Elumatec SBZ 130/01 retrofit
9 years 9 months ago #86513 by PCW
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
look at motions commanded and feedback pins:
axis.N.motor-pos-cmd
and
axis.N.motor-pos-fb
The following error is the difference between these pins
9 years 9 months ago #86514 by tommylight
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
Using 2.8 so i have
joint.N.motor-pos-cmd
and
joint.N.motor-pos-fb
on the scope they do not move at all while
joint.N.pos-cmd
and
joint.N.pos-fb
react as they should
Leme scratch my head for a while, this is new for me.
9 years 9 months ago - 9 years 9 months ago #86515 by tommylight
Also pid.x.feedback does not move.
pid.x.command does not move
Last edit: 9 years 9 months ago by tommylight.
9 years 9 months ago - 9 years 9 months ago #86516 by PCW
Pretty sure you should be using:
and
joint.N.pos-cmd
and
joint.N.pos-fb
are unused
(and joint.N.pos-fb is not even an input)
Last edit: 9 years 9 months ago by PCW.
9 years 9 months ago #86517 by tommylight
Well, they are moving !!!
Had to do several jogs due to following error, but they do move slowly .
I am baffled !
9 years 9 months ago #86518 by tommylight
Checked the joint.0.ferror, it jumps sky high when jogging the axis and slowly fals back. Screen shot of halscope attached.
Time to create page: 2.123 seconds
