Lagunmatic 3516-SX Retrofit
9 years 10 months ago #84650 by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
That looks great, very jealous right now. Any details you can share I'd really appreciate.
What boards are your servo amps plugged into?
9 years 10 months ago - 9 years 10 months ago #84651 by lunada
Replied by lunada on topic Lagunmatic 3516-SX Retrofit
No eBay APP ID and/or Cert ID defined in Kunena configurationthanks!
I'm using something like these, except the female version i believe:
i made brackets for din rail mounts so they are all on din rail. it's still not finished, i need to mount and wire in the 24v power supply a little cleaner, and so it stays on when i kill machine power, since the 7i77 will throw a fit if you kill field power with linux running.
This machine is super easy to wire. with the schematics and breakout boards. The only thing i screwed up is the limit switches... i decided to share them (+ and - switches on the same input), which doesnt work since they happen to be NC switches. Easy fix though.
Last edit: 9 years 10 months ago by lunada.
9 years 9 months ago #85625 by giz
lunada - how is progress going? I am planning to pick this back up come February.
I'd love to piggyback off your progress if you don't mind sharing your config files. Do you have the ATC figured out yet?
9 years 9 months ago #85776 by lunada
i have the servos mostly tuned, and thats about it. i've had to work on other things around here so it'll be on the back burner for a week or two. remind me in a few weeks if i forget and ill give you the config files when i get a little further on them
9 years 9 months ago #86003 by giz
Awesome - will do! Good luck
9 years 8 months ago #87223 by lunada
i havent forgotten about uploading the files, i'm nearly done with them. i hit a snag with a mechanical problem, but i got most of it working, including the toolchanger. I'll upload the files once i'm done. How's yours going?
Time to create page: 1.132 seconds
