- Thank you received: 4153
I'm no expert on lathes but I think you would program a simple turning operation and allow the external offset change the X axis coordinates to follow the cam lobe profile. eg at TDC of the lobe, you would be the height of the lobe away from the main shaft circle and back on it when the lobe ends due to some algorithm that accepts the rotary position as an input.marsheng wrote: Thanks rodw
I've looked up external offsets but I'm non the wiser.
What would the G-Code look like ?
marsheng wrote:
Mnn Now I'm getting excited to get started
