- Thank you received: 286
Brother TC-225 / TC-229 adventure!
- ihavenofish
9 years 2 months ago #98128
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
Doh it's in one of the screen grabs.
P 150
I .02
D .2
Ff0 0
Ff1 .87
Ff2 .00105
Bias 0
Dead band. 00001
P 150
I .02
D .2
Ff0 0
Ff1 .87
Ff2 .00105
Bias 0
Dead band. 00001
- Thank you received: 1480
9 years 2 months ago #98129
Replied by Todd Zuercher on topic Brother TC-225 / TC-229 adventure!
I think I would try reducing P to about 100 and setting I and D to 0. See if that gets a mostly smooth velocity plot. Then fine tune FF1 and FF2 to minimize the following error. Once there, then you should be able to add back some more P to try to stiffen things up.
- ihavenofish
9 years 2 months ago #98130
by ihavenofish
nope. no combination of settings smooths it. even p at some low number like 10 doesn't. it just makes bigger oscilations.
the biggest factor in getting the z for squealing to just short oscillations, was deadband. I kept making it smaller, and it got better. but there seems to be a limit, and basically, all 3 axes are roughly behaving the same right now.
I think there may be something deeper wrong here. the whole analogue output mimicking the follow error, seems weird to me.
hmmmm
hmmmm
- ihavenofish
9 years 2 months ago #98162
by ihavenofish
so, any more thoughts? haha.
ive recovered from the novocaine haze, and would like to try and get further on tuning tonight.
- ihavenofish
9 years 2 months ago #98163
by ihavenofish
how would i make the motor just move smoothly, disregarding error?
is that p=0, ff1=1?
basically saying move at x velocity, but dont attempt to compensate kinda like open an loop.
thanks
is that p=0, ff1=1?
thanks
- Thank you received: 5334
9 years 2 months ago #98164
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
You would not use FF1= 1, you would use the value you determined from tuning
(you can also use a very small amount of P to prevent drift for this test)
(FF1 _would_ be 1 if you set the analog output scale to the velocity in machine units per second at 10V)
Time to create page: 1.140 seconds
