1982 Matsuura MC-500v Retrofit
9 years 9 months ago #85955 by skunkworks
again - I think I just grounded pin 1 to enable the drive..
sam
The following user(s) said Thank You: chopper79
9 years 9 months ago #85956 by chopper79
Ok.. I see that now. Thank you
Then I should just need servo on (pin1) connected to ? voltage and the drive should enable and I can send it a small voltage from my bench top supply to check movement.
Right now if I send voltage to the analog then the IN led will turn on showing signal in. No movement though so seems like the drive is not being enabled.
9 years 9 months ago - 9 years 9 months ago #85958 by PCW
Replied by PCW on topic 1982 Matsuura MC-500v Retrofit
I would not apply any voltage to the drive enable pins, I'm pretty sure you ground them to enable the drive
Last edit: 9 years 9 months ago by PCW.
9 years 9 months ago - 9 years 8 months ago #85960 by chopper79
Grounded (pin1) and then applied voltage to the analog line and I can move my z axis both directions with my bench top supply.
Last edit: 9 years 8 months ago by chopper79. Reason: Removed not.... I CAN move my axis
9 years 9 months ago #85961 by skunkworks
what do the lights on the drive indicate?
sam
9 years 9 months ago - 9 years 9 months ago #85963 by chopper79
There is a green power light and then when I apply voltage to the analog +/- in the IN red led come on and the axis moves. No other lights at all.
Should there be?
Updated my reply to PCW.... I put not in there on accident. I meant to say I CAN move the axis.
Last edit: 9 years 9 months ago by chopper79.
Time to create page: 0.398 seconds
