Brother TC-225 / TC-229 adventure!
9 years 2 months ago - 9 years 2 months ago #98034 by PCW
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
One thing the would help a bit is plotting the commanded velocity and the encoder velocity
The commanded velocity would show the TPs motion better than position does
The encoder (feedback) velocity might shed some light on source of the high frequency oscillation
Last edit: 9 years 2 months ago by PCW.
9 years 2 months ago #98035 by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
ok, ill do that in the morning. (I went home :P)
thanks.
on a mechanical note, I checked the tc229 and it has zero backlash in all axes. I need a spindle drive for that guy! :)
9 years 2 months ago #98052 by ihavenofish
No eBay APP ID and/or Cert ID defined in Kunena configurationso, I noticed these are well priced...
and then noticed they are being used with linuxcnc by some people. thinking that maybe we use this for the tc229, I already have a full beckhoff kit with IO, relays, and other nifty bits and bobs.
how mature is the ethercat in linuxcnc? would it be easy to set up and get running well? keep in mind this is me, and uh... I usually need hand holding :P
9 years 2 months ago #98111 by ihavenofish
well, I did nothing since Friday. had a dental issue, much pain. haha. hopefully I can get back to it tonight, otherwise ill get those hal scope plots tomorrow night.
9 years 2 months ago #98114 by PCW
Yow!
Take it easy
9 years 2 months ago #98118 by ihavenofish
8ipm jog same pod settings as before
Time to create page: 0.687 seconds
