- Thank you received: 11
Lagunmatic 3516-SX Retrofit
- giz
andypugh wrote: I think you might be seeing I-term windup if it oscillates. Does it still oscillate with an I-term of zero?
My methodology was to start with all zeros and first determine an appropriate P value. P=0.125 (everything else zero) will oscillate and the error curve is essentially a stable sine wave. It will never converge in this condition.
If I remember correctly, lowering the P from there would mean sometimes the spindle wouldn't move at all.
I didn't see any convergence until I started adding an I value.
- Thank you received: 5334
For a velocity command input, velocity PID output loop FF0 =1 means you start with the PID output just following the command. If all other PID parameters are 0, this is open loop but it should be close. Next the P and I term values can be added to correct any deviations in the open loop control
- giz
PCW wrote: I think for spindles you should always start with FF0=1 only
Does this still apply if I am trying to control the position of the spindle instead of the velocity?
I experimented with the FF0 values in the .90 to 1.0 range and didn't see much of a benefit
- giz
PCW wrote: No, for position control but velocity PID output (to VFD in this case), you want FF1 = 1.0 and typically FF0 =0
I'll add these tonight and see how it affects the performance. Thanks!
- giz
Have to admit - the struggles with the orient have really discouraged me as well. This has been a long journey and I naively thought I was close to finishing :laugh:
Right now I'm mostly thinking about how I am going to move this damn thing. I don't have a budget for a real rigger so right now I'm thinking about hiring a tow truck to winch the machine up while rolling on pipes. And at my new place, using my truck to winch it into the garage the same way.
