PCW wrote: Index will only clear the spindle position if index enable is true
Can you post your existing HAL and INI files? That might help with diagnosing you tuning and spindle issues
Absolutely! Here they are:
lagunmatic.hal
# Generated by PNCconf at Fri Apr 27 02:57:57 2018
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.p
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.p.do-pid-calcs servo-thread # Position
addf hm2_5i25.0.write servo-thread
loadrt orient
addf orient.0 servo-thread
setp orient.0.mode 0
loadrt mux2
addf mux2.0 servo-thread #Chooses which speed output goes to spindle
loadrt or2 count=2
addf or2.0 servo-thread #Enables spindle in both modes
addf or2.1 servo-thread #Activate Spindle Run relay
loadrt and2
addf and2.0 servo-thread
loadrt near count=3
loadrt edge
addf near.0 servo-thread
addf near.1 servo-thread
addf near.2 servo-thread
addf edge.0 servo-thread
setp edge.0.both 0
setp edge.0.in-edge 0
setp edge.0.out-width-ns 10000000
setp near.0.difference 0.001667 #How close the spindle needs to orient in revs
setp near.1.scale 1.05 #Spindle-at-speed true within scale
setp near.2.difference .5 #Check spindle velocity for near zero
net zero-speed near.2.in1
sets zero-speed 0
loadrt scale count=2
addf scale.0 servo-thread #RPS to RPM
addf scale.1 servo-thread #Motor to Spindle Ratio
setp scale.0.gain 60
setp scale.0.offset 100
setp scale.1.gain 0.8
# external output signals
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled hm2_5i25.0.7i77.0.0.output-00
# --- MAGAZINE_FORWARD ---
net Magazine_Forward hm2_5i25.0.7i77.0.0.output-01
# --- MAGAZINE_DOWN ---
net Magazine_Down hm2_5i25.0.7i77.0.0.output-02
# --- MAGAZINE_CW ---
net Magazine_CW hm2_5i25.0.7i77.0.0.output-03
# --- MAGAZINE_CCW ---
net Magazine_CCW hm2_5i25.0.7i77.0.0.output-04
# --- SPINDLE_ORIENT ---
net Spindle_Orient hm2_5i25.0.7i77.0.0.output-05
# --- SPINDLE-MOVE ---
#net spindle-enable hm2_5i25.0.7i77.0.0.output-06
# --- TOOL_UNCLAMP ---
net Tool_Unclamp hm2_5i25.0.7i77.0.0.output-07
# --- COOLANT-MIST ---
#net coolant-mist hm2_5i25.0.7i77.0.0.output-08
# --- LUBE_RELAY ---
net Lube_Relay hm2_5i25.0.7i77.0.0.output-10
# --- SOFT_START_CANCEL ---
net Soft_Start_Cancel hm2_5i25.0.7i77.0.0.output-11
# external input signals
# --- WAY_LUBE_LEVEL ---
net Way_Lube_Level <= hm2_5i25.0.7i77.0.0.input-00
# --- MAX-X ---
net max-x <= hm2_5i25.0.7i77.0.0.input-01-not
# --- MIN-X ---
net min-x <= hm2_5i25.0.7i77.0.0.input-02-not
# --- MAX-Y ---
net max-y <= hm2_5i25.0.7i77.0.0.input-03-not
# --- MIN-Y ---
net min-y <= hm2_5i25.0.7i77.0.0.input-04-not
# --- MAX-Z ---
net max-z <= hm2_5i25.0.7i77.0.0.input-05-not
# --- MIN-Z ---
net min-z <= hm2_5i25.0.7i77.0.0.input-06-not
# --- HOME-X ---
net home-x <= hm2_5i25.0.7i77.0.0.input-07
# --- HOME-Y ---
net home-y <= hm2_5i25.0.7i77.0.0.input-08
# --- HOME-Z ---
net home-z <= hm2_5i25.0.7i77.0.0.input-09
# --- MAGAZINE_BACK_POSITION ---
net Magazine_Back_Position <= hm2_5i25.0.7i77.0.0.input-10
# --- MAGAZINE_FORWARD_POSITION ---
net Magazine_Forward_Position <= hm2_5i25.0.7i77.0.0.input-11
# --- MAGAZINE_UP_POSITION ---
net Magazine_Up_Position <= hm2_5i25.0.7i77.0.0.input-12
# --- MAGAZINE_DOWN_POSITION ---
net Magazine_Down_Position <= hm2_5i25.0.7i77.0.0.input-13
# --- POSITION_COUNTER ---
net Position_Counter <= hm2_5i25.0.7i77.0.0.input-14
# --- MAGAZINE_HOME ---
net Magazine_Home <= hm2_5i25.0.7i77.0.0.input-15
# --- TOOL_CLAMP_POSITION ---
#net Tool_Clamp_Position <= hm2_5i25.0.7i77.0.0.input-16
# --- TOOL_UNCLAMP_POSITION ---
#net Tool_Unclamp_Position <= hm2_5i25.0.7i77.0.0.input-17
# --- SPINDLE_UP_TO_SPEED ---
net Spindle_Up_To_Speed <= hm2_5i25.0.7i77.0.0.input-18
# --- ESTOP ---
net ESTOP <= hm2_5i25.0.7i77.0.0.input-19
# --- SPINDLE_ORIENT_COMPLETE ---
net Spindle_Orient_Complete <= hm2_5i25.0.7i77.0.0.input-20
# --- LUBE_PRESSURE_SWITCH ---
net Lube_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-21-not
# --- AIR_PRESSURE_SWITCH ---
net Air_Pressure_Switch <= hm2_5i25.0.7i77.0.0.input-22
# --- MACHINE_ON_CMD ---
net Machine_On_CMD <= hm2_5i25.0.7i77.0.0.input-23
# --- SPINDLE_ON_CMD ---
net Spindle_On_CMD <= hm2_5i25.0.7i77.0.0.input-24
# --- TOOL_UNCLAMP_CMD ---
net Tool_Unclamp_CMD <= hm2_5i25.0.7i77.0.0.input-25
# --- MIST_ON_CMD ---
net Mist_On_CMD <= hm2_5i25.0.7i77.0.0.input-26
# --- MAGAZINE_CW_CMD ---
net Magazine_CW_CMD <= hm2_5i25.0.7i77.0.0.input-27
# --- MAGAZINE_CCW_CMD ---
net Magazine_CCW_CMD <= hm2_5i25.0.7i77.0.0.input-28
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_5i25.0.7i77.0.1.analogena
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net min-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net home-y => axis.1.home-sw-in
net min-y => axis.1.neg-lim-sw-in
net max-y => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.02.position
net z-vel-fb <= hm2_5i25.0.encoder.02.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
net home-z => axis.2.home-sw-in
net min-z => axis.2.neg-lim-sw-in
net max-z => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.p.Pgain [SPINDLE]P_P
setp pid.p.Igain [SPINDLE]I_P
setp pid.p.Dgain [SPINDLE]D_P
setp pid.p.FF0 [SPINDLE]FF0_P
setp pid.p.FF1 [SPINDLE]FF1_P
setp hm2_5i25.0.encoder.05.counter-mode 0
setp hm2_5i25.0.encoder.05.filter 1
setp hm2_5i25.0.encoder.05.index-invert 0
setp hm2_5i25.0.encoder.05.index-mask 0
setp hm2_5i25.0.encoder.05.index-mask-invert 0
setp hm2_5i25.0.encoder.05.scale [SPINDLE]ENCODER_SCALE
setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE]OUTPUT_MAX_LIMIT
## Velocity Mode ##
net spindle-vel-rps hm2_5i25.0.encoder.05.velocity motion.spindle-speed-in near.2.in2
net velocity-enable motion.spindle-on or2.0.in0
net spindle-vel-rpm motion.spindle-speed-out mux2.0.in0
net spindle-no-vel near.2.out and2.0.in0
## Orient Mode ##
net spindle-pos-rev hm2_5i25.0.encoder.05.position
net spindle-pos-rev pid.p.feedback orient.0.position near.0.in1 motion.spindle-revs
net orient-enable motion.spindle-orient pid.p.enable orient.0.enable mux2.0.sel or2.0.in1
net orient-mode motion.spindle-orient-mode orient.0.mode
net spindle-index motion.spindle-index-enable hm2_5i25.0.encoder.05.index-enable
net spindle-angle motion.spindle-orient-angle orient.0.angle
net spindle-pos-cmd pid.p.command orient.0.command near.0.in2
net spindle-in-pos-raw near.0.out edge.0.in #not needed v2.8+, use orient.0.is-oriented
net spindle-in-pos edge.0.out and2.0.in1 #motion.spindle-is-oriented
net spindle-pid-out pid.p.output scale.0.in
net spindle-pid-rpm scale.0.out mux2.0.in1
## Spindle Output##
net spindle-cmd-rpm mux2.0.out scale.1.in
net spindle-cmd-vfd scale.1.out hm2_5i25.0.7i77.0.1.analogout5
net spindle-enable or2.0.out hm2_5i25.0.7i77.0.1.spinena hm2_5i25.0.7i77.0.0.output-06
net orient-complete and2.0.out motion.spindle-is-oriented
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-brake <= motion.spindle-brake
#sets spindle-at-speed true
net spindle-vel-cmd-rps motion.spindle-speed-out-rps near.1.in1
net spindle-at-speed motion.spindle-at-speed near.1.out
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
lagunmatic.ini
[EMC]
MACHINE = Lagunmatic_3516-SX
DEBUG = 0
[DISPLAY]
DISPLAY = axis
#DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 2.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/treid/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 1.000000
MAX_LINEAR_VELOCITY = 2.500000
MIN_LINEAR_VELOCITY = 0.000167
DEFAULT_ANGULAR_VELOCITY = 6.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = Lagunmatic_3516-SX.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.20
MAX_LINEAR_VELOCITY = 2.00
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.02
MIN_FERROR = 0.02
MAX_VELOCITY = 2.0
MAX_ACCELERATION = 10.0
P = 105.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.259
FF2 = 0.006
BIAS = 0.0
DEADBAND = 0.0001
MAX_OUTPUT = 0.0
ENCODER_SCALE = 20320.0
OUTPUT_SCALE = -10.0
OUTPUT_MIN_LIMIT = -10.0
OUTPUT_MAX_LIMIT = 10.0
MIN_LIMIT = -0.001
MAX_LIMIT = 26.4
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.166667
HOME_FINAL_VEL = 0.166667
HOME_USE_INDEX = YES
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.02
MIN_FERROR = 0.02
MAX_VELOCITY = 2.0
P = 30.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.08
FF2 = 0.0005
BIAS = 0.0001
DEADBAND = 0.0
MAX_OUTPUT = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 16.0
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.02
MIN_FERROR = 0.02
MAX_VELOCITY = 2.0
P = 60.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.91
FF2 = 0.005
BIAS = 0.0
DEADBAND = 0.0001
MAX_OUTPUT = 0.0
MIN_LIMIT = -20.5
MAX_LIMIT = 0.05
HOME_SEARCH_VEL = 1.000000
HOME_LATCH_VEL = 0.166667
HOME_SEQUENCE = 0
# Spindle
[SPINDLE] **Spindle velocity PID not in use**
P = 5
I = 0
D = 0.0
FF0 = 1
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 10000.0
ENCODER_SCALE = -4096.0
OUTPUT_SCALE = 10000
OUTPUT_MIN_LIMIT = -10000
OUTPUT_MAX_LIMIT = 10000
P_P = 10
I_P = .5
D_P = 0
FF0_P = 0.0
FF1_P = 0.00
DEADBAND_P = 0.001
MAX_OUTPUT_P = 1
BIAS_P = 0.0
MAXI_P = 20.0
MAXD_P = 20.0
MAXERROR_P = 250.0
