Almost finished with the wiring for all of the I/O. Down to my last 4 outputs on the 7i77 and if all goes well I will have exactly enough to complete the wiring. Inputs are not even close to being used up. (May need to by an additional output board)
Ran across two contacts that go up the tool change assembly. There are already two that go there so I am trying to figure out what those additional two would be used for?
The tool change assembly works (mag in , mag out, rotate cw, rotate ccw)so not sure why they second contacts. My guess is since one goes to magazine forward/reverse and the other goes to magazine cw/ccw is that they are brakes of some sort.
I will have to given them a trigger while rotating the tool changer and see if a brake is applied to dead stop the rotation. This would make sense to me as if I rotate the tool change now it seems to not always line up correctly. Seems to have a little free spin as the motor coast to stop.
I will update more about this later today or tomorrow.
