Brother TC-225 / TC-229 adventure!
- ihavenofish
- Thank you received: 286
28 Oct 2024 01:25 #313344
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
The following user(s) said Thank You: RotarySMP, tommylight
- ihavenofish
28 Oct 2024 23:23 #313391
by ihavenofish
- ihavenofish
29 Oct 2024 03:17 #313406
by ihavenofish
The following user(s) said Thank You: tommylight, besriworld
- Philip Lydin
- Thank you received: 6
06 Nov 2024 16:59 - 06 Nov 2024 17:05 #313924
by Philip Lydin
Replied by Philip Lydin on topic Brother TC-225 / TC-229 adventure!
When i plug my vfd in and enable it eeven though not applying any voltag i get vibrations. Its a tc215 have anyone experienced anything similar? im running it on 230v, might that be a reason should be fine since 210v +/-10% ( this is not for the main voltage where i have 200v three phase only 230 on the control voltage)
Last edit: 06 Nov 2024 17:05 by Philip Lydin.
- Philip Lydin
06 Nov 2024 20:50 #313963
by Philip Lydin
does anyone know what the r210 and s210 cables coming from the spindle motor is and what the et pin on the drive is
- ihavenofish
07 Nov 2024 01:36 #313982
by ihavenofish
The spindle and servo should be identical connections. but the toshiba version i remember are different than sanyo. There is another thread on a 211 here than might help.
As for vibrating, If you have no signal connected it is floating, and it could be seeing the noise as a motion command. So I think you need to connect a signal.
I don't know what r/s210 are, ET is enable I think. Sadly I only have the user manual for the 225/215, but not the electrical diagram.
- Philip Lydin
08 Nov 2024 19:44 #314091
by Philip Lydin
i tried with a battery and and variable psu but it makes alot of noise and shuts off because of overheating after maybe a minute of running, i guess the drive is overheating since i dont got the tempreature sensor connected. Any help or thoughts would be much appriciated. is it possible to send videos or maybe audio files?
- ihavenofish
08 Nov 2024 19:53 #314092
by ihavenofish
Why not hook it up correctly/ the pinouts are in this thread. You cant expect anything to work if you have it only half connected.
- Thank you received: 7478
08 Nov 2024 21:12 #314096
Do keep track at what brush was in what orifice and how it was oriented, that is very important.
Replied by tommylight on topic Brother TC-225 / TC-229 adventure!
Noise and vibrations are from interference with unshielde/ungrounded wires, but since it is an old machine, check if motors have brushes and if they do, yank them out and use compressed air inside the brush orifice to remove the fine dust that gathers there and can cause heating during normal work.i tried with a battery and and variable psu but it makes alot of noise and shuts off because of overheating after maybe a minute of running, i guess the drive is overheating since i dont got the tempreature sensor connected.
- alexbrem89
08 Nov 2024 21:13 #314097
by alexbrem89
Replied by alexbrem89 on topic Brother TC-225 / TC-229 adventure!
Does anyone happen to know how I can connect the spindle orientation?
I have the spindle turning, but not yet the orientation
Time to create page: 1.903 seconds
