1982 Matsuura MC-500v Retrofit
9 years 8 months ago #87333 by chopper79
Making slow progress on the retrofit. Software setup blues at the moment.
Here is a couple pictures of the mess so far. Once I get the computer and hardware to play nice then I can start making this look better. Also WORK!!
9 years 8 months ago - 9 years 8 months ago #87513 by chopper79
After many dumb errors on my behalf, there is movement. Still need to put in correct encoder count, ballscrew information, Then I can move onto the spindle, the i/o for the tool changer and limits. Using a 7i92 + 7i77 for interface boards running via Ethernet. Feels good to see it moving....
Milestone #2 achieved!!! A big Thank you goes out to the fellow LCNC users/developers that helped me with a few issues I have been having.
Last edit: 9 years 8 months ago by chopper79.
9 years 8 months ago - 9 years 8 months ago #87572 by chopper79
Ok... This is just to document the information I am finding on the factory encoders. Hope this helps somebody else in the future.
Encoders are Yaskawa TFUE Series
ie: tfue-(25)zd7 = 2500ppr encoder. (First 2 number * 100 = ppr)
There are two types of encoders offered, they are a 12v and a 5v style. You will need the 5v style and this is determined by the part number also. The following will determine the voltage.
tfue-25z(d)7 -> the D = 5v encoder
tfue-25z(c)7 -> the C = 12v encoder
My machine came with the 5v style encoders so there was no need to change them over.
9 years 8 months ago #87574 by skunkworks
The inch input scale for ours was 25400 :)
The following user(s) said Thank You: chopper79
9 years 8 months ago #87580 by chopper79
I have attached a link for all the manuals I have about the MC-500v2. Some of these manuals are specific to my machine, but most are general manuals. The file included wiring, operation, service, drive manuals, spindle manuals, etc. Good little collection of files for anybody who needs them. I will continue to add information to this link as I get it.
Hope this helps somebody in the future.
STUFF
* wanted to upload files here, bu they are greater than 1.6mb so I had to go back to my dropbox link.
The following user(s) said Thank You: sinusvag
9 years 8 months ago - 9 years 8 months ago #87581 by chopper79
Ball Screw information:
X axis = 12mm pitch
Y axis = 12mm pitch
Z axis = 10mm pitch
When used with the factory encoders and motors you will have the following (if you have same equipment)
X axis = TFUE30ZD7 encoder (3000ppr) with a 12mm pitch ball screw = 25399.9992 scale
Y axis = TFUE30ZD7 encoder (3000ppr) with a 12mm pitch ball screw = 25399.9992 scale
Z axis = TFUE25ZD7 encoder (2500ppr) with a 10mm pitch ball screw = 25399.9992 scale
Using factory settings on drives and my old FERROR values (.05) I am at 600ipm on both X &Y. The Z axis is at 475ipm. The acceleration is set at 30.0 on each axis.
FERROR will be reduced as PID tuning happens. I am sure the as I reduce the FERROR value I will also be reducing the IPM on each axis. I hope not but we will see.
Time to create page: 0.157 seconds
