- Thank you received: 7491
Elumatec SBZ 130/01 retrofit
9 years 9 months ago #86246
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
I read somewhere that some need that to be sent from controller to encoder, but will check on that in a bit.
Either way i do not consider that a problem, it can be done in hal, even if the encoder sends that signal back it can be done in hal.
The problem i have now is i have 5 of these encoders and only 4 SSI inputs on the 7i74. That leaves 2 options:
1. PCW can do another magic and do a firmware for 5 or 6 SSI ( just a thought, i do not want to bother him again, he and some other member here deserves a truck load of beer if and when i get to US)
2. Change the encoder on the spindle or Z axis as i have access to them without dismantling the machine, i got my eye on the spindle, already have plenty of incremental encoders.
Anyway, thank you all, much appreciated.
P.S.
Andy i know you're in England, somewhere...... alas they did not grant me entry even though i had a business schengen visa.
P.S.
9 years 9 months ago #86411
Took the day off today, having a coffe watching a movie thinking about the machine. I wish i had a switch for that, i keep thinking about the job 24 hours a day.
Well i got to test almost everything and all looks good so far so will wire the rest in the next days while testing each connection and function and adding the functions in hal.
Will have to add a bunch of small relays as the brakes draw 0.68A and the 7i71 can deliver 0.3A per output, no big deal at all just more wires. That would take care of the field power having 28.6V and 7i71 has 5 to 28V outputs and i do not like pushing electronics to it's limits, much safer this way.
Inputs on 7i70 can handle 32V so all is good there.
Not changing the encoder on the spindle as PCW generously offered to make a config for 6 SSI and 2 SSerial, very much apreciated and very happy for the extreemly good support.
Still have not test anything about the double X axis, i got some advice from forum members and as usual it is very much apreciated. One of the ideas was to have a sum of X and U used as X, but if i remember correctly U does not comply to velocity on G0 and G1 same as X or Y or Z moves, and that is no good so i will have to actually test that and see how it works out later on.
Also will have to figure out the toolchanger, so far i only found out it has something ( sensors, most probably) for tool 1,2,4,8 .
More fun, for sure.
Thank you all for everything.
P.S.
Took pictures of the wiring just in case anyone needs them.
More fun, for sure.
P.S.
- Thank you received: 5334
9 years 9 months ago #86415
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
9 years 9 months ago #86418
PCW, is it monday already???
Thank you very much.
9 years 9 months ago #86423
Nah, its Sunday but its raining...
9 years 9 months ago #86499
Ok, flashed the new firmware PCW made for me to have 6 SSI and 2 SSerial on 7i74, all working nicely.
Wired all encoders, all working.
Wired servo drives .........and working but only in one direction, pressing + or - moves in the sames direction on all axis. Checked the HAL Configuration for hm2_5i25.0.7i77.0.1.analogout0 and hm2_5i25.0.7i77.0.1.analogout1 and hm2_5i25.0.7i77.0.1.analogout2, all give negative value when pressing - or +.
Also changed the OUTPUT_SCALE adding - but no joy just changes the direction as it should, also changing encoder scale does nothing as far as moving forward/backward is concerned.
Time to create page: 2.027 seconds
