- Thank you received: 7491
Elumatec SBZ 130/01 retrofit
9 years 9 months ago #86501
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
Got the X axis working in both directions, now to expunge the joint.0.following errors
9 years 9 months ago #86502
Something fuzzy with encoder feedback, i get the error even when moving slowly at exactly the amount set in the ini file, namely i get the error at 1mm of movement, that is the min_ferror.
Something fishy in ..........enter country here !!!
- Thank you received: 5334
9 years 9 months ago #86503
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
Are you sure the feedback is negative? (there's a 50 % chance of getting this wrong on a first time setup)
You probably need to plot the commanded and feedback position (with HALScope) to see whats going on
9 years 9 months ago #86508
net x-pos-fb <= hm2_5i25.0.ssi.00.xencoder.position
net x-vel-fb <= hm2_5i25.0.ssi.00.xencoder.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_5i25.0.ssi.00.xencoder.index-enable
net x-pos-rawcounts <= hm2_5i25.0.ssi.00.xencoder.rawcounts
When i enable the x-vel-fb linuxcnc fails to start complaining about hm2_5i25.0.ssi.00.xencoder.velocity does not exist.
9 years 9 months ago - 9 years 9 months ago #86511
That's correct, there is no velocity pin on SSI (or BISS or FANUC) encoders
This is because unlike quadrature encoders, there is no mechanism to get a
better velocity estimate than simple d/dt of position
The PID component calculates this d/dt velocity automatically from the feedback position
if the pid.n.feedback-deriv pin is left unconnected
Last edit: 9 years 9 months ago by PCW.
9 years 9 months ago #86512
Thank you PCW.
Still getting the error, set the min_ferror at 3, i get the following error after exactly 3 mm of movement. DRO shows all is good moving up and down.
Seems to me like it is not updating the pid feedback.
Strange.
Strange.
Time to create page: 2.517 seconds
