.index-enable # ---setup spindle control signals--- net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-enable <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-pos halui.jog.0.plus net jog-x-neg halui.jog.0.minus net jog-x-analog halui.jog.0.analog net joint-select-b halui.joint.1.select net y-is-homed halui.joint.1.is-homed net jog-y-pos halui.jog.1.plus net jog-y-neg halui.jog.1.minus net jog-y-analog halui.jog.1.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-pos halui.jog.2.plus net jog-z-neg halui.jog.2.minus net jog-z-analog halui.jog.2.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net jog-speed halui.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in ###################################### # ---automatic tool change signals--- net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared #in net magazine-CW-req-fetch carousel.0.motor-fwd classicladder.0.in-14 net magazine-CCW-req-fetch carousel.0.motor-rev classicladder.0.in-15 net tool-change iocontrol.0.tool-change classicladder.0.in-00 net magazine-fwd-switch hm2_5i25.0.7i77.0.0.input-11 classicladder.0.in-09 net magazine-back-switch hm2_5i25.0.7i77.0.0.input-10 classicladder.0.in-08 net magazine-home-switch hm2_5i25.0.7i77.0.0.input-15 carousel.0.sense-0 net magazine-position-switch hm2_5i25.0.7i77.0.0.input-14 carousel.0.sense-1 net magazine-up-switch hm2_5i25.0.7i77.0.0.input-12 classicladder.0.in-10 net magazine-dwn-switch hm2_5i25.0.7i77.0.0.input-13 classicladder.0.in-11 net orient-complete hm2_5i25.0.7i77.0.0.input-20 classicladder.0.in-07 net unclamp-tool hm2_5i25.0.7i77.0.0.input-16 classicladder.0.in-03 net unclamp-tool-position hm2_5i25.0.7i77.0.0.input-17 classicladder.0.in-02 net carousel-in-position classicladder.0.in-19 <= carousel.0.ready #out net spindle-orient classicladder.0.out-04 hm2_5i25.0.7i77.0.0.output-05 net magazine-cw classicladder.0.out-12 hm2_5i25.0.7i77.0.0.output-03 net magazine-ccw classicladder.0.out-03 hm2_5i25.0.7i77.0.0.output-04 net tool-unclamp classicladder.0.out-05 hm2_5i25.0.7i77.0.0.output-07 net magazine-down classicladder.0.out-11 <= hm2_5i25.0.7i77.0.0.output-02 net magazine-fwd classicladder.0.out-06 <= hm2_5i25.0.7i77.0.0.output-01 net tool-changed iocontrol.0.tool-changed classicladder.0.out-07 #net magazine-position classicladder.0.s32out-01 mod-dir.0.actual net mod-desired-position iocontrol.0.tool-prep-number carousel.0.pocket-number net rotate-carousel carousel.0.enable classicladder.0.out-13
Lagunmatic_3516-SX.INI:
# Generated by PNCconf at Fri Apr 27 02:57:57 2018 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = Lagunmatic_3516-SX DEBUG = 0 [DISPLAY] DISPLAY = axis #DISPLAY = gmoccapy POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 2.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/treid/linuxcnc/nc_files #PYVCP = pyvcp-panel.xml ## PYVCP = shizuoka.xml INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 1.000000 MAX_LINEAR_VELOCITY = 2.500000 MIN_LINEAR_VELOCITY = 0.000167 DEFAULT_ANGULAR_VELOCITY = 6.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyz [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 1000000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 [HAL] HALUI = halui HALFILE = Lagunmatic_3516-SX.hal HALFILE = custom.hal #POSTGUI_HALFILE = postgui_call_list.hal ## POSTGUI_HALFLIFE = shizuoka-pyvcp.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 0.20 MAX_LINEAR_VELOCITY = 2.00 NO_FORCE_HOMING = 1 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl TOOL_CHANGE_QUILL_UP = 1 #tool turret info #TOOL_TURRET_MAX = 17 #TOOL_TURRET_WRAP = 1 #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 105.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.259 FF2 = 0.006 BIAS = 0.0 DEADBAND = 0.0001 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -0.001 MAX_LIMIT = 26.4 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 1 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 30.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 0.08 FF2 = 0.0005 BIAS = 0.0001 DEADBAND = 0.0 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -0.001 MAX_LIMIT = 16.0 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = -1.000000 HOME_LATCH_VEL = -0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 2 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 0.02 MIN_FERROR = 0.02 MAX_VELOCITY = 2.0 MAX_ACCELERATION = 10.0 P = 60.0 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 0.91 FF2 = 0.005 BIAS = 0.0 DEADBAND = 0.0001 MAX_OUTPUT = 0.0 ENCODER_SCALE = 20320.0 OUTPUT_SCALE = -10.0 OUTPUT_MIN_LIMIT = -10.0 OUTPUT_MAX_LIMIT = 10.0 MIN_LIMIT = -20.5 MAX_LIMIT = 0.05 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL = 1.000000 HOME_LATCH_VEL = 0.166667 HOME_FINAL_VEL = 0.166667 HOME_USE_INDEX = YES HOME_SEQUENCE = 0 #******************** # Spindle #******************** [SPINDLE_9] P = 5.0 I = 0.0 D = 0.0 FF0 = 1.0 FF1 = 0.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 10000.0 ENCODER_SCALE = 4096.0 OUTPUT_SCALE = 10000 OUTPUT_MIN_LIMIT = -10000 OUTPUT_MAX_LIMIT = 10000
shizuoka-pyvcp.HAL:
#net seconds classicladder.0.s32out-05 pyvcp.seconds-number #net minutes classicladder.0.s32out-04 pyvcp.minutes-number #net hours classicladder.0.s32out-06 pyvcp.hours-number #linksp Spindle-rpm-cmd pyvcp.spindle-speed net tool-num-display carousel.0.current-position pyvcp.tool-number net tool-release-button pyvcp.tool-release-button classicladder.0.in-16 #net mpg-x axis.0.jog-enable <= pyvcp.axis-selection.X_AXIS #net mpg-y axis.1.jog-enable <= pyvcp.axis-selection.Y_AXIS #net mpg-z axis.2.jog-enable <= pyvcp.axis-selection.Z_AXIS #net mpg-a-axis axis.3.jog-enable <= pyvcp.axis-selection.A_AXIS #net scale1 mux4.0.sel0 <= pyvcp.feed-multiplier..0010in #net scale2 mux4.0.sel1 <= pyvcp.feed-multiplier..0100in net esc-button halui.program.stop pyvcp.stop-execution
8 years 2 months ago #115658 by giz
Today was really rough. I've been studying everything I can find related to ATC and spindle orientation and I am just about where I left off yesterday (I did figure out my spindle encoder was reversed - which wasn't the magic fix I was hoping it would be).
For awhile I started to port over andy's vmc.index config but wasn't able to successfully launch my own interpretation. It was difficult to parse through what was essential and what was only needed for the simulation. I also couldn't find how to map the various M codes.
I think I am really close with Lunada's classicladder program, written for this very same machine, so I'd really like to stick to that.
I just can't figure out how to orient the spindle and it is KILLING ME
8 years 2 months ago #115659 by lunada
Replied by lunada on topic Lagunmatic 3516-SX Retrofit
i didn't have an encoder on my spindle, so i guess i probably am not much help. My machine had an input to orient the spindle, and an output for orient complete. made it really simple. Are you sure you don't have that on yours?
Is there an index line on the encoder on the spindle? If so, i'm sure you can use your encoder to determine the position of the spindle for the toolchange.
Have you called dynapath or lagunmatic? I seem to remember getting some info from one of them for my specific machine.
Wish i could help ya man, i'm just not very good at this stuff. I wonder if you could just line your index line on your spindle up with the spindle orient position and link to an input in classicladder so you just rotate until the input goes true? kind of ghetto but it may work, i have no idea.
8 years 2 months ago - 8 years 2 months ago #115660 by giz
lunada wrote: i didn't have an encoder on my spindle, so i guess i probably am not much help. My machine had an input to orient the spindle, and an output for orient complete. made it really simple. Are you sure you don't have that on yours?
I'm clearly no good myself! Haha. Thanks for chiming in
My factory spindle VFD was DOTA and I replaced it with something more modern, so I don't have the built-in signals you are using. This seems painfully obvious now why I can't plug-and-play your ladder program, but honestly I couldn't understand completely where the signals were originating. But this does explain some of my confusion when comparing INI files...
Lagunmatic has helped in the past, Dynapath not so much. This community here has been the absolute best resource! No way I could have made it this far without some very helpful and patient people.
My encoder is connected 1:1 to the spindle cartridge and I can read it's position in HAL Meter under spindle.rev. I know I should be able to use this feedback to home, move to an preset index position, and then do all that as part of a tool change procedure but I'm stuck there. I'm guessing the answer is somewhere in the Spindle Control documentation and andy's spindle.hal file:
# HAL config file for vismach simulation of vertical milling machine # This file deomstrates closed-loop spindle control in both position and # Velocity modes. # see http://wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient for a diagram # Note that the connections of the signals to "hardware" are all in the # sim_vmc.hal file rather than here # First load 2x pid components. These would normally have to be loaded at # the same time as the Axis PID components loadrt pid num_chan=2 addf pid.0.do-pid-calcs servo-thread # Velocity addf pid.1.do-pid-calcs servo-thread # Position loadrt orient addf orient.0 servo-thread #loadrt mux2 -- This has already been loaded in the sim_vmc.hal addf mux2.0 servo-thread # chooses which pid output goes to the spindle speed control net spindle-pos pid.1.feedback orient.0.position net spindle-vel pid.0.feedback # & encoder.3.velocity for a real machine net spindle-vel-cmd motion.spindle-speed-out pid.0.command net spindle-vel-pid pid.0.output mux2.0.in0 net spindle-pos pid.1.feedback orient.0.position near.0.in1 # & encoder.3.position for a real machine net spindle-pos-cmd orient.0.command pid.1.command near.0.in2 net spindle-angle motion.spindle-orient-angle orient.0.angle net spindle-pos-pid pid.1.output mux2.0.in1 net spindle-in-pos orient.0.is-oriented motion.spindle-is-oriented # this switches modes net orient-mode motion.spindle-orient orient.0.enable pid.1.enable mux2.0.sel net velocity-mode motion.spindle-on pid.0.enable #pwmgen.0.enable net orient-dir motion.spindle-orient-mode orient.0.mode # this is simple for the simulated spindle. net spindle-cmd mux2.0.out #for a real spindle run by a VFD # loadrt abs # addf abs.0.servo-thread # net spindle-cmd mux2.0.out abs.0.in # net spindle-cmd-abs abs.0.out pwmgen.0.value # net spindle-pwm pwmgen.0.pwm parport.0.pin-NN-out # net spindle-fwd abs.0.is-positive parport.0.pin-NN-out # net spindle-rev abs.0.is-negative parport.0.pin-NN-out # Tune the PID from the INI values setp pid.0.Pgain [SPINDLE]PGAIN_V setp pid.0.Igain [SPINDLE]IGAIN_V setp pid.0.Dgain [SPINDLE]DGAIN_V setp pid.0.FF0 [SPINDLE]FF0_V setp pid.0.FF1 [SPINDLE]FF1_V setp pid.1.Pgain [SPINDLE]PGAIN_P setp pid.1.Igain [SPINDLE]IGAIN_P setp pid.1.Dgain [SPINDLE]DGAIN_P setp pid.1.FF0 [SPINDLE]FF0_P setp pid.1.FF1 [SPINDLE]FF1_P
I'll probably create a thread somewhere else in the forum for higher visibility
Last edit: 8 years 2 months ago by giz.
8 years 2 months ago #115666 by andypugh
Replied by andypugh on topic Lagunmatic 3516-SX Retrofit
The trick in this case is probably to use the M19 spindle orient G-code.
Then use the "orient" HAL component to calculate the nearest point that satisfies that angle.
(Or you could use classic ladder to output a fixed orient angle, it is unlikely to change).
If using CL to source the orient command / angle then the outputs from the "motion" block there would come from CL when a tool change was active. (spindle-speed-out for normal machining would still come from motion).
The VMC-toolchange simulator does it all with G-code. The best starting point with that is probably to look at the G-code sequence that handles the change. It uses M19 to orient the spindle and the carousel component (controlled by M6) to move the tool changer.
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
8 years 2 months ago - 8 years 2 months ago #115708 by giz
andypugh wrote: The trick in this case is probably to use the M19 spindle orient G-code.
Thanks andy. I'm going to try the M19/remapped M6 route. I understand I need to implement the two PID components found in spindle.hal to make this work.
I'm struggling to integrate the code I see in spindle.hal with the spindle section of the HAL file generated by PNCconf. Deciphering what stays, what goes, which pins are being called, etc is very difficult for me so far. I'll keep working at it...
Time to create page: 1.888 seconds
