- Thank you received: 11
Lagunmatic 3516-SX Retrofit
- giz
9 years 8 months ago #87226
by giz
That is awesome! Good job, I'm really excited to see yours up and running.
The only thing I've been able to do on my end is order some breakout boards and start planning out the layout of the computer and VFD in their respective cabinets. It has been slow going.
I also ran into a mechanical problem I need to deal with. It looks like my spindle motor fan is dead so I need to source a replacement.
Replied by giz on topic Lagunmatic 3516-SX Retrofit
lunada wrote: i havent forgotten about uploading the files, i'm nearly done with them. i hit a snag with a mechanical problem, but i got most of it working, including the toolchanger. I'll upload the files once i'm done. How's yours going?
- lunada
9 years 8 months ago #87227
by lunada
Replied by lunada on topic Lagunmatic 3516-SX Retrofit
The nice thing is the existing wiring is well laid out and the schematics are good, so i could easily bench wire the sub panel with the breakout boards and computer. I've never had one go that smoothly.
That sucks about the spindle fan, but i wouldnt imagine it would be too difficult to replace. My gearmotor for the toolchanger carousel had some stripped teeth, so it failed after my second toolchange. i was fortunate enough to find one on ebay though.
- giz
9 years 8 months ago #87229
by giz
I agree, the wiring should go smoothly. I have a copy of the printed manual with all schematics and it has been a lifesaver so far. When I purchased my machine it was in pretty dire shape.
Pretty lucky to find a direct match! I found direct match for the Yaskawa fan motor/housing but they were about $350. I'm going to use an off the shelf fan (I believe 170MM) for about $50.
These old machines can be pretty stressful to update, you never know if something is going to cost $10 or $1000 to replace.
- lunada
9 years 8 months ago #87233
by lunada
yea they are stressful in general... i did the retrofit because i lost a board in the dynapath within a week of owning it. luckily they didn't seem to go too exotic or proprietary on the hardware in these things.
- giz
8 years 10 months ago #103329
by giz
Long time no updates!
I've set a goal to have this machine at least moving in XYZ by the end of the year, so here I am back at configuring LinuxCNC and waiting for some components to arrive so I can start wiring on the bench.
Lunada retrofitted an identical machine to mine, and was gracious enough to provide his config files. I've been scouring over them trying to reverse engineer the what was done and why. I have to admit, none of this is coming naturally but I'm trudging along.
I'm unsure about nearly everything, but I'm most unsure about the toolchanger right now. This set of files uses the classicladder "carousel pockets" component to handle the toolchanger. My basic plan right now is to use PNCconf to create my own set of config files (done) and then copy/paste the pertinent info from Lunada's files.
As I mentioned before, I replaced the original Yaskawa spindle drive with a Teco A510. I will tackle the spindle after I get the XYZ movement, but it's definitely on the back of my mind that I'll need to learn how to interface with the new spindle drive to orient, confirm speed, etc.
Any comments and advice would be appreciated. Here are the files:
lagunmatic.hal
lagunmatic.ini
shizuoka-pyvcp.hal
shizuoka.clp
And here is my current pin mapping based on the above hal file as a sanity check. I plan to do things a little bit different, such as using separate pins for limit +/-/home. I also don't quite know what some of the inputs are involving the magazine position and tool unclamping.
Outputs
Inputs
lagunmatic.hal
# Generated by PNCconf at Wed Dec 21 15:14:14 2016
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=4 num_pwmgens=1 num_stepgens=0 sserial_port_0=000xxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt threads name1=classicladder-thread period1=2000000
loadrt classicladder_rt numS32in=3 numS32out=8 numRungs=60 numBits=90 numWords=55 numTimers=27 numCounters=15 numPhysInputs=50 numPhysOutputs=50 numArithmExpr=25 numSections=6 numSymbols=220 numS32in=3 numS32out=9
loadusr -w classicladder --nogui shizuoka.clp
loadrt modmath mod_dir=1
loadrt carousel pockets=18 encoding=index num_sense=1 dir=2
addf carousel.0 servo-thread
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
addf classicladder.0.refresh classicladder-thread
# external output signals
# --- SPINDLE-CW ---
net spindle-cw hm2_5i25.0.7i77.0.0.output-00
# --- SPINDLE-CCW ---
net spindle-ccw hm2_5i25.0.7i77.0.0.output-01
# --- COOLANT-FLOOD ---
net coolant-flood hm2_5i25.0.7i77.0.0.output-02
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled hm2_5i25.0.7i77.0.0.output-03
# --- SPINDLE-INDEX-ENABLE ---
#net spindle-index-enable hm2_5i25.0.7i77.0.0.output-05
# --- LUBE ---
net lube hm2_5i25.0.7i77.0.0.output-13
# external input signals
# --- LUBE_LEVEL ---
net lube_level <= hm2_5i25.0.7i77.0.0.input-00
# --- BOTH-X ---
net both-x <= hm2_5i25.0.7i77.0.0.input-01-not
# --- BOTH-Y ---
net both-y <= hm2_5i25.0.7i77.0.0.input-02-not
# --- BOTH-Z ---
net both-z <= hm2_5i25.0.7i77.0.0.input-03-not
# --- HOME-X ---
net home-x <= hm2_5i25.0.7i77.0.0.input-04
# --- HOME-Y ---
net home-y <= hm2_5i25.0.7i77.0.0.input-05
# --- HOME-Z ---
net home-z <= hm2_5i25.0.7i77.0.0.input-06
# --- SPINDLE-AT-SPEED ---
net spindle-at-speed <= hm2_5i25.0.7i77.0.0.input-21
#setp hm2_5i25.0.7i77.0.1.analogout4-scalemax 5915
#setp hm2_[HOSTMOT2](BOARD).0.pwmgen.04.output-type 2
#net Spindle-rpm-cmd motion.spindle-speed-out => hm2_5i25.0.7i77.0.1.analogout4
#net spindle-index-enable <= hm2_5i25.0.7i77.0.0.input-24
# --- ESTOP-EXT ---
#net estop-ext <= hm2_5i25.0.7i77.0.0.input-26
# --- CYCLE-START ---
net cycle-start <= hm2_5i25.0.7i77.0.0.input-28
# --- ABORT ---
net abort <= hm2_5i25.0.7i77.0.0.input-29
# --- FEED-HOLD ---
net feed-hold <= hm2_5i25.0.7i77.0.0.input-30
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
#setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_5i25.0.7i77.0.1.analogena
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net both-x => axis.0.neg-lim-sw-in
net both-x => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
#setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net home-y => axis.1.home-sw-in
net both-y => axis.1.neg-lim-sw-in
net both-y => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
#setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
setp hm2_5i25.0.encoder.02.counter-mode 0
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.index-invert 0
setp hm2_5i25.0.encoder.02.index-mask 0
setp hm2_5i25.0.encoder.02.index-mask-invert 0
setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.02.position
net z-vel-fb <= hm2_5i25.0.encoder.02.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts
net home-z => axis.2.home-sw-in
net both-z => axis.2.neg-lim-sw-in
net both-z => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
#setp pid.s.maxerror .0005
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
#net spindle-vel-cmd-rpm <= motion.spindle-speed-out hm2_5i25.0.7i77.0.1.analogout4
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
loadrt scale count=1
addf scale.0 servo-thread
setp scale.0.gain 0.002
net spindle-speed-scale motion.spindle-speed-out => scale.0.in
net spindle-speed-DAC scale.0.out => hm2_5i25.0.7i77.0.1.analogout4
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---jogwheel signals to mesa encoder - shared MPG---
net joint-selected-count <= hm2_5i25.0.encoder.03.count
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
#net estop-out <= iocontrol.0.user-enable-out
#net estop-ext => iocontrol.0.emc-enable-in
net estop-loop iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in
# ---toolchange signals for custom tool changer---
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
#in
net magazine-CW-req-fetch carousel.0.motor-fwd classicladder.0.in-14
net magazine-CCW-req-fetch carousel.0.motor-rev classicladder.0.in-15
net tool-change iocontrol.0.tool-change classicladder.0.in-00
net magazine-fwd-switch hm2_5i25.0.7i77.0.0.input-11 classicladder.0.in-09
net magazine-back-switch hm2_5i25.0.7i77.0.0.input-10 classicladder.0.in-08
net magazine-home-switch hm2_5i25.0.7i77.0.0.input-15 carousel.0.sense-0
net magazine-position-switch hm2_5i25.0.7i77.0.0.input-14 carousel.0.sense-1
net magazine-up-switch hm2_5i25.0.7i77.0.0.input-12 classicladder.0.in-10
net magazine-dwn-switch hm2_5i25.0.7i77.0.0.input-13 classicladder.0.in-11
net orient-complete hm2_5i25.0.7i77.0.0.input-07 classicladder.0.in-07
net unclamp-tool hm2_5i25.0.7i77.0.0.input-18 classicladder.0.in-03
net unclamp-tool-position hm2_5i25.0.7i77.0.0.input-17 classicladder.0.in-02
net carousel-in-position classicladder.0.in-19 <= carousel.0.ready
#net reset classicladder.0.in-01 <= hm2_[HOSTMOT2](BOARD).0.gpio.039.in_not
#net program-running halui.program.is-running classicladder.0.in-07
#net program-is-auto halui.mode.is-auto classicladder.0.in-08
#net flood-coolant-out classicladder.0.out-07 hm2_[HOSTMOT2](BOARD).0.gpio.060.out
#net flood-coolant-io iocontrol.0.coolant-flood classicladder.0.in-09
#net flood-coolant-button hm2_[HOSTMOT2](BOARD).0.gpio.035.in classicladder.0.in-10
#out
net spindle-orient classicladder.0.out-04 hm2_5i25.0.7i77.0.0.output-04
net magazine-cw classicladder.0.out-12 hm2_5i25.0.7i77.0.0.output-09
net magazine-ccw classicladder.0.out-03 hm2_5i25.0.7i77.0.0.output-10
net tool-unclamp classicladder.0.out-05 hm2_5i25.0.7i77.0.0.output-06
net magazine-down classicladder.0.out-11 <= hm2_5i25.0.7i77.0.0.output-08
net magazine-fwd classicladder.0.out-06 <= hm2_5i25.0.7i77.0.0.output-07
net tool-changed iocontrol.0.tool-changed classicladder.0.out-07
#net magazine-position classicladder.0.s32out-01 mod-dir.0.actual
net mod-desired-position iocontrol.0.tool-prep-number carousel.0.pocket-number
net rotate-carousel carousel.0.enable classicladder.0.out-13
#net servo0-power-on classicladder.0.out-15 hm2_[HOSTMOT2](BOARD).0.pwmgen.00.enable
#net servo1-power-on classicladder.0.out-16 hm2_[HOSTMOT2](BOARD).0.pwmgen.01.enable
#net servo2-power-on classicladder.0.out-17 hm2_[HOSTMOT2](BOARD).0.pwmgen.02.enable
# "times 4 mode" one count per full quadrature cycle, instead of the usual one count per edge.
# mpg jog wheels often have a full quadrature cycle per "click". 0 for off and 1 for on.
#setp encoder.0.x4-mode 0
#setp axis.0.jog-vel-mode 1
#setp axis.1.jog-vel-mode 1
#setp axis.2.jog-vel-mode 1
#setp axis.3.jog-vel-mode 1
#setp mux4.0.in0 0.0001
#setp mux4.0.in1 0.001
#setp mux4.0.in2 0.01
#net pend-scale axis.0.jog-scale <= mux4.0.out
#net pend-scale axis.1.jog-scale
#net pend-scale axis.2.jog-scale
#net pend-scale axis.3.jog-scale
#net mpg-a encoder.0.phase-A <= hm2_[HOSTMOT2](BOARD).0.gpio.029.in
#net mpg-b encoder.0.phase-B <= hm2_[HOSTMOT2](BOARD).0.gpio.031.in
#net pend-counts axis.0.jog-counts <= encoder.0.counts
#net pend-counts axis.1.jog-counts
#net pend-counts axis.2.jog-counts
#net pend-counts axis.3.jog-counts
lagunmatic.ini
[EMC]
MACHINE = lagunmatic
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cncmill/linuxcnc/nc_files
PYVCP = shizuoka.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 1.0000
MAX_LINEAR_VELOCITY = 6.6666666000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = lagunmatic.hal
#HALFILE = custom.hal
#SHUTDOWN = shutdown.hal
POSTGUI_HALFILE = shizuoka-pyvcp.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.0
MAX_LINEAR_VELOCITY = 6.66666600
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
# tool turret info
TOOL_TURRET_MAX = 17
TOOL_TURRET_WRAP = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.05
MIN_FERROR = 0.007
MAX_VELOCITY = 6.6666660
MAX_ACCELERATION = 20.0
P = 105
I = 0
D = 0
FF0 = 0
FF1 = 1.197
FF2 = 0.01
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
ENCODER_SCALE = -20320
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -.001
MAX_LIMIT = 26.4
HOME_OFFSET = 2.8000000
HOME_SEARCH_VEL = -.2500
HOME_LATCH_VEL = -0.05000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = YES
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.05
MIN_FERROR = 0.005
MAX_VELOCITY = 6.66666660
P = 30
I = 0
D = 0
FF0 = 0
FF1 = 0.395
FF2 = 0.0055
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 0
ENCODER_SCALE = 20320
OUTPUT_SCALE = -10
MIN_LIMIT = -16.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = .5
HOME_LATCH_VEL = 0.050000
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0
FERROR = 0.1
MIN_FERROR = 0.02
MAX_ACCELERATION = 30.0
P = 60
I = 0
D = 0
FF0 = 0
FF1 = 1.155
FF2 = 0.01
BIAS = -0.0001
DEADBAND = 0
MAX_OUTPUT = 0
OUTPUT_SCALE = 10
MIN_LIMIT = -20.50
MAX_LIMIT = 0.05
HOME_OFFSET = -0.030000
HOME_SEARCH_VEL = .5000
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 2000.0
shizuoka-pyvcp.hal
#net seconds classicladder.0.s32out-05 pyvcp.seconds-number
#net minutes classicladder.0.s32out-04 pyvcp.minutes-number
#net hours classicladder.0.s32out-06 pyvcp.hours-number
#linksp Spindle-rpm-cmd pyvcp.spindle-speed
net tool-num-display carousel.0.current-position pyvcp.tool-number
net tool-release-button pyvcp.tool-release-button classicladder.0.in-16
#net mpg-x axis.0.jog-enable <= pyvcp.axis-selection.X_AXIS
#net mpg-y axis.1.jog-enable <= pyvcp.axis-selection.Y_AXIS
#net mpg-z axis.2.jog-enable <= pyvcp.axis-selection.Z_AXIS
#net mpg-a-axis axis.3.jog-enable <= pyvcp.axis-selection.A_AXIS
#net scale1 mux4.0.sel0 <= pyvcp.feed-multiplier..0010in
#net scale2 mux4.0.sel1 <= pyvcp.feed-multiplier..0100in
net esc-button halui.program.stop pyvcp.stop-execution
shizuoka.clp
_FILES_CLASSICLADDER
_FILE-rung_7.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=2
#NEXTRUNG=1
1-0-0/11 , 9-0-60/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 2-0-50/1 , 9-0-0/0 , 50-0-60/4
0-0-0/0 , 0-0-50/0 , 1-1-50/7 , 9-0-0/9 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 2-0-0/32 , 9-0-0/0 , 50-0-60/6
0-0-60/0 , 0-0-0/29 , 0-0-50/3 , 1-1-50/9 , 9-0-0/0 , 9-0-0/0 , 9-0-0/7 , 2-0-0/33 , 9-0-0/0 , 50-0-0/19
0-0-60/9 , 0-0-50/0 , 0-0-0/35 , 0-0-50/0 , 1-1-60/5 , 9-0-0/0 , 9-0-0/0 , 2-0-0/34 , 9-0-0/9 , 50-0-60/11
1-0-0/19 , 9-0-0/50 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/1 , 9-0-0/0 , 9-0-0/0 , 50-0-60/5
1-0-50/16 , 0-1-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/10
_/FILE-rung_7.csv
_FILE-arithmetic_expressions.csv
#VER=2.0
0004,@280/4@=@251/2@
0005,@280/5@=@251/4@
0006,@280/6@=@251/0@
_/FILE-arithmetic_expressions.csv
_FILE-timers.csv
2,4
2,11
2,2
2,1
2,5
2,5
2,2
2,3
2,3
2,3
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
_/FILE-timers.csv
_FILE-modbusioconf.csv
#VER=1.0
_/FILE-modbusioconf.csv
_FILE-rung_2.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=-1
#NEXTRUNG=7
1-0-50/0 , 9-0-0/0 , 9-0-0/0 , 2-0-0/30 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/10
0-0-0/10 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 50-1-0/11
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 50-1-0/13
0-0-0/10 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/14
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0
_/FILE-rung_2.csv
_FILE-sections.csv
#VER=1.0
#NAME000=Prog1
000,0,-1,2,4,0
_/FILE-sections.csv
_FILE-com_params.txt
MODBUS_MASTER_SERIAL_PORT=
MODBUS_MASTER_SERIAL_SPEED=9600
MODBUS_MASTER_SERIAL_DATABITS=8
MODBUS_MASTER_SERIAL_STOPBITS=1
MODBUS_MASTER_SERIAL_PARITY=0
MODBUS_ELEMENT_OFFSET=0
MODBUS_MASTER_SERIAL_USE_RTS_TO_SEND=0
MODBUS_MASTER_TIME_INTER_FRAME=100
MODBUS_MASTER_TIME_OUT_RECEIPT=500
MODBUS_MASTER_TIME_AFTER_TRANSMIT=0
MODBUS_DEBUG_LEVEL=0
MODBUS_MAP_COIL_READ=0
MODBUS_MAP_COIL_WRITE=0
MODBUS_MAP_INPUT=0
MODBUS_MAP_HOLDING=0
MODBUS_MAP_REGISTER_READ=0
MODBUS_MAP_REGISTER_WRITE=0
_/FILE-com_params.txt
_FILE-sequential.csv
#VER=1.0
S50,79,1701669204,114,0,0
S57,79,1701669204,114,0,0
S64,79,1701669204,114,0,0
S71,79,1701669204,114,0,0
S78,79,1701669204,114,0,0
S85,79,1701669204,114,0,0
S92,79,1701669204,114,0,0
S99,79,1701669204,114,0,0
S106,79,1701669204,114,0,0
S113,79,1701669204,114,0,0
S120,78,1701669204,114,0,0
S127,78,1701669204,114,0,0
T1,21541,13389,-256,-1,-1,21541,13389,-256,-1,-1,25934,8311,26964,25965,114,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,21541,13645,-256,-1,-1,37,84,77
C1,0,0/0
_/FILE-sequential.csv
_FILE-counters.csv
9999
59
59
9999
59
0
17
0
0
0
0
0
0
0
0
_/FILE-counters.csv
_FILE-rung_0.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=0
#NEXTRUNG=1
_/FILE-rung_0.csv
_FILE-rung_4.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=8
#NEXTRUNG=-1
1-0-0/31 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/30
2-0-0/10 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 99-0-0/0 , 13-0-0/0 , 0-0-0/0 , 50-1-60/7
9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 99-0-0/0 , 99-0-0/0 , 9-1-0/0 , 50-0-0/17
3-0-50/19 , 9-0-0/0 , 2-0-0/14 , 9-0-0/0 , 9-1-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/15
1-0-0/15 , 0-1-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 50-1-0/16
3-0-0/17 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/14
_/FILE-rung_4.csv
_FILE-symbols.csv
#VER=1.0
%I0,M6 SGNL,
%I1,TL CLMP P,
%I2,TL UNCL P,
%I3,TL UNCLPD,
%I4,,,
%I5,TARGET #,
%I6,,,
%I7,ORNT CPLT,no signal connected
%I8,MAG BK P,
%I9,MAG FWD P,
%I10,MAG UP P,
%I11,MAG DWN P,
%I12,POS CNT,
%I13,MAG HM SW,
%I14,%I14,
%I15,%I15,
%I16,%I16,
%I17,%I17,
%I18,%I18,
%I19,%I19,
%I20,%I20,
%I21,%I21,
%I22,%I22,
%I23,%I23,
%I24,%I24,
%I25,%I25,
%I26,%I26,
%I27,%I27,
%I28,%I28,
%I29,%I29,
%I30,%I30,no signal connected
%I31,%I31,
%I32,%I32,
%I33,%I33,
%I34,%I34,
%I35,%I35,
%I36,%I36,
%I37,%I37,
%I38,%I38,
%I39,%I39,
%I40,%I40,
%I41,%I41,
%I42,%I42,
%I43,%I43,
%I44,%I44,
%I45,%I45,
%I46,%I46,
%I47,%I47,
%I48,%I48,
%I49,%I49,
%Q0,OOOO,
%Q1,%Q1,
%Q2,%Q2,
%Q3,MAG CCW,
%Q4,ORIENT,
%Q5,TL UNCLP,
%Q6,MAG FWD,
%Q7,TCH CPLT,
%Q8,%Q8,
%Q9,TR DB,
%Q10,%Q10,
%Q11,MAG DWN,
%Q12,MAG CW,
%Q13,%Q13,
%Q14,%Q14,
%Q15,%Q15,
%Q16,%Q16,
%Q17,%Q17,
%Q18,%Q18,
%Q19,%Q19,
%Q20,%Q20,
%Q21,%Q21,
%Q22,%Q22,
%Q23,%Q23,
%Q24,%Q24,
%Q25,%Q25,
%Q26,%Q26,
%Q27,%Q27,
%Q28,%Q28,
%Q29,%Q29,
%Q30,%Q30,
%Q31,%Q31,
%Q32,%Q32,
%Q33,%Q33,
%Q34,%Q34,
%Q35,%Q35,
%Q36,%Q36,
%Q37,%Q37,
%Q38,%Q38,
%Q39,%Q39,
%B0,%B0,HOME LATCHED
%B1,MAG HM LA,INTERNAL COIL FOR MAG HOME LATCH
%B2,%B2,HOME LATCHED
%B3,%B3,HOME LATCHED
%B4,%B4,HOME LATCHED
%B5,%B5,HOME LATCHED
%B6,%B6,
%B7,%B7,
%B8,%B8,
%B9,%B9,
%B10,%B10,
%B11,%B11,
%B12,%B12,
%B13,%B13,
%B14,%B14,
%B15,%B15,
%B16,%B16,
%B17,%B17,
%B18,%B18,
%B19,%B19,
%B20,%B20,
%B21,%B21,
%B22,%B22,
%B23,%B23,
%B24,%B24,
%B25,%B25,
%B26,%B26,
%B27,%B27,
%B28,%B28,
%B29,%B29,
%B30,%B30,
%B31,%B31,
%B32,%B32,
%B33,%B33,
%B34,%B34,
%B35,%B35,
%B36,%B36,
%B37,%B37,
%B38,%B38,
%B39,%B39,
%B40,%B40,
%B41,%B41,
%B42,%B42,
%B43,%B43,
%B44,%B44,
%B45,%B45,
%B46,%B46,
%B47,%B47,
%B48,%B48,
%B49,%B49,
%W0,%W0,
%W1,%W1,
%W2,%W2,
%W3,%W3,
%W4,%W4,
%W5,%W5,
%W6,%W6,
%W7,%W7,
%IW0,%IW0,
%IW1,TOOL # RE,
%B50,%B50,
%B51,%B51,
%B52,%B52,
%B53,%B53,
%B54,%B54,
%B55,%B55,
%B56,%B56,
%B57,%B57,
%B58,%B58,
%B59,%B59,
%B60,%B60,
%B61,%B61,
%B62,%B62,
%B63,%B63,
%B64,%B64,
%B65,%B65,
%B66,%B66,
%B67,%B67,
%B68,%B68,
%B69,%B69,
%W8,%W8,
%W9,%W9,
%W10,%W10,
%W11,%W11,
%W12,%W12,
%W13,%W13,
%W14,%W14,
%W15,%W15,
%W16,%W16,
%W17,%W17,
%W18,%W18,
%W19,%W19,
%IW2,%IW2,
%QW0,%QW0,
%QW1,%QW1,
%QW2,%QW2,
%QW3,%QW3,
%QW4,%QW4,
%QW5,%QW5,
%QW6,%QW6,
%IF0,%IF0,
%IF1,%IF1,
%IF2,%IF2,
%IF3,%IF3,
%IF4,%IF4,
%IF5,%IF5,
%IF6,%IF6,
%IF7,%IF7,
%IF8,%IF8,
%IF9,%IF9,
%Q40,%Q40,
%Q41,%Q41,
%Q42,%Q42,
%Q43,%Q43,
%Q44,%Q44,
%Q45,%Q45,
%Q46,%Q46,
%Q47,%Q47,
%Q48,%Q48,
%Q49,%Q49,
%B70,%B70,
%B71,%B71,
%B72,%B72,
%B73,%B73,
%B74,%B74,
%B75,%B75,
%B76,%B76,
%B77,%B77,
%B78,%B78,
%B79,%B79,
_/FILE-symbols.csv
_FILE-general.txt
PERIODIC_REFRESH=2
SIZE_NBR_RUNGS=60
SIZE_NBR_BITS=90
SIZE_NBR_WORDS=55
SIZE_NBR_TIMERS=27
SIZE_NBR_MONOSTABLES=10
SIZE_NBR_COUNTERS=15
SIZE_NBR_TIMERS_IEC=10
SIZE_NBR_PHYS_INPUTS=50
SIZE_NBR_PHYS_OUTPUTS=50
SIZE_NBR_ARITHM_EXPR=25
SIZE_NBR_SECTIONS=6
SIZE_NBR_SYMBOLS=220
_/FILE-general.txt
_FILE-monostables.csv
1,5
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
1,0
_/FILE-monostables.csv
_FILE-timers_iec.csv
1,2,0
1,1,0
1,2,2
1,5,0
2,6,0
2,1,0
2,50,0
1,5,0
1,1,0
2,16,0
_/FILE-timers_iec.csv
_FILE-ioconf.csv
#VER=1.0
_/FILE-ioconf.csv
_FILE-rung_8.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=1
#NEXTRUNG=4
1-0-0/13 , 9-0-0/0 , 1-0-50/11 , 9-0-0/0 , 0-0-0/5 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/7
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-1-0/0 , 0-1-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/14
0-0-50/0 , 0-0-0/0 , 0-0-0/0 , 0-1-0/0 , 1-1-50/14 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-60/12
9-0-0/0 , 0-0-0/0 , 9-0-0/0 , 9-1-0/0 , 0-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 0-1-0/15
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 1-1-50/15 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-60/3
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 9-1-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-60/13
_/FILE-rung_8.csv
_FILE-rung_1.csv
#VER=2.0
#LABEL=
#COMMENT=
#PREVRUNG=7
#NEXTRUNG=8
1-0-0/16 , 9-0-0/14 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/34
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/3 , 1-1-50/10 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/33
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-1-50/10 , 0-0-0/0 , 99-1-0/0 , 13-0-0/1 , 9-0-0/0 , 50-0-0/32
0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-0-0/0 , 0-1-0/0 , 0-0-0/0 , 99-0-0/0 , 99-0-0/0 , 0-0-0/0 , 0-0-0/0
0-0-0/0 , 0-0-50/8 , 0-0-0/0 , 0-0-0/0 , 1-1-50/8 , 9-0-0/1 , 9-0-0/0 , 9-0-0/0 , 9-0-0/0 , 50-0-0/31
_/FILE-rung_1.csv
_/FILES_CLASSICLADDER
Outputs
| 0 | Spindle CW |
| 1 | Spindle CCW |
| 2 | Coolant Flood |
| 3 | Machine is Enabled |
| 4 | Spindle Orient |
| 5 | Spindle Index Enable |
| 6 | Tool Unclamp |
| 7 | Magazine Forward |
| 8 | Magazine Down |
| 9 | Magazine CW |
| 10 | Magazine CCW |
| 11 | |
| 12 | |
| 13 | Lube |
| 14 | |
| 15 | |
| 16 |
Inputs
| 0 | Lube Level |
| 1 | Both X |
| 2 | Both Y |
| 3 | Both Z |
| 4 | Home X |
| 5 | Home Y |
| 6 | Home Z |
| 7 | Spindle Orient Complete |
| 8 | |
| 9 | |
| 10 | Magazine Back Switch |
| 11 | Magazine FWD Switch |
| 12 | Magazine Down Switch |
| 13 | Magazine Position Switch |
| 14 | Magazine Home Switch |
| 15 | Magazine Home Switch |
| 16 | |
| 17 | Unclamp Tool Position |
| 18 | Tool Unclamped |
| 19 | |
| 20 | |
| 21 | Spindle Index Enable |
| 22 | |
| 23 | |
| 24 | Spindle Index Enable |
| 25 | |
| 26 | Estop Ext |
| 27 | |
| 28 | Cycle Start |
| 29 | Abort |
| 30 | Feed Hold |
| 31 | |
| 32 |
8 years 10 months ago #103335
Replied by andypugh on topic Lagunmatic 3516-SX Retrofit
If you just want XYZ then the Classic Ladder can wait. And if it worked on an identical machine then it should also work on yours.
So, what is the current obstacle to getting XYZ moving?
Time to create page: 0.161 seconds
