1982 Matsuura MC-500v Retrofit
9 years 7 months ago #89359 by chopper79
Have a basic idea on how I want to mount my sensors. Need to model a few more thing fist and then I will make the mount and see how it fits. The mount is the left piece with the two holes. This will allow me to mount one sensor on top to pick up my index mark and the other two sensors will have more then enough adjustment are for me to dial it in.
This is just a concept at the moment.
9 years 7 months ago #89364 by andypugh
Looks like it will work. But it seems significantly more elaborate than necessary. Is it visible? If not, then some simple bits of bent metal would be perfectly adequate.
The following user(s) said Thank You: chopper79
9 years 7 months ago #89366 by skunkworks
9 years 7 months ago - 9 years 7 months ago #89370 by chopper79
I agree Andy and Skunk. I like to build things that fit locations and seem purpose built. I am very fond of simple solutions, but I need this mill to be able to run production and withstand the use over a long period of time. This is also the reason I made the gear. Could have made the timing pulley work, but it just did not feel right to me. Even though it would have worked fine.
If this fails then I will make a simple bracket with bent metal.
Oh and Andy.... No it is not visible to anyone else but is to me. I am kinda a pain in the a** when it come to stuff like that. Still not sure how my wife puts up with me.
Last edit: 9 years 7 months ago by chopper79.
9 years 7 months ago - 9 years 7 months ago #89378 by chopper79
Well here is the final sensor mount design. Do the sensors generate any heat?
Does anybody see any issue with the placement here?
One sensor is on the edge of a tooth and the other sensor would be either between two teeth.
9 years 7 months ago - 9 years 7 months ago #89386 by chopper79
Before I make this from a block of aluminum I figured I would 3D print the part first to check fitment and such. This right here is one of the main reasons I have a 3D printer. It is cheaper to prototype in plastic then metal. The other reasons are to make little trinkets with my kids.
Heck I may just use the 3D printer to make this sensor mount for the real one. Use some additive manufacturing for the subtractive manufacturing machine.
Time to create page: 0.066 seconds
