1982 Matsuura MC-500v Retrofit
9 years 9 months ago - 9 years 9 months ago #85944 by chopper79
Correct.... to what on the drive is my issue. In his picture he has them hooked up to the original wiring for the drives. I am not sure which pins on the original connector for the machine he used on his.
Once I find these wires then I can do some testing before I order my mesa boards.
Picture attached is skunkworks wiring on his board.
Last edit: 9 years 9 months ago by chopper79.
9 years 9 months ago #85946 by skunkworks
Awesome!!
The drive manuals have the pinouts. That is what we used. Make sure the encoders are 5v and not 12v. (some of the older ones had 12v encoders)
sam
9 years 9 months ago #85947 by chopper79
I have the manual for the drive. I also have 5v encoders thank goodness.
I am not sure which wires to use on the drive. I have found the analog lines (thanks tommylight) , but from there I can not seem to find the additional wires need to enable the drive.
Analog is pin 7 and 13
Servo on is pin 1
Have to missing something else to enable the drive though. Also is the servo on pin + and what voltage?
9 years 9 months ago #85951 by skunkworks
I cannot look right now - but I assume I hooked the other end of the enable (pin 1) to ground. (pin 16-19) on p1
sam
9 years 9 months ago - 9 years 9 months ago #85952 by chopper79
Just check pins 16-19 and they are at ground already. The servo on (pin1) do you remember the voltage use on that pin?
Seems that the servo ready pin (4) needs used also I would think. Not sure of the voltage needed for that either.
Manufacture has been ok for help but they jump around the questions. One wrong wire and I will lose a drive so I am very cautious on this one.
9 years 9 months ago #85953 by skunkworks
servo ready is an output from the drive.
sam
The following user(s) said Thank You: chopper79
Time to create page: 0.285 seconds
