1982 Matsuura MC-500v Retrofit
9 years 9 months ago #85965 by skunkworks
Oh - good - Yay!
sam
9 years 9 months ago #85967 by chopper79
Now it is time to test the spindle to see i fI can get it to work and then order my mesa boards and begin the retrofit!!!!
9 years 9 months ago - 9 years 9 months ago #85981 by chopper79
Did not get the spindle moving......I need to go through all the wires and find the pins. Have the manuals so should be ok on that.
I am getting ready to order my boards from Mesa. I was planning on doing the following:
Can anybody think of why this setup will not work or anything additional I should add to the setup?
Last edit: 9 years 9 months ago by chopper79.
9 years 9 months ago #85989 by tommylight
Have a look here
forum.linuxcnc.org/30-cnc-machines/31792...rofit?start=40#85988
I did that setup since i had no constraints on budget, but it is worth every cent.
7i92/7i77 are obligatory in most cases, although 7i83 can be used for anlog outs
7i74 since i wanted to use SSI encoders on the machine ( i did order and get the incremental encoders just in case)
7i70 for inputs
7i71 for outputs ( sourcing outputs, you might need sinking ones, so do check )
You can add a 7i73 ( thank you andy ) for MPG
I like to have things separate as much as possible, and makes wiring less messy.
I am sure i will order a 7i83 and another 7i74 and a THCAD nest time i order, the versatility and support of Mesa boards is astonishing.
The following user(s) said Thank You: chopper79
9 years 9 months ago - 9 years 9 months ago #85992 by chopper79
Sounds like a nice setup tommylight
I am going to go with the 7i92M and the 7i77. I will break things out with terminal blocks to clean wiring up. On a small budget so need to keep the board count down as much as possible.
Skunkwork..... How many inputs and outputs did you end up using to get your machine working?
Keep in mind I will not be using 3 MPG like you did. I will just have a single one.
9 years 9 months ago - 9 years 8 months ago #86006 by chopper79
Just placed my order for my Mesa boards. I wish we had teleportation so I can have them now, as I am ready to get going on this conversion. Just a few days and I can get moving.
Last edit: 9 years 8 months ago by chopper79.
Time to create page: 0.300 seconds
