- Thank you received: 11
Lagunmatic 3516-SX Retrofit
- giz
8 years 2 months ago #115818
by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
Awesome - thanks for the confirmation andy. I did use that line of code at some point last night but I didn't see movement at the spindle, hence the question about the PID.
I'm fairly certain I checked the status of spindle-enable in both situations but I'll double-check.
If nothing else, this particular struggle has really helped me understand the structure and syntax of LinuxCNC. Definitely feeling more comfortable about what is actually happening
- giz
8 years 2 months ago #115840
by giz
Best update of the night is that I remeasured the height of the machine and, as long as I take off the Z-axis servo, it turns out I will be able to fit this machine into the new house. The garage has 8ft doors the tallest permanent hard spot is about 88". YES!!
Ok - so Andy was right about the spindle enable preventing movement. However, I cannot for the life of me figure out how to incorporate it into the logic. Because I have the velocity-mode signal connected to motion.spindle-on I don't seem to be able to drive hm2_5i25.0.7i77.0.1.spinena with motion.spindle-on (through the spindle-enable signal that is standard).
I've racked my brain over and over but I can't come up with a solution - advice?
To keep progressing, I started my config using the .hal below and used halcmd to sets spindle-enable true. This gave me signal on analogout5 in both modes (success) but only resulted in movement when I was in velocity mode.
So once I can get the spindle enabled in both modes, then I need to:
1) determine why there is no motion in orient mode
2) scale the spindle speed correctly
The two might be related? I found a diagram that shows a similar logic setup for position vs. velocity mode that incorporates some scaling but I haven't fully digested it yet. It seems to be setup differently than how I have it now (where 1 spindle revolution = +1 encoder position).
spindle hal section below. It's been cleaned up, I left my attempt at using an or2 component to flip the spindle-enable but, again, I run into the issue of the pins already being in use.
Current spindle PID section for reference. Just playing with numbers right now to see if they affected the motion:
# SPINDLE S
setp pid.s.Pgain [SPINDLE]P
setp pid.s.Igain [SPINDLE]I
setp pid.s.Dgain [SPINDLE]D
setp pid.s.bias [SPINDLE]BIAS
setp pid.s.FF0 [SPINDLE]FF0
setp pid.s.FF1 [SPINDLE]FF1
setp pid.s.FF2 [SPINDLE]FF2
setp pid.s.deadband [SPINDLE]DEADBAND
setp pid.s.maxoutput [SPINDLE]MAX_OUTPUT
setp pid.s.error-previous-target true
setp pid.1.Pgain [SPINDLE]PGAIN_P
setp pid.1.Igain [SPINDLE]IGAIN_P
setp pid.1.Dgain [SPINDLE]DGAIN_P
setp pid.1.FF0 [SPINDLE]FF0_P
setp pid.1.FF1 [SPINDLE]FF1_P
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE]OUTPUT_MAX_LIMIT
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => hm2_5i25.0.7i77.0.1.spinena
net spindle-pos pid.1.feedback orient.0.position
net spindle-vel pid.s.feedback hm2_5i25.0.encoder.05.velocity
net spindle-vel-cmd motion.spindle-speed-out pid.s.command
#net spindle-vel-cmd motion.spindle-speed-out-rps pid.s.command
net spindle-vel-pid pid.s.output mux2.0.in0
net spindle-pos pid.1.feedback orient.0.position near.0.in1 hm2_5i25.0.encoder.05.position
net spindle-pos-cmd orient.0.command pid.1.command near.0.in2
net spindle-angle motion.spindle-orient-angle orient.0.angle
net spindle-pos-pid pid.1.output mux2.0.in1
setp near.0.difference 0.0005
net spindle-in-pos-raw near.0.out edge.0.in #not needed v2.8+, use orient.0.is-oriented
net spindle-in-pos edge.0.out motion.spindle-is-oriented
# this switches modes
net orient-mode motion.spindle-orient orient.0.enable pid.1.enable mux2.0.sel
net velocity-mode motion.spindle-on pid.s.enable #hm2_5i25.0.7i77.0.1.spinena
net orient-dir motion.spindle-orient-mode orient.0.mode
setp hm2_5i25.0.encoder.05.counter-mode 0
setp hm2_5i25.0.encoder.05.filter 1
setp hm2_5i25.0.encoder.05.index-invert 0
setp hm2_5i25.0.encoder.05.index-mask 0
setp hm2_5i25.0.encoder.05.index-mask-invert 0
setp hm2_5i25.0.encoder.05.scale [SPINDLE]ENCODER_SCALE
net spindle-cmd mux2.0.out hm2_5i25.0.7i77.0.1.analogout5
net spindle-index-enable <=> hm2_5i25.0.encoder.05.index-enable
#loadrt or2
#addf or2.0 servo-thread
#net velocity-enable or2.0.in0 pid.s.enable
#net position-enable or2.0.in1 pid.1.enable
#net spindle-enable or2.0.out
#net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
#net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
#net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-pos => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# Spindle
[SPINDLE]
P = 5
I = 0
D = 0.0
FF0 = 1
FF1 = 0.0
FF2 = 0.0
PGAIN_P = 60
IGAIN_P = 0
DGAIN_P = 0
FF0_P = 1
FF1_P = 0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 10000.0
ENCODER_SCALE = -4096.0
OUTPUT_SCALE = 10000
OUTPUT_MIN_LIMIT = -10000
OUTPUT_MAX_LIMIT = 10000
- giz
8 years 2 months ago #115841
by giz
The lack of movement may also be related to some setting in my VFD. I have noticed that the minimum spindle speed to initiate movement is lower than I expected. As far as the VFD is concerned, it thinks it is running in open loop between a min and max frequency
- giz
8 years 2 months ago #115855
by giz
Here is the schematic I found last night that may be helpful. It seems to address the spindle enable and scaling. I haven't fully digested it yet.
The following user(s) said Thank You: Becksvill
- raglanlittlejohn
- Thank you received: 9
8 years 2 months ago #115878
by raglanlittlejohn
Replied by raglanlittlejohn on topic Lagunmatic 3516-SX Retrofit
giz,
I did the schematic earlier this year. I was struggling to understand how the orient component worked, and found it easier to follow a schematic. I did get this working using a new Huangyang vfd which had sensorless vector control. The idea was to orient a lathe spindle. It worked well, getting the position within about 1 degree.
There is no pid for the normal speed, that is controlled by a variable voltage output to the vfd. I planned to use a disc with say 12 holes on the spindle, and a pin that would be engaged in the appropriate hole, when the spindle orientated signal came in. I think that would work, but I have not finished that part of the project yet.
- giz
8 years 2 months ago #115890
by giz
Awesome, thanks John. Funny you mention it - my plan today is to switch the VFD over to closed-loop vector control. It's running v/f right now and I think that might be why I don't see any movement during the M19 cycle (or at least, it isn't helping).
Im looking into how I can possibly use your scaling and logic components to make my current Hal work as intended.
Time to create page: 1.826 seconds
