Elumatec SBZ 130/01 retrofit
9 years 9 months ago #85835 by tommylight
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
PCW wrote: freeby.mesanet.com/77ssiss.zip
Has the 5i25/6i25 bitfile and the new pinout file source code
P3 --> 7I77
P2 --> 7I74 (channels 0..3= SSI 4..7= Sserial)
Not tested, better to test with a 6i25 than 5I25 since a 6I25 can be boostrapped without
JTAG if a non-workin bitfile is loaded
Tested today, but it can not find analogout 's !!! Also checked the show pin and show param, no analog outs there.
Must something with addresses. Another thing i noticed after flashing this file, "reload" does not function any more. Flashed back the 5i25_7i74_7i77 bit file that comes with 5i25 configs, and reload works, analog works, all is good.
Hmmmmm i wonder.............. did a lot of research before reloading the working firmware, so i changed the 5V power supplies several times, just to be sure, wasn't it.
Back to the drawing board, PCW can i test this on another 7i92_7i77 combo, as far as i know it should work as 5i25 configs work always after changing the pci to eth and card name (well, number).
9 years 9 months ago - 9 years 9 months ago #85836 by PCW
Replied by PCW on topic Elumatec SBZ 130/01 retrofit
NO! NEVER load a bitfile thats is not specifically for the FPGA card or you will brick the card
I will check the bitfile tomorrow
( hal files are compatible across cards with minor changes but FPGA bit files are card specific )
Also noticed you said you used 7I74_7I77 bit file
If that the case you would have a 7I74 on P3 and a 7I77 on P2,
the config I supplied has the 7I77 on P3 and 7I74 on P2 so it is not going to work without swapping connectors
Last edit: 9 years 9 months ago by PCW.
9 years 9 months ago #85838 by tommylight
Oh cr@p, sorry for the mess up.
And i may add, damn you are quick !!! :)
Thank you very much Peter.
Assumptions are the mother of all f.........!!!!
Going in the corner to feel ashamed for a while......
9 years 9 months ago #85839 by PCW
Note my edit on previous post, you may have to swap connectors to get things to work
in any case its worthwhile to do a
mesaflash --device 5i25 --readhmid to verify the pinout
9 years 9 months ago #85840 by tommylight
I did and everything looked O.K.
P3 => 7i77 port on 6i25 card
P2 => 7i74 port added with cable
9 years 9 months ago #85842 by tommylight
BTW, is there a quick how to for combining mesa files ?
I would like to do it myself, only not to bother you with it.
I really appreciate your work, and amassing support you offer, makes using Mesa cards such fun.
Time to create page: 0.365 seconds
