1982 Matsuura MC-500v Retrofit
9 years 7 months ago - 9 years 7 months ago #89292 by chopper79
Andy you got me thinking about this....
I checked my steel rack and I used 1018 for the gear and not 4140. I was going to bu the 4140 piece I had was not large enough. So I grabbed the 1018 stock instead.
Updated my posts to reflect. Thanks for bringing up the topic of material.
Last edit: 9 years 7 months ago by chopper79.
9 years 7 months ago #89305 by andypugh
Doing a bit more Googling, there isn't enough Chromium in 4140 to make it a stainless anyway.
(I am not too familiar with the US steel standards)
9 years 7 months ago #89314 by chopper79
Correct... It is pretty far off from being stainless. If 4140 had 10-12x more chromium it would stainless. Either way it would have worked fine for this gear, but I ended up using 1018 anyway so all is good.
Working on setting up a sensor mounting system now. Kinda unsure on how to align the two sensors on the teeth. I am thinking that one sensor should be centered on a root and the other sensor needs to be on the leading edge of another tooth. Never done one of these before so I am learning about the gear sensors as I go.
9 years 7 months ago #89325 by andypugh
chopper79 wrote: Kinda unsure on how to align the two sensors on the teeth. I am thinking that one sensor should be centered on a root and the other sensor needs to be on the leading edge of another tooth.
As long as one sensor is on an edge (any edge) while the other is half-way between two edges it will work. Make one mount slightly slottted is possible.
9 years 7 months ago - 9 years 7 months ago #89326 by chopper79
I will give it a go after I design a mount for the sensors. I will post my results.
9 years 7 months ago #89351 by andypugh
Here is one I did. Drilled holes and epoxy.
goo.gl/photos/umzFVy4JqTYQJMcH9
Kapton tape to keep the leads off the base plate.
The following user(s) said Thank You: chopper79
Time to create page: 0.069 seconds
